How to Shuck a WD Elements External Hard Drive
  1. How to Shuck a WD Elements External Hard Drive, Locate the enclosure clips: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Locate the enclosure clips: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure to turn off and unplug the drive prior to disassembly.
    • The external enclosure cover is attached to the vented frame with four plastic clips from the inside. Note their locations before moving on to the next step.
  2. How to Shuck a WD Elements External Hard Drive, Insert a Jimmy into the seam of the enclosure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Insert a Jimmy into the seam of the enclosure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a Jimmy into the seam between the frame and the cover on one side of the drive, roughly halfway between the top and bottom.
    • You may need to wiggle the Jimmy in order to slide it in between the frame and the cover.
  3. How to Shuck a WD Elements External Hard Drive, Release the bottom clip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Release the bottom clip: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Release the bottom clip: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the Jimmy inserted in between the frame and cover, pry the frame outward to release the bottom clip.
    • Take care not to pry too forcefully, as that may break the enclosure.
    • If you're having trouble releasing the clips, slide the Jimmy closer to the clip and try again.
  4. How to Shuck a WD Elements External Hard Drive, Release the top clip: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Release the top clip: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the Jimmy up along the seam and pry the frame outward to release the top plastic clip.
  5. How to Shuck a WD Elements External Hard Drive, Release the clips on the other side: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Release the clips on the other side: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat steps 2-4 on the other side of the enclosure.
  6. How to Shuck a WD Elements External Hard Drive, Remove the cover from the enclosure: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the cover from the enclosure: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the cover from the enclosure: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the cover straight off the frame to remove it.
  7. How to Shuck a WD Elements External Hard Drive, Remove the LED light guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the LED light guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the LED light guide out of the LED slot on the drive's controller board.
  8. How to Shuck a WD Elements External Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the end of the LED light guide and slide it completely out of the frame to remove it.
  9. How to Shuck a WD Elements External Hard Drive, Remove the hard drive from the frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the hard drive from the frame: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the hard drive from the frame: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands to push on the four rubber blocks in the corners to unseat the hard drive from the frame.
    • Slowly push one or two blocks out at a time until the hard drive is completely unseated from the frame.
    Wtf. How? This doesn’t work.
    Feddy Friender - crwdns2934203:0crwdne2934203:0
    Ok, got it, but these directions are terrible. You don’t want to push the blocks out, like the illustration and directions say, because they literally can’t be pushed out. They need to be lifted up while the plastic shell is manipulated until the drive is loosened.
  10. How to Shuck a WD Elements External Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hard drive from the frame.
  11. How to Shuck a WD Elements External Hard Drive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber blocks from the hard drive if they're still attached—some of them may have already fallen off when you removed the hard drive.
  12. How to Shuck a WD Elements External Hard Drive, Remove the controller board metal bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the controller board metal bracket: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the controller board metal bracket: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the 8.5 mm-long screw securing the small controller board metal bracket to the hard drive.
    • Remove the metal bracket.
  13. How to Shuck a WD Elements External Hard Drive, Remove the controller board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the controller board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Shuck a WD Elements External Hard Drive, Remove the controller board: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the 8.5 mm-long screw securing the controller board to the hard drive.
    • Slide the controller board straight off the end of the hard drive to remove it.
    • There will be a bit of resistance when removing this board, since it's connected to the hard drive's SATA and power connectors.
  14. How to Shuck a WD Elements External Hard Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Shuck a WD Elements External Hard Drive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
Be sure to keep the enclosure—as well as all the parts and screws that accompany it—until the warranty has expired. After that, take them to an R2 or e-Stewards certified recycler. You can also offer them to folks on r/DataHoarder to be reused.
To reassemble the drive and enclosure, follow these instructions in reverse order.
crwdns2935229:060crwdne2935229:0
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
39.249 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
crwdns2947412:016crwdne2947412:0
Can you recommend a Mac program for running a deep scan to check for bad sectors?
This article only gives two recommendations and they’re both for Windows :(
Martin - crwdns2934203:0crwdne2934203:0
Disk drill (not free but hey... works well)
JeanJean -
I have a question. Is it possible to take a similar drive but smaller capacity like this about and turn it into a portable drive from it having to have a power supply?
Louis Wilson - crwdns2934203:0crwdne2934203:0
It is not possible. The problem is that a 3.5” disk drive (as used in the Elements drive) needs 12 V as well as 5 V, and they need more power than a USB socket can typically deliver. 2.5” disk drives operate from just a 5 V supply, and, having smaller disks inside, they use less power to start up, so they can be run completely through USB.
Andrew Morton -
Hi Craig! My PC sees it as Local Disc (E:) and wants to format it. Can’t do that! Is there a workaround? This was due to a power surge and I think it was just the adaptor power supply that got damaged. Running W10Home21H1 on Lenovo DESKTOP-699CIMO. Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz 3.60 GHz 16,0GB 64bits Any ideas would be greatly appreciated! Cheers, Marco
Marco66 - crwdns2934203:0crwdne2934203:0
On Step 14, you see there are no screws to take the HDD cover off. How do you take the cover off the HDD to get inside?
Nathan - crwdns2934203:0crwdne2934203:0
lol + other characters to allow comment
Jerry Attric -
I have a WD element 4T and it will not power up. New cable and power adapter. It was stabilized in one spot for over a year, powered up just to store my movies. Plug it up after two weeks of none use and would not power up, no light inside. What can be done? My other storage drives work fine. By the way, you have the best directions on the web.
Tim Newton - crwdns2934203:0crwdne2934203:0
I just wrote you about WD Element, it is a 5.0TB Sata/64MB Cache, WD50EZRZ
WDBlue PC Hard Drive. It will not power up. I wonder if I can get a new USB controller board for it? I am only interested in getting information off of the hard drive. Can an "WEme USB 3.0 to SATA Converter Adapter for 2.5 3.5 Inch Hard Drive Disk SSD HDD" work to power it up to retrieve the Data?
Hey Tim, yeah so if you already tried a new power adapter, then it could be a bad controller board. If the drive is already shucked (or you don't mind shucking it), then you can get a SATA to USB adapter to see if the drive will boot up. That will at least rule out the USB controller board.
Craig Lloyd -
Very informative explenation wih clear pictures that show EXACLY in which direction to move the tool to safely detach the casing from the clips without breaking them, much better than most YouTube video's.
Only, I've used two old bank cards. That is i.m.o. much safer than using a metal knife or "Jimmy". With two plastic credit- or bank cards or two guitar picks it's almost impossible to damage the case.
Ruud Wilschut - crwdns2934203:0crwdne2934203:0
Thank you for the guide!
I found that I had a 3 TB Toshiba hdd lying around which I put in one of WD Elements enclosures I was about to recycle. Now I have a fully stacked NAS as well as an external hdd :)
And I'm keeping a controller board + wall wart to be used as simple usb-to-sata device.
Frida Mattias - crwdns2934203:0crwdne2934203:0
Hi.
Is possible on this box, change the HDD. For example. I have WD Elements to 4Tb and have another ( Seagate ) 12Tb and I thinking to change the HDD 4Tb for 12Tb using the same case.
Is possible?
Thanks a lot
Victor Santos - crwdns2934203:0crwdne2934203:0
Did it successfully with fairly limited experience of taking electronics apart (other than joycons a few times), didn't even break any clips. Worked fine for me installing it in a PC without taping over anything.
Jack Bailey - crwdns2934203:0crwdne2934203:0
Can I remove the drive and install in a new enclosure? My WD 8tb no longer mounts on my mac. I think it's probably the usb port or whatever communicates with the port.
Jim Fields - crwdns2934203:0crwdne2934203:0
I am in need of the board that is held on by 2 screws. One of the kids jammed something into it and destroyed the connector. I have taken the hard drive out and inserted it into a hard drive reader and everything is still there and reading properly. Please advise where or if I can find this board. Thank You in advance
Pat F. - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 58
crwdns2936753:07crwdne2936753:0 478
crwdns2936753:030crwdne2936753:0 1,851
crwdns2942667:0crwdne2942667:0 169,811
