Huawei P8 Lite Display with Frame Replacement
Tobias Isakeit
crwdns2944107:0crwdnd2944107:0Tobias Isakeitcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 27, 2021crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937803:0crwdne2937803:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the Display assembly of your Huawei P8 Lite including the frame.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
  1. Huawei P8 Lite Display with Frame Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
    El celular no tiene ese tipo de tapa es como sellada, que debo hacer para saber si es por la pila que no agarra carga porxa
    maguada1106 - crwdns2934203:0crwdne2934203:0
    Wenn man langsam langsam arbeiten und vorsichtig ist, dann kein problem gibt es.Ich hätte keine Problemen zu öffnen.Das ist sehr leicht.
    Athanasios Georgopoulos - crwdns2934203:0crwdne2934203:0
  2. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
    The back panel is really really easy to brake, be careful :)
    romaingauthier - crwdns2934203:0crwdne2934203:0
    In my mobile phone the back panel was kept in place also from 2 strips of bi-adhesive tape. Pull gently to detach it to remove the panel.
    beppe modolo - crwdns2934203:0crwdne2934203:0
    right. it has 4 strips of adhesive tape
    Miguel Cretu -
    To facilitate the detachment of these double-sided tapes, I recommend heating with a hairdryer along the edges of the back cover, especially at the four corners.
    Nicola -
  3. Huawei P8 Lite Display with Frame Replacement, Loudspeaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
    The 4 screws wich hold down the lower part of the loudspeaker are Torx screws for me. But it's a French Huawei, doin' nothing like the others :)
    Christopher Hourlier - crwdns2934203:0crwdne2934203:0
    Die Wasserschadenindikatoren sitzen unter dem Mainboard. Bei den Aufklebern auf den TORX handelt es sich um Garantiesiegel.
    Andre Richter - crwdns2934203:0crwdne2934203:0
    Danke für den Hinweis, wurde so übernommen.
    Dominik Schnabelrauch -
    pour dévisser les vis cruciformes, quel taille de tournevis faut il? svp
    blan - crwdns2934203:0crwdne2934203:0
    Bonjour, il vous faut un tournevis ou un embout cruciforme #00 pour dévisser une vis cruciforme #00. Bonne réparation !
    Claire Miesch -
  4. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Display with Frame Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three Phillips #00 screws that hold the metal plate in place.
    • Remove the metal plate with a tweezer.
    • Unplug the battery flex connector with a spudger.
    Theese Screws are quite hard to remove…
    Jannik Peichl - crwdns2934203:0crwdne2934203:0
  7. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Torx T5 screws.
    • If there is a tamper evident sticker over your screws remove them to properly seat your driver.
    • Remove the five Phillips #00 screws.
  8. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pry off the plastic cover on the left side. The NFC antenna contacts might be slightly glued to the cover.
    • Then remove the top cover.
    An der Linken Plastikabdeckung sind die Kontakte dran geklebt!
    Luk_ S!lver - crwdns2934203:0crwdne2934203:0
    EN: The lateral small plastic piece is sticked to the flex of the side buttons. Take care
    Miguel Cretu - crwdns2934203:0crwdne2934203:0
  9. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM card and SD card trays.
    • Disconnect the three plug connectors and one ZIF connector.
    • Unlock the ZIF connector by lifting the small black plastic lever.
  10. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the volume and power button cable.
    • Take out the motherboard by lifting the bottom part first.
    • Pay attention to the cables, so they don't rip when staying stuck to the motherboard.
    • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If this thermal pad broke or is too dried out you might want to replace it with a new one.
  11. Huawei P8 Lite Display with Frame Replacement, Vibrator: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement, Vibrator: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the vibrator using a plastic opening tool.
    Il motore di vibrazione era incollato, ma telaio nuovo non era dotato di adesivo, cosa che ora non lo fa restare aderente.
    ancora - crwdns2934203:0crwdne2934203:0
  12. Huawei P8 Lite Display with Frame Replacement, Earpiece Speaker: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Lite Display with Frame Replacement, Earpiece Speaker: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift out the earpiece speaker of its recess with a tweezer.
    • It is glued in place with a mild adhesive, so you might need a little prying.
  13. Huawei P8 Lite Display with Frame Replacement, Display with Frame: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To avoid thermal runaway, including fire, do not bend or puncture the battery
    • Use the pull tab as seen here in the battery guide to remove one of the adhesives strips underneath the battery.
    • Use an opening pick or spudger to carefully pry the battery out the rest of the way.
    • Never reinstall a battery that has been bent or damaged during removal.
    La batterie colle si fort qu’il est impossible de l’enlever sans la plier!!
    Miniwhite - crwdns2934203:0crwdne2934203:0
    You could try and weaken the adhesive with >97% isopropyl alcohol. But yes, the battery is indeed firmly glued in place
    Tobias Isakeit -
  14. Huawei P8 Lite Display with Frame Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect your new display assembly and be sure to transfer any missing parts from the old one.
    Io ho dovuto anche prendere un sensore che mancava nel telaio fornito, sotto un altro, a fianco alla presa del Jack microfono
crwdns2935229:022crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
126 502 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01 140crwdne2935297:0
Hat super geklappt, danke! Zwei wichtige Dinge - NFC Antenne ist schwer von Batterie zu lösen- müsste gleich bei Akku mit beschrieben sein und bei Schritt 7 oder 11, dass man noch eine Steckverbindung lösen muss (verklebt!) und übertragen muss. Hat geklappt, danke Euch - eure tools sind super dazu!
allehoffis - crwdns2934203:0crwdne2934203:0
Danke allehoffis für dein Feedback. Freut mich, dass alle so weit geklappt hat. Ja, die NFC Antenne klebt da gut dran. Im separaten Akku-Guide ist darauf hingewiesen, dass sie schwer zu lösen ist. Vlt kommt hier auch noch eine Notiz dazu. In Schritt 6 wird die ZIF Verbindung getrennt. Ist es das, was du meinst mit “verklebt”?
Tobias Isakeit -
Hat alles super geklappt, danke für diese Anleitung
pt5878-631 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,589
