Use this guide to remove the motherboard assembly in the Huawei Honor 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Switch off your phone.
Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
You might need to reheat and reapply the iOpener several times during the rear glass removal.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction cup to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner.
Insert a second opening pick and slide it to the bottom left corner.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner.
Start to slide the tip of the opening pick from the bottom left corner along the side of the Huawei Honor 9 to cut the adhesive.
Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the top right corner of the phone.
Slide the opening pick along the right side to cut the remaining adhesive.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
Carefully lift the rear glass and remove it.
Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Remove the three Phillips #00 screws (3.45 mm length).
Remove the five Phillips #00 screws (2.9 mm length).
Carefully peel up the black thermal foil and remove it completely.
Remove the Phillips #00 screw that is located underneath the thermal foil at the bottom center of the motherboard.
Slide an opening pick under the right side of the motherboard shield.
Twist the opening pick sideways to release the clips that hold the shield in place.
Repeat the previous process and work your way around the motherboard shield until it pops out.
Use a spudger to pry up and disconnect the battery flex cable.
Remove the SIM card tray.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to pry up and disconnect the antenna coax cable located next to the battery connector.
Use a spudger to pry up and disconnect the interconnect flex cable.
Use a spudger to pry up and disconnect the display flex cable.
Use a spudger to pry up and disconnect the power and volume button flex cable.
Insert a spudger in the gap between the battery and the motherboard.
Carefully pry up the motherboard until you can get a good grip.
Make sure the previously unplugged connectors are out of the way and avoid damaging any close components while lifting the motherboard.
Remove the motherboard assembly.
