  1. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Drain your eReader's battery as much as possible before starting your repair. Ideally, it should be fully discharged.
    • Optionally, to drain the battery faster, navigate to MoreSettingsEnergy saving and privacy and set Automatically go to sleep after and Automatically power off after to Never.
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery.
    • Unplug all cables and fully shut down your eReader.
    • Your screen should be black and say Powered off.
  2. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay your eReader down so the back cover is facing up.
    • Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
    • Push the pick downwards at a slight angle until it slides under the back cover.
  3. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick toward the bottom right corner to release the clips along the bottom edge.
  4. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pick and reinsert it under the bottom left corner.
    • Angle the pick flat under the back cover and rotate it around the bottom left corner to release its clips.
    • If you're having trouble, try twisting the pick to lift the corner clips out of their slots.
  5. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick toward the top left corner to release the clips along the left edge.
  6. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At this point, you should be able to grip the back cover and release its remaining clips. If not, slide a pick under the perimeter of the back cover until you can grip an edge.
    • Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
    • Remove the back cover.
    • During reassembly, align the back cover over the eReader and press along the perimeter until all its clips snap back into place.
  7. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The entire surface of the eReader's internals is covered in a thin, plastic-like waterproof coating. Keep the following in mind as you continue disassembly:
    • While this won't hurt your device, removing the coating compromises the device to potential water damage.
    • The coating is brittle and can flake into many small pieces. Heating the coating helps, but working with it is still a time-consuming process.
    • The ZIF connector locking tabs are coated in a gel that can jam the hinge and keep the locking tab from completely unlocking. Make sure the tabs are completely upright before disconnecting any cables.
    • Depending on your repair, you might have to remove the coating from ZIF connectors and their cables.
  8. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  9. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to scrape up the coating along the white battery connector head—enough so you can grab clumps of it with pointed tweezers.
  10. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use pointed tweezers to peel off all of the coating around the battery connector head and its socket.
    • If the coating becomes too brittle and hard to peel off, reheat the connector and try again.
    • This is a meticulous process! Failure to remove enough of the coating could damage the plastic head during disconnection, so take your time!
  11. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger under the edge of the battery connector head opposite of the cable.
    • There's a surface-mounted component close to the connector. Be careful not to touch it with your spudger!
    • Lift up the connector with the spudger to separate the rest of the coating and disconnect the battery.
    • During reassembly:
    • Inspect the connector head and its socket for any remaining coating that could prevent a good connection.
    • Peel off the coating, heating the area when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating so the connector head sits properly in its socket.
  12. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When working on or near the battery, don't use sharp metal tools to avoid puncturing and shorting the battery! A punctured battery can leak dangerous chemicals and catch fire.
    • If your battery comes with stretch release adhesive, follow the next two steps to remove them.
    • Otherwise, skip ahead three steps to remove the normal adhesive.
  13. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next two steps show how to remove a battery that's secured by stretch release adhesive.
    • Use tweezers to pull on the battery adhesive strip's pull tab until you can grip it with your fingers.
    • While holding the battery in place, pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
    • You can also wrap the adhesive strip around a spudger and "roll" it for a more consistent pull.
    • If the adhesive strip breaks off, try to retrieve it using your fingers and continue pulling—but don’t pry under the battery.
    • If you can't retrieve a strip, don't worry! Remove as much adhesive as possible and skip down two steps for an alternate method.
  14. : crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  15. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next four steps show how to remove a battery that's secured by regular adhesive.
    • Apply a few drops of isopropyl alcohol under the right edge of the battery.
    • Tilt the eReader up to let the isopropyl alcohol flow under the battery and wait one minute for it to soften the adhesive.
  16. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide a plastic card a half an inch (~13 mm) under the top right corner of the battery.
    • Rotate the plastic card so its short edge sits under the right edge of the battery.
  17. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the plastic card under the battery to separate the adhesive and the thin layer of coating.
    • Don't bend or crease the battery! Avoid prying or lifting up with the plastic card.
    • If you're having trouble, apply a few more drops of isopropyl alcohol and try again.
  18. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery off the frame and remove it.
    • If you're transferring the battery to a new screen, inspect the battery for any dents or deformations.
    • Never reuse a damaged battery! If your battery shows any signs of damage, replace it with a new one.
    • During reassembly, follow this guide to install a new battery or to transfer an old battery to a new screen.
  19. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are surface-mounted components next to the power button ZIF connector. Follow the instructions carefully to avoid dislodging them.
    • Insert the tip of a spudger under the right side of the power button ZIF connector's black locking tab.
    • Lift up the locking tab with the spudger to unlock it.
    • The locking tab should be nearly vertical when unlocked. If not, gently push the tab forward to compress the gel and completely unlock the tab.
  20. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and lay it on the power button connector for 90 seconds to soften the coating.
    • Alternatively, you can use a hair dryer or a heat gun.
  21. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt nose tweezers to grip the cable close to the head and pull it away from its ZIF connector slowly and steadily to separate the coating.
    • If the coating feels stubborn, reheat the connector and try again.
    • Gripping the tweezers closer to the tip can help you get a tighter hold on the cable.
    • Keep pulling on the cable until the cable comes completely out of its socket.
    • Inspect the head of the cable and the ZIF connector for any remaining coating that could prevent a good connection.
    • Peel off the coating—heating the cable and the ZIF connector when the coating becomes too brittle.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in its connector.
  22. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and lay it on the power button board for 90 seconds to soften the coating.
  23. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the coating along one of the long edges of the power button board.
    • The side doesn't matter! Choose whichever side has the easiest-to-remove coating.
  24. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to scrape the coating along the base of the power button board—enough so you can grab clumps of it with tweezers.
    • Don't use tweezers to scrape the coating, as you could accidentally puncture the board.
  25. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to peel off the coating on the power button board.
    • If the coating becomes too brittle and hard to peel off, reheat the board and try again.
    • It doesn't have to look pretty! You just need to remove enough coating so the board can move freely during the next four steps.
  26. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The adhesive securing the power button board is strong and requires time and patience to separate properly. Follow the next four steps closely to avoid damaging the power button board.
    • Heat an iOpener and lay it on the power button board for 90 seconds to soften the adhesive.
  27. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an arm of pointed tweezers under the edge of the power button board that you separated the coating from.
    • If you're having trouble, reheat the board and try again.
    • Slide the arm along the edge of the board to separate enough adhesive to fit an opening pick under the board.
    • Keep the arm as flat to the frame as possible to avoid scratching the metal.
  28. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the tweezers and immediately replace it with the tip of an opening pick to prevent the adhesive from resealing.
    • Slide the pick along the edge of the power button board to separate the adhesive.
  29. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the opening pick under the bottom of the power button board and under its cable.
    • Slide the opening pick along the other edge of the board to separate the remaining adhesive.
  30. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the power button board off the frame and remove it.
    • During reassembly, follow this guide to transfer your power button board to a new screen or to install a new one.
  31. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lift up the locking tab on the digitizer cable ZIF connector.
  32. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the digitizer cable ZIF connector for 90 seconds to soften the coating.
  33. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the digitizer cable close to the head and pull it away from its ZIF connector slowly and steadily to separate the coating.
    • Keep pulling on the cable until it comes completely out of its socket.
  34. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are surface-mounted components next to the display ZIF connector. Follow the instructions carefully to avoid dislodging them.
    • Insert the flat end of a spudger under the right side of the ZIF connector's black locking tab.
  35. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener and lay it on the display connector for 90 seconds to soften the coating.
  36. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt nose tweezers to grip the corner of the display cable closest to the charging port.
    • Pull the cable away from the ZIF connector slowly and steadily at a level angle to separate the coating at the corner.
    • If you're having trouble, try rocking the cable side-to-side while pulling.
    • Gripping the tweezers closer to the tip can help with getting a tighter hold on the cable.
  37. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for the other corner until the the cable comes completely out of its socket.
  38. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the display cable and peel off any remaining coating holding it to the motherboard.
    • Inspect the ends of the cable and the ZIF connectors for any remaining coating that could prevent a good connection.
    • It doesn't have to look pretty! You just need to remove enough coating to have the cable sit properly in the connector.
  39. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the display cable out of the way of the backlight cable underneath.
    • Use the point of a spudger to lift up the blue locking tab on the backlight cable ZIF connector.
  40. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener and lay it on the backlight connector for 90 seconds to soften the coating.
  41. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  42. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 2.4 mm‑long screws securing the motherboard.
  43. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide an opening pick under the top left corner of the motherboard and lift it up enough to grip the motherboard with your fingers.
  44. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Angle the motherboard up and pull it toward the top edge of the eReader to remove it.
    • During reassembly, slide the charging port into its slot at an angle before pressing the motherboard flat to the frame.
  45. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 : crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 3 mm‑long screws securing corners of the front cover.
  46. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screen is secured by adhesive along the perimeter of the front cover and a layer of coating at the bottom edge.
    • Bend the top edge of the front cover around the screen to separate the adhesive.
  47. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top edge of the screen to separate any remaining adhesive around the perimeter of the front cover.
    • Slide the screen toward the top of the eReader to expose the coating at the bottom edge.
  48. crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
    : crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 : crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 : crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and rotate the screen off the bottom edge of the front cover to separate the coating.
    • Remove the screen.
    • You've now disassembled your eReader enough to transfer the internals to your new screen.
    • Align the front cover over the screen and press down around the perimeter until the clips snap back into place.
    • Follow this guide to update the VCOM number on your eReader to match the replacement screen.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
165,955 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,068crwdne2935297:0
Thanks for this. I ordered the screen and tool kit and had it fixed in around 2 hours maybe less. I had a magnifying glass which helped alot to identify where the clear coating was. The guide was excellent and its working no dramas so far. Cheers
Gsmith - crwdns2934203:0crwdne2934203:0
The adhesive of the battery was very annoying, it took a lot of alcohol and time to remove the battery. All the other steps are very easy. If you have a Tolino Shine 5, you have to revert to the Kobo firmware to adjust the vcom value.
Klaus - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 165
crwdns2936753:030crwdne2936753:0 618
crwdns2942667:0crwdne2942667:0 6,130
