Joy-Con Buckle Lock Replacement
Adam O'Camb
crwdns2944107:0crwdnd2944107:0Adam O'Cambcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:010crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 5, 2025crwdne2944111:0
10 - 30 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the buckle lock in a Nintendo Switch Joy-Con with a metal one, or a new plastic one.
There are a few minor differences between the left and right Joy-Cons, but none that will affect the procedure. These steps apply to both Joy-Cons.
crwdns2944105:0crwdne2944105:0
  1. Joy-Con Buckle Lock Replacement, Remove the case screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-point Y00 driver to remove the four 6.3 mm-long screws from the back panel of the Joy-Con.
  2. Joy-Con Buckle Lock Replacement, Separate the halves of the Joy-Con: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con Buckle Lock Replacement, Separate the halves of the Joy-Con: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con Buckle Lock Replacement, Separate the halves of the Joy-Con: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
    • Slowly slide the flat edge of your opening pick up the side of the Joy-Con.
    • Be careful not to slide the opening pick too far inside the Joy-Con. This may damage the inner components. The back panel loosens easily, so not much pressure is needed.
  3. Joy-Con Buckle Lock Replacement, Open the Joy-Con: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con Buckle Lock Replacement, Open the Joy-Con: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the charging rail facing away from you, open the the Joy-Con like a book.
    • Don’t try to fully remove the back panel. There are still two cables connecting the charging rail to the motherboard.
  4. Joy-Con Buckle Lock Replacement, Unscrew the charging rail: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 driver to remove the 2.5 mm screw securing the charging rail.
  5. Joy-Con Buckle Lock Replacement, Remove the back panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Joy-Con Buckle Lock Replacement, Remove the back panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the back panel straight off of the charging rail to remove it.
    • There's a chance the rail unlock button will fall out of the back panel. During reassembly, make sure it is installed correctly, with the tab on the button slotted into the notch in the back panel.
    This took me by surprise because the charging rail is actually attached with glue as well. The glue is located in the middle of the rail.
    Steven Reynolds - crwdns2934203:0crwdne2934203:0
  6. Joy-Con Buckle Lock Replacement, Remove the buckle lock bracket: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 driver to remove the screw securing the buckle lock retaining bracket.
    Be sure not to over-tighten this screw on reassembly, or the button will stick. Test the button before reassembling the plastic shell.
    Andy Harris - crwdns2934203:0crwdne2934203:0
    Is there a missing step of disconnecting the cables to the other half of the joycon?
    Nexant - crwdns2934203:0crwdne2934203:0
    No, that's not necessary. The repair can be completed with the ribbon cables still attached.
    James Hartman -
    Damit es auch auf Deutsch dasteht: man muss wirklich aufpassen beim Zusammenbauen die Schraube nicht zu fest zu ziehen da sich der Sicherungsriegel sonst nicht mehr gut bewegen kann.
    Thomas Reichert - crwdns2934203:0crwdne2934203:0
  7. Joy-Con Buckle Lock Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con Buckle Lock Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con Buckle Lock Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one side of a pair of pointed tweezers under the flat part in the middle of the buckle lock bracket.
    • Grasp the bracket with the tweezers and pull the bracket straight away from the charging rail to remove it.
    • Be careful when you remove the bracket, as the spring and old buckle lock may shoot out and be easily lost.
    This step takes some considerable force by the way.
    IkBenAnders - crwdns2934203:0crwdne2934203:0
    if you have trouble removing the silver bracket just pry with the tweezers then put the screwdriver under the bracket the pry and it comes of so much easier!!!
    Micah Hilbert - crwdns2934203:0crwdne2934203:0
    The spring may eject during this step if you pull with enough force to pry the buckle lock out. Keep your body to prevent the spring from flying too far. Also be mindful of which direction in the room it could fly to help you locate it sooner if it does eject out-of-sight.
    Booster Boards - crwdns2934203:0crwdne2934203:0
    Yes it's true, I've lost springs before when disassembling a Joycon, have a flashlight near you in case it rockets somewhere in the room.
    Alessandro De Marta -
    Note that if the buckle release is stiff or not returning to the correct position you may need to loosen this part out to give the correct resistance against the spring. This is more prevalent in non standard parts such as a metal Buckle lock. Lubrication may also help, such as WD40.
    William McGregor - crwdns2934203:0crwdne2934203:0
  8. Joy-Con Buckle Lock Replacement, Remove the buckle lock: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Joy-Con Buckle Lock Replacement, Remove the buckle lock: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Joy-Con Buckle Lock Replacement, Remove the buckle lock: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the buckle lock slightly out of its slot in the charging rail, just until the spring is exposed enough that you can grab it with tweezers.
    • Grab the buckle lock such that the tweezers are around both sides of the lock and holding the spring inside the lock.
    • When you pull the lock out, the spring can shoot out. Make sure you have a firm grip with the tweezers.
    • Pull the buckle lock out of its slot in the charging rail.
    • During reassembly, make sure to move the spring from the old lock to the new one.
    Upon reassembly of the buckle lock make sure the notch on the back is facing downwards.
    Kallon Lewallen - crwdns2934203:0crwdne2934203:0
    Dude, the shooting spring has to be a warning, PLEASE. I didn’t read the whole thing and it spring out once I lifted the buckle lock. I spent like 30 MINUTES finding it AND HAVING A MENTAL BREAKDOWN. I got so angry and once I found it it was AMAZING. So PLEASE AT ALL COSTS DO NOT LOSE IT PLEASE. I WAS GOING THROUGH THE STAGES OF GRIEF.
    Alexander Munoz Solis - crwdns2934203:0crwdne2934203:0
    ALSO be careful when screwing because I stripped the screw meaning the head of a screw has worn out from not pushing down enough and screwing it back in which ruined the screw. So BE VERY VERY CAREFUL, be sure you know everything you’re doing because if you don’t it’ll MESS you up.
    There used to be a photo and a procedure step showing the buckle lock orientation. Some important stuff got deleted here.
    Jim Nugent - crwdns2934203:0crwdne2934203:0
    Unbedingt darauf achten den richtigen Metallsicherungsriegel zu benutzen!
    Es gibt einen für den rechten Joycon und einen für den linken!
    Am besten genau mit dem alten aus Plastik vergleichen
    Peter Ullrich - crwdns2934203:0crwdne2934203:0
    don't tighten the metal buckle too tight. it stops the spring from working and the lock will not work
    sven coessens - crwdns2934203:0crwdne2934203:0
    Not sure if this only applies to the white OLED model, but for the left joycon that came with it, the buckle lock bracket was extremely difficult to remove. I had apply enough force that the bracket bent in the middle before it only popped out on the bottom side. Instead of trying to fully remove it, I just bent it out of the way, replaced the buckle lock, and bent it back in place.
    As others have said, some of the screws will very easily strip the plastic screw holes. For me, the short 2.5 mm screw for the charging rail stripped the plastic. Fortunately, the kit I purchased off amazon had some extra screws that were thicker, and were able to secure the rail.
    Otherwise, this was a great guide, and made the repair relatively painless.
    David H - crwdns2934203:0crwdne2934203:0
crwdns2935229:0142crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
213.675 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:038crwdne2947412:0
I tried to do this carefully, but I ended up removing the side rail ribbon cables and I had to disassemble the whole thing just to try to get to the inside of these babies. However it seems I messed up, and now I could use some help here. I don't want to lose my left Joy-Con.
Francisco Q. - crwdns2934203:0crwdne2934203:0
It seems rather strange.. Its pretty easy to reattach. All I have is a $@$*!& ph00 + y00 that stripped the screws so I broke the cover. Technically not my fault. I have done multiple reshells.
[deleted] -
I tryed to do this but the 2nd at the bottom would not come out now my buckle is chiped
TAQI HASSAN - crwdns2934203:0crwdne2934203:0
You mean the screws? Break off the shell! A perfect opportunity to put some clear ones :))
[deleted] -
I bought this kit of replacement metal buckles, and they work beautifully: https://www.amazon.com/gp/product/B07BDH...
This kit comes with four buckles, two for the left Joy Con, and two for the right. If you happen to have two sets (or plan to get a second set) of Joy Cons, a whopping $9.00 will set you up right.
I did have a bit of trouble replacing the metal cover that holds the buckle in place, but that was my own stupidity as I was trying to do this repair with insufficient light. Once I shed some light on the subject and I could see what I was doing, everything went back together smooth as silk. I replaced the buckles on both of my Joy Cons, and they’re both rock solid now.
itpurchasing - crwdns2934203:0crwdne2934203:0
I just bent that and refitted it. Force INDEED works.
[deleted] -
i held the latch in one hand and gently pulled it out and the spring went flying! never found it again. just printed a shorter one with a pen spring.
Kobedie - crwdns2934203:0crwdne2934203:0
I saw a recommendation to remove the latch while holding the controller inside a zip lock bag, i thought that was pretty clever :)
Martin Refseth -
Strange.. I did both and never had such issues. I just do this trick; first I cover the area, 2nd I remove the energy by when raising at pushing slowly grabbing back if you understand. Kinda hard to explain.
[deleted] -
pretty easy solution, don’t think it’s fixed the wobbly joycon issue much but I feel safer in the knowledge that these new buckles shouldn’t wear out as easily (if at all)
thegreatcraftings - crwdns2934203:0crwdne2934203:0
It really shouldn’t. In my opinion, metal to metal is more prone to break, maybe the rail or the joycon, but yeah feels much sturdier. So worth it.
[deleted] -
Be careful with the small metal screw that attaches joycon shell to the black rail thingie - it’s very easy to damage the screw hole when reassembling the joycon by not properly aligning it with the shell.
Alexandr Oleynikov - crwdns2934203:0crwdne2934203:0
Followed this guide. Was super easy. I replaced the locks in both my joycons in under 30 minutes.
NOTE: Often the metal locks come with some tools when you order them. IN my experience these are not high quality and can damage the screws. I recommend getting ifixit tools.
Gavin McFall - crwdns2934203:0crwdne2934203:0
RIP my springs. IDK how you’re meant to take the latches out but I definitely didn’t do it right. Good thing Aliexpress sells replacements lol
UnicornsOnLSD - crwdns2934203:0crwdne2934203:0
I bought a kit of metal buckles and put them in using this guide and it worked perfectly. Thanks! :)
Alex - crwdns2934203:0crwdne2934203:0
If you drop your switch on the side the joycons would probably be the first thing to break… sooo by making a joycon component that makes contact with the console out of metal, wouldn’t that mean the mechanism in the console itself would break in case of a drop?
BadamAdam - crwdns2934203:0crwdne2934203:0
That’s almost certainly why the JoyCon latches are plastic to begin with… they’re probably engineered to give way under extraordinary circumstances.
Jim Nugent -
I can tell you from experience the joycons are sturdy enough to survive serious stresses. My granddaughter somehow managed to remove one by snapping off the mounting screws on the rails. Not easy to do, as the rails are mounted directly on the metal midframe. So I got the honor of pioneering the midframe replacement guide here.
Jerry Wheeler -
I also bought this kit of replacement metal buckles, and they work beautifully: https://www.amazon.com/dp/B08HPD3Z46/ref...
This kit comes with four buckles, two for the left Joy Con, and two for the right. If you happen to have two sets (or plan to get a second set) of Joy Cons, a whopping price will set you up right.
Ray Rivera - crwdns2934203:0crwdne2934203:0
So my joycon is loose, Should I buy a spring or just need to replace the buckle lock only?
yusuf afandi - crwdns2934203:0crwdne2934203:0
If the button still goes in and out when pressed the spring should be fine. That said, if you see a good offer that includes both it never hurts to have spares since they are very easy to lose.
David R. -
I replaced the buckles in my joycons but now my left joycon slides off more easily (without pressing the button) than before? Can someone help me with this?
Rick Houtzager - crwdns2934203:0crwdne2934203:0
Are you sure you’ve put the right buckle in? The buckles for each joycon are different and if you put in the wrong one, it’ll be hard to slot in but easy to remove (the opposite of what you want). It happened to me on my first repair lol
David R. -
Worked like a charm! Well, expect for that &!%& spring, which I almost lost twice. :)
Alfy B - crwdns2934203:0crwdne2934203:0
I was able to do this easily, and it works great! However, I did have to do it twice because the first time I put in the wrong side of buckle. For other people like me who might forget that these things are different whether left or right, I think a big disclaimer at the beginning could help, something like “Make sure you are installing the correct side of buckle for your joycon” for example. Thanks for the guide!
David R. - crwdns2934203:0crwdne2934203:0
Can the people who changed the original latches, to the metal ones, tell me if this repair ended up damaging the console, because it is no longer plastic? Thank you.
JELLERET - crwdns2934203:0crwdne2934203:0
It does not damage the console. The metal latch only interfaces with the metal bars on the side of the screen, which are very robust.
Jim Nugent -
Echoing David R’s comment; I did the exact same thing. The buckles are sided, meaning one’s for the left side and the other’s for the right. Be sure you’ve got them in the correct position before you button it all up again or like me you’ll be disassembling them again so you can swap the buckles to their proper positions. Once they were on the correct sides, the controllers latch down nicely.
Jerry Wheeler - crwdns2934203:0crwdne2934203:0
It should be made aware that each buckle is shaped differently for each joycon. I bought the pack thinking I could fix both my left joycons, then I realized I had to disassemble one again.
Daniel Cital - crwdns2934203:0crwdne2934203:0
Thank you very much! I was wondering why my joy cons was still unlatching. Turns out I inverted the buckles during the installation.
Emmanuel Marleau -
Don't be like me, get attention to the spring if you don't want to be directly hit in the face by it :D
Damien M. - crwdns2934203:0crwdne2934203:0
When you're screwing the lock bracket screw back in, make sure not to screw it in too tight. I had it screwed in too tight when I installed the metal locks, and the lock wouldn't go back out properly after I pressed the release button.
Incineroar2296 - crwdns2934203:0crwdne2934203:0
You have to be careful at the end with the cabel of the SR, SL buttons. Mine got damaged while putting anything back together. As said in a other guide here its best to place it below the battery to prevent damage!
Paul Stachowiak - crwdns2934203:0crwdne2934203:0
Set up guide parts kit worked perfect fixed my kids Nintendo switch handles. Do not come off on their own anymore when you play OK pricing for the little parts charging as much as they did for shipping was a little excessive when you could’ve just put them in a padded envelope instead of a giant box Charge a little less for shipping but overall love that I fix it. Guides quality parts.
Dan Erickson - crwdns2934203:0crwdne2934203:0
Ces pièces conviennent elles à la switch oled?
Dodi - crwdns2934203:0crwdne2934203:0
Well. All was going good until I removed the spring. I actually got it free but as I was putting it back together it sprung away from me. I might be able to find it but I'm not counting on it. Can anyone advise what size spring it is so I can order a replacement? I saw numerous kits for the L/R buttons themselves that include springs but I'm not sure if they're the same. Amazon.com: iParto Replacement Screw Set with Spring for Nintendo Switch Console & Joycon Controller Springs Screws Replacement for Nintendo Switch Slide Rail Back Shell Philip's Triwing Head Screws(83pcs) : Video Games
Bibihabibi - crwdns2934203:0crwdne2934203:0
False alarm! I swept and found it. But I'm gonna leave this comment here in case others have lost their springs for good. If anyone has replacement suggestions, please feel free to post :)
Bibihabibi -
crwdns2936751:024crwdne2936751:0 65
crwdns2936753:07crwdne2936753:0 468
crwdns2936753:030crwdne2936753:0 2,301
crwdns2942667:0crwdne2942667:0 161,642
