How to Splice Wire
crwdns2869540:0crwdne2869540:0: 36 B
50
427
1.755
36.142
crwdns2955950:0crwdne2955950:0: 2
crwdns2960004:02crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 27
crwdns2959974:027crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
How to Splice Wire
The purpose of this guide is to instruct users on how to effectively repair a broken wire, as they commonly become damaged. This guide will cover how to repair stranded wire and solid-core (single strand) wire.
Note: to efficiently complete the following guide, it's crucial to know how to strip wires. The following link can be used as a guide for wire stripping before continuing.
Stripping Wire: Wire Stripping
    1. How to Splice Wire, Prepare your work area: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Splice Wire, Prepare your work area: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Set your tools down on a clean, non-flammable surface.
      • Ensure that the work area is well-ventilated and clear of anything that can be damaged during soldering.
      • Attach a stripped wire end to each of the helping hands clips, facing the ends towards each other.
    2. How to Splice Wire: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Cut a piece of heat-shrink tubing such that it's 10-15 mm longer than one of the exposed wire ends.
      • Slip the heat shrink over one of the wires, making sure to move the heat shrink away from the soldering point as to avoid any burning.
    3. How to Splice Wire, Intermesh the wire strands: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Splice Wire, Intermesh the wire strands: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Splice Wire, Intermesh the wire strands: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • This step shows how to physically intermesh stranded wires together. This improves the physical properties of the joined wires.
      • Unravel all of the wire strands for both the wires, intermesh them, and then twist the strands together.
    4. How to Splice Wire, Heat up the wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      FixHub Smart Soldering Iron
      $79.95
      • Place the tip of a soldering iron against the exposed wires. You want to heat the wires hot enough such that they'll readily melt the solder.
      • Position the tip such that you maximize the wire surface area it touches.
    5. How to Splice Wire, Apply solder wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Splice Wire, Apply solder wire: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slowly feed solder wire into the heated wire. The wire strands should readily absorb the molten solder.
      • If the solder pools on top of the wire strands, the strands aren't hot enough to melt the solder. Try moving the soldering iron so that the tip touches more of the strands.
      • Feed solder wire along the exposed wire until everything is thinly coated.
      • Once the molten solder saturates the wire strands, allow the solder joint to cool down and solidify (2-3 minutes).
    6. How to Splice Wire, Cover the exposed solder joint: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Splice Wire, Cover the exposed solder joint: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Splice Wire, Cover the exposed solder joint: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the heat-shrink over the exposed solder joint so that it completely covers the joint and the surrounding insulation.
      • The heat-shrink acts as insulation for the wire.
      • Wave a heat source (lighter or heat gun) over the heat-shrink material to activate it. Apply heat until the heat-shrink has shrunk securely around the solder joint.
You have successfully soldered two wires together!
For more soldering tips and guides, click here.
crwdns2935229:027crwdne2935229:0
Justin N/A Nguyen
crwdns2935283:002/20/24crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
University of Arizona, Team 3-6, Cools Stephens Spring 2024 crwdns2935289:0University of Arizona, Team 3-6, Cools Stephens Spring 2024crwdne2935289:0
ARIZONA-COOLS STEPHENS-S24S3G6
crwdns2936751:024crwdne2936751:0 50
crwdns2936753:07crwdne2936753:0 427
crwdns2936753:030crwdne2936753:0 1,755
crwdns2959996:0crwdne2959996:0 36,142
