Huawei Watch 2 Battery Disconnect
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Huawei Watch 2 Battery Disconnect, Huawei Watch 2 Opening Procedure: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  2. Huawei Watch 2 Battery Disconnect: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four Torx T2 screws (4.5 mm length).
  3. Huawei Watch 2 Battery Disconnect: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the four plastic covers sitting next to the watch band holders.
  4. Huawei Watch 2 Battery Disconnect: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool into the gap between the back cover and the watch case at the bottom edge of the back cover.
    • Use the opening tool to pry up the back cover of the Huawei Watch 2.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  5. Huawei Watch 2 Battery Disconnect: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully fold the back cover assembly to the opposite side of the two watch crowns.
  6. Huawei Watch 2 Battery Disconnect, Huawei Watch 2 Battery Disconnect: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Phillips #00 screw (1.8 mm length).
  7. Huawei Watch 2 Battery Disconnect: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The heart rate sensor flex cable is attached to the metal shield which covers the battery connector. In order to avoid damage to the flex cable, only grab the metal shield on the bottom end where the Phillips screw was located.
    • Use a pair of tweezers to carefully remove the metal shield.
    • Remove the back cover assembly.
  8. Huawei Watch 2 Battery Disconnect: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Watch 2 Battery Disconnect: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
To reassemble your Huawei Watch 2 follow these instructions in reverse.
If possible, turn on your Huawei Watch 2 and test your repair before installing new adhesive underneath the battery and resealing.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235,233 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,909crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 199
