Use this guide to restore a dried out Marking Pen.
Note: You may have to repeat the procedure a few times depending on how dry your Marking Pen is.
Fill a cup with enough isopropyl alcohol for the marking pen's tip to be fully submerged.
Place the pen into the cup with the tip side down.
Wait 15 minutes for the alcohol to soak into the pen tip.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Remove the pen from the cup and wipe off any remaining alcohol from the pen tip.
On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see alcohol leaving the pen nib.
Fill a cup with enough water for the marking pen's tip to be fully submerged.
Wait 30 minutes for the water to soak into the pen tip.
Remove the pen from the cup and wipe off any remaining water from the pen tip.
On your FixMat, or another dry-erasable surface, draw the pen back and forth until you see ink forming in solid lines.
Congratulations! Your pen has been revived.
Brand new pen turned up dry and this fix didn't work.
My pen has been iffy for quite a while—not dried out, but writing poorly. One round each of isopropyl and water have got it working beautifully.
For more electronics skills guides, click here.
crwdns2935229:011crwdne2935229:0
crwdns2947412:010crwdne2947412:0
Unfortunately this did not help for me.
This is such a great pen I wish I could find replacements.
Apparently this pen that comes with the FixMat cannot be purchased, but is covered by the lifetime warranty. Send an email to support@ifixit.com to get replacement pens.
P.S. It's called the iFixit Marking Pen
Same for me, I repeated the guide 3 times, it didn't helped, I wish I could just open it and use a replacement, it's cheap to buy but I feel bad of throwing everything, and also the pen dries super fast I think I need to buy another one and just glue some metal plate to use with the I fix it magnetic mat
See my reply above
Echoing the consensus that this did not work for me - will be seeking warranty replacement.
Seems to have done the trick, thanks. It was a brand new pen and must've dried out on the shelf.
Further tip:
If you wrap a pair of tweezers around it, and lay the tweezers across the top of a glass, it's pretty easy to stand the pen perfectly upright, even if it's a short+wide glass.
Update: the fix only lasted a few days. It's dried out again. The cap may have been slightly loose though (friction fit, not clicked into position).
Sam L. -
I received a replacement from ifixit wich is great but I ended up having the dame problem and this guide also using comments suggestions didn't work, I'm not going to request more replacement because I think it's a product fault, and I don't want to generate more waste If they make a new oen and sell separate I'll be happy to purchase
This worked for a few seconds, but then It just stopped, and wouldn't work afterwards. I attempted this fix 3 more times, to no avail. Will attempt to get a replacement.
