Jura Ceramic Valve repair
  1. Jura Ceramic Valve repair, Ceramic Valve: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are many sensitive parts on the inside of the Valve. The exact position is important and often the only position that works is the original one. Work slowly and carefully and take many pictures of the original positions, so you can reassemble them again later.
    • Unscrew the two Story T20 Screws from the Flange of the Motor and take it out carefully.
  2. Jura Ceramic Valve repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Ceramic Valve repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The distributor head with the ceramic discs is secured with two additional Torx screws. Once you loosen them, you can remove the head. Be sure to note the two nuts that come loose.
    • Motor
    • Flange
    • Distributor head
    • Carefully remove the black distributor head from the white part. Caution: the ceramic discs are now exposed. Blow into all connections and check that they are clear. You may need to descale the head.
    • Check the Head for Cracks. You can maybe find replacement parts here.
    • Check the driver for abrasion.
    • Work very carefully from here. If you disassemble the head, look at the exact position of every disk and take pictures of them. If you want to replace the Microswitches, you can hold it together provosionally.
  3. Jura Ceramic Valve repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Ceramic Valve repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is the motor flange and the motor.
  4. Jura Ceramic Valve repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Jura Ceramic Valve repair: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Jura Ceramic Valve repair: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Image 1 shows the driver and one of the microswitches.
    • Images 2 and 3 show the pack of ceramic discs under the distributor head. Note the elastic seal made of transparent silicone. If the ceramic valve is not tight, replace this seal.
    • You can slide the discs apart, e.g. for descaling. However, be very careful as they can break.
    • The discs are shaped so that they can only be installed one way. Do not use force during assembly.
    • Lightly grease the moving parts with food-safe silicone grease during assembly, but not the discs.
  5. Jura Ceramic Valve repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Jura Ceramic Valve repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Image shows an old and new switch. They are the most common cause of error of the Valve. It is clearly visible how the shutter button has been ground down by about 1 mm and can't activate.
    • One of the microswitches is plugged into the distributor head and one into the motor flange. It is held in place by side catches. Push them to the side and lift out the switches.
    • Notice the exact position of the switches and the colors of the cables they are connected to.
    • Desolder the Switches and resolder the new ones.
    • Good replacements are:Cherry DB3, Cherry DB3 or SAIA XCG3Z1.
To reassemble your device, follow the steps in reverse order.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
293,806 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
Repair is War on Entropy crwdns2935289:0Repair is War on Entropycrwdne2935289:0
Community
crwdns2931471:032crwdne2931471:0
crwdns2935297:01,563crwdne2935297:0
crwdns2936751:024crwdne2936751:0 17
crwdns2936753:07crwdne2936753:0 141
crwdns2936753:030crwdne2936753:0 589
crwdns2942667:0crwdne2942667:0 3,864
