JBL Go 4 Battery Replacement
  1. JBL Go 4 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Go 4 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Go 4 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening into the seam in between the grille and chassis, in the top corner opposite the strap.
    • Slide the tool along the edge of the housing until the grille releases.
    • Remove the grille.
    • Be sure that the battery has been drained completely before attempting this replacement.
  2. JBL Go 4 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 JBL Go 4 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 JBL Go 4 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool in the opposite corner, lifting carefully.
    • Slide the tool along the edge until the cover pops off.
    • Gently pull the housing up and to the side.
    • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
  3. JBL Go 4 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Go 4 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find the connection between the motherboard and the battery cable as labeled.
    • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
    • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
  4. JBL Go 4 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 JBL Go 4 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the Blue plastic pry tool on one of the sides that does not contain the wire.
    • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
    • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jackosn Caron
crwdns2935283:003/20/25crwdne2935283:0
255 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-1, Konn Spring 2025 crwdns2935289:0UMass Dartmouth, Team 4-1, Konn Spring 2025crwdne2935289:0
UMASSD-KONN-S25S4G1
crwdns2936753:030crwdne2936753:0 68
crwdns2942667:0crwdne2942667:0 141
