Huawei Watch 2 Opening Procedure
crwdns2942287:0crwdne2942287:0Use this guide to open your Huawei Watch 2 for repairs.
crwdns2944105:0crwdne2944105:0
Before starting repairs, take your watch off the charger and power it down.
Remove the four Torx T2 screws (4.5 mm length).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove the four plastic covers sitting next to the watch band holders.
Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
Use the opening tool to pry up the back cover of the Huawei Watch 2.
Carefully fold the back cover assembly to the opposite side of the two watch crowns.
Das Kabel ist festgeschraubt, benötigt wird ein Kreuzschlitz PH0.
To reassemble your Huawei Watch 2, follow these instructions in reverse order.
Tengo un problema con el reloj que no me esta haciendo las mediciones de la frecuencia cardiaca, como se cambia y donde se consigue ese sensor.
Gracias
Hi, any ideas if you can get the rubber membrane that goes behind the buttons? One of mine has worn away so had to swap them so the main button actually worked. Just bottom button now not working..
A carcaça do meu HUAWEI WATCH 2 quebrou aonde o pino da pulseira encaixa. Como conseguir uma para reposição? Grato.
