How to disconnect the Battery in the Huawei Watch GT 3
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. How to disconnect the Battery in the Huawei Watch GT 3, Remove the watch band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to disconnect the Battery in the Huawei Watch GT 3, Unfasten the back cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.7 mm-long Torx T2 screws securing the back cover.
  3. How to disconnect the Battery in the Huawei Watch GT 3, Pry up the rear panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Pry up the rear panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the edge of a spudger into the the loudspeaker opening at the bottom edge of your watch.
    • When prying up the back cover put a finger on top or the edge of it and hold it down. Too much force during the prying procedure may lead to popping off the back cover too quickly and tearing the rear panel assembly cable.
    • The plastic clamps holding the back cover in place sit very tight and may require some force during the prying procedure.
    • Use a spudger to pry up the rear panel of your Huawei watch GT 3.
    • Don't try to remove the back cover assembly all the way yet, it's still connected to the daughterboard.
  4. How to disconnect the Battery in the Huawei Watch GT 3, Swing open the rear panel assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Swing open the rear panel assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  5. How to disconnect the Battery in the Huawei Watch GT 3, Peel off the black tape: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Peel off the black tape: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to peel the black tape off the battery connector bracket.
  6. How to disconnect the Battery in the Huawei Watch GT 3, Unfasten the battery connector bracket screw: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the singe 2.2 mm-long Phillips screw securing the battery connector bracket.
  7. How to disconnect the Battery in the Huawei Watch GT 3, Remove the battery connector bracket: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Remove the battery connector bracket: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Remove the battery connector bracket: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the battery connector bracket.
    • The connector bracket is secured with a small metal hook next to the screw recess. This hook sits very tight und you might need to bend it a little to the side to remove the bracket.
  8. How to disconnect the Battery in the Huawei Watch GT 3, Disconnect the back cover assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Disconnect the back cover assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to disconnect the Battery in the Huawei Watch GT 3, Disconnect the back cover assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the rear panel assembly cable by prying the connector straight up from its socket.
    • Remove the rear panel assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237,300 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,725crwdne2935297:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 28
