Use this guide to remove or replace the main flex cable in the Huawei Mate 20.
Opening the Huawei Mate 20 will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its splash-protection.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
Carefully fold the back cover to the right side of the phone assembly. Avoid tension to the fingerprint cable during this procedure.
Slide an opening pick under the bottom end of the black protective foil that covers the battery. Use the opening pick to loosen the adhesive that attaches the foil to the loudspeaker.
Use an opening pick to carefully pry the flash assembly off the motherboard cover and fold it into the direction of the battery. Avoid damaging the flash assembly flex cable.
Remove the eleven Phillips #00 screws (2.8 mm length).
Use the pointed end of a spudger to unhinge the motherboard cover from the small hook above the left side of the battery.
Slide an opening pick underneath the left side of the motherboard cover.
Use the opening pick to pry up the motherboard cover.
Remove the motherboard cover including the NFC and the black protective foil. Avoid damaging the flash assembly during this procedure.
Use a spudger to pry up and disconnect the fingerprint flex cable.
Use a spudger to pry up and disconnect the battery connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to pry up and disconnect the antenna cable.
Remove the four Phillips #00 screws (3.3 mm length).
Remove the two Phillips #00 screws (3.9 mm length).
Slide an opening pick under the loudspeaker cover where the main flex cable is located.
Slide the opening pick around the right side of the loudspeaker cover and start to pry it up. Avoid damaging the antenna cable during this step.
Work your way along the bottom edge of the loudspeaker cover into the direction of the charging port. Use the opening pick to pry up the loudspeaker during this procedure.
Use a spudger to pry up and disconnect the connector on the bottom end of the main flex cable.
Use a spudger to pry up and disconnect the connector on the upper end of the main flex cable.
Remove the main flex cable.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
