Use this guide to replace a worn-out or dead battery in your Huawei Watch GT.
For your safety, discharge your battery below 25% before disassembling your Huawei Watch GT. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Note: If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, take your watch off the charger and power it down.
Remove the watch band.
Remove the four Torx T3 screws (3.65 mm length).
Insert an opening pick into the notch at the top edge of the back cover.
Use the opening pick to pry up the back cover of the Huawei Watch GT.
Carefully fold the back cover assembly to the side of the two watch crowns.
Remove the Phillips #00 screw (2.9 mm length).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the metal shield which covers the flex connector of the distribution cable.
Use a spudger to pry up and disconnect the distribution cable connector.
Remove the two Phillips #00 screws (2.6 mm length).
Use a pair of tweezers to remove the metal shield which secures the battery connector.
At this step, what I assume is a proximity sensor also came away, and was attached to the underside of the metal plate. You can see it in the picture as a second square piece of metal to the right of the battery connector. This got in the way a little bit, but was just about able to remove (and reattach) the battery connector without trying to remove it from the plate.
Use a spudger to pry up and disconnect the battery flex connector.
Apply a heated iOpener to the rear side of the back cover assembly to loosen the adhesive which is holding the battery in place. Apply the iOpener for at least two minutes.
Insert a spudger between the top edge of the battery and the back cover.
Use the spudger to pry the battery out of its recess.
Remove the battery.
To reassemble your Huawei Watch GT follow these instructions in reverse.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
crwdns2935229:010crwdne2935229:0
Vielen Dank für die super ausführliche und sehr gut verständliche Anleitung. Habe keine 30 Minuten als absoluter Anfänger gebraucht, um den Akku der smartwatch zu tauschen 👍
I have a GT2 46mm . It looks a little different inside . Have you maybe instructions for these too?
Sehr schön, dass der Akku hier so einfach tauschen lässt. Meiner hält noch locker zwei Wochen durch, obwohl die Uhr schon einige Jahre auf dem Buckel hat.
Hi there. I would like to replace my battery at my gt3 42". Is the gt2 battery compatible? If not, where can i find one?
Thank you in advance
