Use this guide to remove or replace the charging port and main flex cable assembly in the Huawei Mate 20 Pro.
Opening the Huawei Mate 20 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Remove the eight Phillips #00 screws (4.3 mm length).
Slide an opening pick under the black adhesive at the bottom left of the charging coil.
Carefully slide the opening from the left to the right side to loosen the adhesive.
Insert an opening pick under the bottom left corner of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Carefully fold the motherboard cover in the direction of the battery.
Use a spudger to pry up and disconnect the flash assembly flex cable.
Remove the motherboard cover including the NFC and charging coil.
Use a spudger to pry up and disconnect the battery connector.
Remove the three Phillips #00 screws (4.3 mm length).
If you want to remove or replace the loudspeaker, daughterboard, battery, or the OLED screen, remove the four Phillips #00 screws (4.3 mm length) which hold down the loudspeaker assembly.
Slide an opening pick under the top right corner of the daughterboard cover.
Use the opening pick to pry up the daughterboard cover. Remove the daughterboard cover with tweezers.
Use a Spudger to pry up and disconnect the interconnect flex cable from the daughterboard.
Use a Spudger to pry up and disconnect the interconnect flex cable from the motherboard.
Remove the interconnect flex cable.
Use a pair of tweezers to pry up and disconnect the connector of the black coax cable from the daughterboard.
Unroute the black coax cable from the metal clip on the daughterboard and fold it to the side.
Slide an opening underneath the top left corner of the loudspeaker cover.
Use the opening pick to pry up the loudspeaker and daughterboard assembly.
Remove the loudspeaker and daughterboard assembly.
Use a spudger to pry up and disconnect the main flex cable from the motherboard.
Use a spudger to pry up and disconnect the main flex cable from the left daughterboard.
Slide the flat end of a spudger under the right side of the main flex cable next to the charging port.
Use the spudger to pry up the main flex cable and to lever the charging port out of its recess.
Remove the main flex cable including the charging port by lifting it upwards and then pulling it in the direction of the motherboard.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
What width of the Tesa 61395 tape should you use for this phone?
Hi sar I'm using Huawei mate 20 pro my mobile phone slow charging
Replaced both battery and USB port. Went well but I cracked the corner of the back case, non issue because I’m using a case but be careful
