How to Restore a Dried Out Marking Pen
  1. How to Restore a Dried Out Marking Pen, Soak the tip in isopropyl alcohol: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Restore a Dried Out Marking Pen, Soak the tip in isopropyl alcohol: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fill a cup with enough isopropyl alcohol for the marking pen's tip to be fully submerged.
    • Place the pen into the cup with the tip side down.
    • Keep the pen as upright as possible to prevent the alcohol from going around the side of the pen nib.
    • Wait 15 minutes for the alcohol to soak into the pen tip.
  2. How to Restore a Dried Out Marking Pen, Remove the alcohol: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Restore a Dried Out Marking Pen, Remove the alcohol: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Restore a Dried Out Marking Pen, Remove the alcohol: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $36.95
    • Remove the pen from the cup and wipe off any remaining alcohol from the pen tip.
    • On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see alcohol leaving the pen nib.
    • Rotate the pen while drawing to ensure all sides of the pen nib are exercised.
    • If no alcohol is coming out of the pen nib, repeat the previous step.
  3. How to Restore a Dried Out Marking Pen, Soak the tip in water: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Restore a Dried Out Marking Pen, Soak the tip in water: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fill a cup with enough water for the marking pen's tip to be fully submerged.
    • Keep the pen as upright as possible to prevent the water from going around the side of the pen nib.
    • Wait 30 minutes for the water to soak into the pen tip.
  4. How to Restore a Dried Out Marking Pen, Remove the water: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Restore a Dried Out Marking Pen, Remove the water: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Restore a Dried Out Marking Pen, Remove the water: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the pen from the cup and wipe off any remaining water from the pen tip.
    • On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see ink forming in solid lines.
    • Rotate the pen while drawing to ensure all sides of the pen tip are releasing ink.
    • If no ink is coming out of the pen nib, repeat the previous step.
  5. How to Restore a Dried Out Marking Pen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations! Your pen has been revived.
    Brand new pen turned up dry and this fix didn't work.
    Paul Nevin - crwdns2934203:0crwdne2934203:0
    My pen has been iffy for quite a while—not dried out, but writing poorly. One round each of isopropyl and water have got it working beautifully.
    Brad Compton - crwdns2934203:0crwdne2934203:0
For more electronics skills guides, click here.
crwdns2935229:011crwdne2935229:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
166.281 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.162crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Unfortunately this did not help for me.
Sven Alleblas - crwdns2934203:0crwdne2934203:0
This is such a great pen I wish I could find replacements.
lupinm - crwdns2934203:0crwdne2934203:0
Apparently this pen that comes with the FixMat cannot be purchased, but is covered by the lifetime warranty. Send an email to support@ifixit.com to get replacement pens.
P.S. It's called the iFixit Marking Pen
Andrew Chen -
Same for me, I repeated the guide 3 times, it didn't helped, I wish I could just open it and use a replacement, it's cheap to buy but I feel bad of throwing everything, and also the pen dries super fast I think I need to buy another one and just glue some metal plate to use with the I fix it magnetic mat
thematho - crwdns2934203:0crwdne2934203:0
See my reply above
Andrew Chen -
Echoing the consensus that this did not work for me - will be seeking warranty replacement.
Fevix - crwdns2934203:0crwdne2934203:0
Seems to have done the trick, thanks. It was a brand new pen and must've dried out on the shelf.
Further tip:
If you wrap a pair of tweezers around it, and lay the tweezers across the top of a glass, it's pretty easy to stand the pen perfectly upright, even if it's a short+wide glass.
Sam L. - crwdns2934203:0crwdne2934203:0
Update: the fix only lasted a few days. It's dried out again. The cap may have been slightly loose though (friction fit, not clicked into position).
Sam L. -
I received a replacement from ifixit wich is great but I ended up having the dame problem and this guide also using comments suggestions didn't work, I'm not going to request more replacement because I think it's a product fault, and I don't want to generate more waste If they make a new oen and sell separate I'll be happy to purchase
This worked for a few seconds, but then It just stopped, and wouldn't work afterwards. I attempted this fix 3 more times, to no avail. Will attempt to get a replacement.
AdamG - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 257
crwdns2942667:0crwdne2942667:0 6,788
