Follow this guide to replace the capacitor (also commonly called a condenser) on a 2014 Kushlan cement mixer model 600DDS.
To prevent electric shock, leave the device unplugged for 20 minutes to allow the capacitor to discharge before you begin.
Use a 13 mm socket to remove the two bolts securing the motor cover to the frame.
Remove the motor cover.
Use a Phillips screwdriver to remove the four screws securing the electrical panel.
Remove the electrical panel.
Use a Phillips screwdriver to remove the screw securing the capacitor support.
Use a pair of needle nose pliers to disconnect the red and black wires from the capacitor.
Remove the capacitor.
