Huawei P10 Plus Charging board Replacement
  1. Huawei P10 Plus Charging board Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement, Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
    • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
    • To avoid damage to the display, do not push the tool too deeply into the phone.
  2. Huawei P10 Plus Charging board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
    • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
    • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
  3. Huawei P10 Plus Charging board Replacement, Unfasten the screw: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
  4. Huawei P10 Plus Charging board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Open the metal bracket that covers the display flex cable.
    • Use a spudger to disconnect the display flex cable.
    • Remove the display.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    Beim Zusammenbau kann man das Display gut mit flüssigem Handy-Klebegel einkleben z.B. T-8000 oder B-7000 (Zhanlida)
    Martin Aillaud - crwdns2934203:0crwdne2934203:0
    Where can I get a metal bracket and screw to buy?
    Shamoya Hurditt - crwdns2934203:0crwdne2934203:0
  5. Huawei P10 Plus Charging board Replacement, Midframe: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Plus Charging board Replacement, Midframe: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 13 Phillips #00 screws.
    • Remove the metal shield which holds down the display flex connector.
    Es sind nur 14 Kreuzschlitzschrauben #00, dabei ist die Kreuzschlitzschraube aus Schritt 3 bereits mitgezählt
    Ja, war bei mir genauso. Schade dass ich den Kommentar erst jetzt lese. Die zweite Schaube unten Links (von links) ist keine Schraube.
    Benjamin Fuß -
    Thanks for the note. We corrected it in the english version (our translators will soon catch up)
    Tobias Isakeit -
  6. Huawei P10 Plus Charging board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SIM card tray.
    • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
  7. Huawei P10 Plus Charging board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mid frame.
    • Disconnect the battery flex cable with a spudger.
  8. Huawei P10 Plus Charging board Replacement, Charging Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Plus Charging board Replacement, Charging Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three Phillips #000 screw.
    • Remove the metal shield covering the charging board with tweezers.
  9. Huawei P10 Plus Charging board Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the headphone jack flex cable, the loudspeaker flex cable and the main flex cable.
  10. Huawei P10 Plus Charging board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug both antenna cables with tweezers.
    • Carefully remove the headphone jack.
    • The headphone jack might be a little bit sticky. In case you're having trouble removing it, use an iOpener to loosen the adhesive.
  11. Huawei P10 Plus Charging board Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P10 Plus Charging board Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry off the charging board.
    • Remove the charging board.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
232,576 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,002crwdne2935297:0
Just a comment to say that when you remove the midframe, there’s a catch at the bottom of the phone which slots under other components, and this can make removal challenging
Ellie Milne-brown - crwdns2934203:0crwdne2934203:0
Can anyone help me? My new charging board doesn’t come with the heat shield as it does on the original old ones. Anyone knows how to remove the old ones to transfer it to the new ones?
mohammedsyahmi - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 3,499
