How to Use a Pre-Cut Adhesive Sheet
Adam O'Camb
crwdns2944107:0crwdnd2944107:0Adam O'Cambcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:06crwdnd2944107:0crwdne2944107:0
crwdns2944111:0April 3, 2025crwdne2944111:0
crwdns2931287:045crwdne2931287:0 - crwdns2931291:02crwdne2931291:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Many replacement parts don’t come with custom-cut adhesive, but do come with a pre-cut adhesive card that has a variety of useful shapes cut into double-sided adhesive. This guide covers some of the most common device repair applications of the pre-cut adhesive card.
Follow the repair guide specific to your phone and part for replacement instructions. This guide only pertains to use of the pre-cut adhesive card included in some replacement kits.
crwdns2944105:0crwdne2944105:0
crwdns2943227:0crwdne2943227:0
  1. How to Use a Pre-Cut Adhesive Sheet, Surface Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Surface Preparation: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Surface Preparation: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by removing all the old adhesive, glass, and any other debris from all adhesion surfaces.
    • You can pull the adhesive off with tweezers or your fingers, roll it up on the tip of a spudger with a roll-and-pull motion, or scrape it off with the flat end of a spudger.
    • After removing most of the adhesive, scrape with the tip of a spudger to get small bits of adhesive out of tight spaces.
    • When working around a battery, be extremely careful not to accidentally puncture or bend the battery.
  2. How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a lint-free cloth (or coffee filter) with a bit of isopropyl alcohol, clean the adhesion surfaces. Use a Q-tip to clean smaller surfaces and corners.
    • For delicate surfaces that might be damaged by solvents use a 50/50 mix of water and isopropyl alcohol. Don't use any scented cleaners or anything that might leave a residue.
    • For best results, swipe your cleaning implement in one direction, not back and forth.
    • This will help remove any remaining adhesive residue and prep the surface for the new adhesive.
    • Wait at least a minute to let the solvent evaporate after cleaning.
    • The next four steps are example use cases for the pre-cut adhesive card. Evaluate what will work for your repair, and continue from step seven for application and installation.
  3. How to Use a Pre-Cut Adhesive Sheet, Rectangular Strips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Rectangular Strips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the narrow rectangular strips to secure narrow edges, like those on a display.
    • Use multiple long rectangular strips to adhere large components, like batteries.
  4. How to Use a Pre-Cut Adhesive Sheet, Card Borders: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Card Borders: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Card Borders: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can use the thin adhesive border of the card to secure small, rectangular components.
  5. How to Use a Pre-Cut Adhesive Sheet, Custom Shapes and Rectangles: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Custom Shapes and Rectangles: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Custom Shapes and Rectangles: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a small rectangle or an uncut part of the card to cut out odd shapes for small components.
    • Use an entire rectangle or two for small square or rectangular parts.
  6. How to Use a Pre-Cut Adhesive Sheet, Arcs: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the arc-shaped cutouts to secure circular components, place adhesive around fragile components that should not be adhered (like an NFC coil) or can tear, or to secure rounded corners.
  7. How to Use a Pre-Cut Adhesive Sheet, Application and Installation: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Application and Installation: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet, Application and Installation: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before applying any adhesive, make sure your replacement part fits, and that all connectors will connect without putting too much stress on their cables. If it is safe to do so, power on your device and verify that everything functions correctly. If everything works, power off the device and continue.
    • If anything does not function as expected, visit the Answers Forum for troubleshooting advice.
    • With the device powered off, apply the correct adhesive shape for your repair.
    • Avoid applying adhesive over ribbon cables, or delicate surfaces like NFC or wireless charging coils.
    • When applying adhesive strips, make sure to apply one end first, then use a finger or the flat end of a spudger to smooth the rest of the strip as you lay it down, squeezing out any air bubbles.
    • Use a pair of tweezers to peel the backing off the adhesive.
  8. How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Install the new part, taking care to position it correctly.
    • For parts with inflexible cables (like some batteries), connect the cable before installing it, and leave it connected during installation, to make sure the part stays positioned correctly.
  9. How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Use a Pre-Cut Adhesive Sheet: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply even pressure over the whole adhesion surface for at least 30 seconds to strengthen the bond.
    • For maximum bond strength on external-facing components (like displays and covers), you can leave the adhesive under pressure overnight.
    • Leaving the phone under a stack of books is a good way to do this—just make sure the books apply even pressure to the entire bond. You may need some kind of spacer to allow the books to lay flat.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
    Extremely well illustrated. This addendum to the Moto Z battery replacement procedure was very helpful and should be read in it’s entirety before re-assembly.
    Ed Parella - crwdns2934203:0crwdne2934203:0
Follow the guide associated with your device and part to complete your repair.
crwdns2935229:0120crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
210.710 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Ciao, per chiudere la cover posteriore, che larghezza di nastro adesivo consigli
William Micheli - crwdns2934203:0crwdne2934203:0
First, the ifixit kit was excellent. The linked instruction were very thorough and easy to follow. I was a bit nervous about attempting the battery replacement on my Moto G6…“with it’s nonreplaceable battery”, but I pulled if off without a hitch thanks to the kit and directions from ifixit. Now my phone is charging and working better than it has in a long time. Highly recommend these guys.
Wilton Thomas - crwdns2934203:0crwdne2934203:0
Das sind gute Tipps, hoffe das ich auch als Laie dies hin bekomme. Werde es mal ausprobieren mit den Klebefolien. Wird bestimmt sehr kniffelig.
Lg Emma
emma kuehn - crwdns2934203:0crwdne2934203:0
Sehr hilfreich zu den Tipps mit Folien. Es ist für dicke Finger etwas schwer handzuhaben aber dennoch machbar.
Grüße
Sinan
Sinan Kayan - crwdns2934203:0crwdne2934203:0
The guide is generally good, but it lacks the note in the end that you need do more actions to be able to put together the phone:
1) Carefully peel off the fingerprint sensor from back cover, make sure sticky bits still there
2) Connect fingerprint sensor to the frame of the phone
3) Place the sensor in its place (you'll see a tab there)
4) Re-place the back of the phone - it should click in on all sides and the fingerprint sensor will adhere back to its place
Also, beware VERY LOW QUALITY LCD replacements on Amazon. Terrible, horrible quality.
Giorgi - crwdns2934203:0crwdne2934203:0
What thickness tape for a Nintendo switch digitizer?
Joey Castelli - crwdns2934203:0crwdne2934203:0
I managed to replace my pixel 7 pro screen and it works! Two things I forgot to put the metal retaining clip over the electrical connection, hopefully it will stay connected until I get a new phone. I wasnt sure if the adhesive should be put on the back of the screen or on the phone first, I put it on the phone and it seemed to work okay, better instruction about the adhesive would be nice.
troy condit - crwdns2934203:0crwdne2934203:0
What I feel is missing is instructions on how to properly attach a phone screen - where exactly to apply the adhesive.
Coming from the manufacturer the screen is glued at it's circumference - is that where the adhesive tape should be appliied as well?
firubat - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 152
crwdns2936753:07crwdne2936753:0 1,158
crwdns2936753:030crwdne2936753:0 4,544
crwdns2942667:0crwdne2942667:0 234,135
