Kushlan Cement Mixer 600DDS 2014 Power Components Replacement
  1. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the motor cover bolts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, ensure the power cord is unplugged and the power switch is in the OFF position.
    • Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
  2. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the motor cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor cover.
  3. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the electrical panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four screws securing the electrical panel.
  4. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the electrical panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the electrical panel.
  5. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the on/off switch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the on/off switch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the on/off switch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of needle-nose pliers to disconnect the four wires from the back of the on/off switch.
    • During reassembly, ensure the wires are connected back into their original locations and the on/off switch is not upside-down.
  6. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a flathead screwdriver to press the sides of the on/off switch through the opening in the electrical box.
  7. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the on/off switch.
  8. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the power cord: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two screws securing the fastener behind the strain relief fitting.
  9. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fastener.
  10. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the green ground wire to the bottom of the electrical box.
  11. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an adjustable wrench to remove the power cord's strain relief fitting cap.
  12. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the cap off of the strain relief fitting.
  13. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Feed the power cord and its black, white, and green wires out through the strain relief fitting.
    • Transfer the strain relief fitting cap onto the new power cord.
  14. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement, Remove the capacitor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the capacitor support.
  15. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the capacitor support.
  16. Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Power Components Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of needle nose pliers to disconnect the red and black wires from the capacitor.
    • Remove the capacitor.
    • Use tape or a zip tie to differentiate this set of red and white wires from the other set of red and white wires running to the on/off switch to ensure proper reinstallation.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87.448 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
Very well presented. The photos were very sharp and clear. From looking at your photos it would apear that you can reverse the motor rotation by reversing the 2 capacitor leads. This would make empting the mixer eaiser in some situations. Do you agree?
Thank you,
Drew Watson
Drew Watson - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 86
crwdns2942667:0crwdne2942667:0 3,640
