Use this guide to replace the display including the frame of your Huawei P9 Lite.
Also, take a look at the comments in the last two steps, they might come in handy depending on your replacement part.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
Remove the SIM card tray.
Disconnect the motherboard flex, the battery flex and the antenna cable.
Disconnect the display flex and the power and volume button cable.
Unplug the rear camera and the headphone jack.
Take the camera and the headphone jack out of their recesses.
Use a spudger to lift the motherboard carefully.
Remove the motherboard assembly.
Remove the rubber microphone cover and the earpiece speaker.
Remove the seven loudspeaker screws:
Three silver 2.9 mm Phillips #00
Four black 3.8 mm Phillips #00
Unplug the motherboard flex cable and disconnect the antenna cable.
Put both cables aside.
Now remove the daughter board.
Carefully peel off the contact of the vibration motor and take it out.
Also remove the lower microphone housing.
Insert a spudger or thin prying tool at a shallow angle to avoid bending the battery and pry it up from its adhesive.
crwdns2935229:039crwdne2935229:0
crwdns2947412:07crwdne2947412:0
I finished to replace the display yesterday and everything is perfect , thanks ifixit
husam faraj - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i replaced the display but the touchscreen doesn’t work
Michele Rappazzo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can try to reopen the phone and check if the flex cable is plugged in correctly or if any cable is ripped. If you can’t find any damage and all cables are plugged in correctly it’s possibly an issue with the replacement part.
Dominik Schnabelrauch - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hi, could you show how to replace the power button flex cable for a P9 Lite 2017? I would be greatful.
szaszisti - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my powerbutton connection is also missing…
lorenz_untersulzner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
