Jura Z Model remove ceramic valve
  1. Jura Z Model remove ceramic valve, Open the Jura Z models.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the machine from the power outlet
    • Remove all attachments: water tank, drip tray, aroma lid
  2. Jura Z Model remove ceramic valve: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the machine so the back is facing toward the front.
    • The Jura sign must be removed. Turn it a few millimeters counterclickwise.
    • If this becomes difficult use a suction cup to assist.
    • Remove the Jura sign.
  3. Jura Z Model remove ceramic valve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Behind the Jura sign are two screws with an oval head. They have to be removed.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
  4. Jura Z Model remove ceramic valve: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the back down a bit and then remove it.
  5. Jura Z Model remove ceramic valve: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right side panel- as seen looking to the frontpanel - backwards and take it off.
    • Sometimes it gets a bit stuck and may require a bit more of a pull.
  6. Jura Z Model remove ceramic valve: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In this step, you should remove the screws of the left side panel. The side panel can only be removed after removing the top cover.
    • Remove the Torx T15 screw on the front wall of the side panel.
    • In the side part there is a lid over the brew group. The lid is fastened at the top with two oval head screws. Remove those to remove the lid.
    • With the cover removed the brew group becomes visible
  7. Jura Z Model remove ceramic valve: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step shows how to remove the top cover
    • Remove the powder tray and all coffee beans.
    • The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
    • Remove the two Phillips screws on the bean container and remove the bean container.
    • Lift the cover upwards.
    • If it is stuck, use a plastic opening tool to carefully pry it open.
    • The lid of the bean container is held in place by a small, strong magnet that loosely rests. It is either in the green marked recess, or it remains hanging on the bean container. Make sure it is not lost!
  8. Jura Z Model remove ceramic valve: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Z Model remove ceramic valve: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the left side panel backwards to take it off.
    • For some repairs it is not necessary to remove the left side panel.
  9. Jura Z Model remove ceramic valve, Jura Z models removing the ceramic valve: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Z Model remove ceramic valve, Jura Z models removing the ceramic valve: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The ceramic valve is only pushed in. Release the detents at the bottom of the white plastic base and slide the valve to the right.
    • Lift out the valve.
    • Disconnect all connections and remove the valve.
    • If the valve is only to be removed to access other parts, you can leave the connectors on.
Work through the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
289,385 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 2,768
