Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the motor cover bolts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, ensure the power cord is unplugged and the power switch is in the OFF position.
    • Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
  2. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the motor cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor cover.
  3. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the motor cage bolts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 13 mm socket to remove the four bolts securing the motor cage to the frame.
  4. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the motor cage: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the motor cage: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motor cage.
  5. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the drum: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 19 mm socket to remove the 70 mm-long bolt securing the drum to the output shaft.
  6. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the drum straight off of the output shaft and set it aside.
    • Two people may be required depending on the weight of the drum.
  7. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement, Remove the gearbox and motor assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Have a second person hold the gearbox and motor assembly while you remove the nuts to prevent it from dropping.
    • Use a 10 mm socket to remove the four nuts securing the gearbox to the frame.
  8. Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kushlan Cement Mixer 600DDS 2014 Gearbox and Motor Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gearbox and motor assembly from the frame.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
87,448 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2942667:0crwdne2942667:0 30
