Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement
  1. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the watch band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Unfasten the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.7 mm-long Torx T2 screws.
  3. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Insert a spudger: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Insert a spudger: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the edge of a spudger into the middle loudspeaker opening at the top edge of your watch.
  4. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The plastic clamps holding the back cover in place sit very tight and may require some force during the prying procedure.
    • Use the spudger to pry up the back cover assembly of your Huawei watch GT 2.
    • Don't try to remove the back cover assembly all the way yet, it's still connected to the motherboard.
  5. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully swing the back cover assembly open to an upward position.
  6. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Unfasten the screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.3 mm-long Phillips #00 screws.
  7. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the metal shield: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the metal shield: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezer to remove the metal shield covering the multi-purpose flex connector.
  8. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the flex cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the flex cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the multi-purpose flex connector.
  9. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Separate the back cover assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the back cover assembly from the watch case.
  10. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the main flex cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the main flex cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the main flex cable from the daughterboard.
  11. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the watch buttons: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Disconnect the watch buttons: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the watch buttons flex cable from the daughterboard.
  12. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Lift the daughterboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Lift the daughterboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift the right edge of the daughterboard off its socket.
  13. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the daughterboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement, Remove the daughterboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the daughterboard.
  14. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 2.3 mm-long Phillips #00 screws.
  15. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the metal shield covering the display connectors.
  16. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the left display flex cable.
  17. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the right display flex cable.
  18. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to carefully peel the watch button flex cable off the motherboard and fold it to the side.
  19. Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch GT 2 (46 mm) Motherboard & Daughterboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard.
crwdns2935229:014crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237,587 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,912crwdne2935297:0
Fine, the step 15 is quite difficult, because there is a pin into the U near the edge ... I did have to remove by the middle of the shield and pry It
Good job
Bruno Dujardin - crwdns2934203:0crwdne2934203:0
Tutoriel très bien détaillé, j'ai suivi toutes les étapes sans problème, merci pour cete aide précieuse.
Walter - crwdns2934203:0crwdne2934203:0
Many thanks, worked perfect for me. When prying open the watch, I put it face up on the table and placed the side with the speaker on 5 mm thick solid elevation. I then pressed down with a spudger using the middle speaker opening as insertion point.
Rolbinho - crwdns2934203:0crwdne2934203:0
Re-assembled - no issues. But the capacitive touch screen does not work now - what do I need to check? Everything appears to be back in its place.
Paul - crwdns2934203:0crwdne2934203:0
Dommage qu il n y ai pas d explication sur comment retirer la batterie😢… elle est soudée et donc pas remplaçable 😢 pas la peine de commander une batterie!
Matt MacFly - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 198
crwdns2942667:0crwdne2942667:0 13,122
