How to Repair a Stuck Car Door Latch
  1. How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the car door that will not close, examine the door latch located near the handle on the side of the door.
    • The car door latch will be locked in a closed position.
    Tür ist im geschlossenen Zustand blockiert
    Hubert schaub - crwdns2934203:0crwdne2934203:0
  2. How to Repair a Stuck Car Door Latch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Stuck Car Door Latch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Stuck Car Door Latch: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position a screwdriver between the legs of the locked door latch.
    • You may use any size screwdriver that will fit between the latch.
  3. How to Repair a Stuck Car Door Latch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the exterior car door handle.
  4. How to Repair a Stuck Car Door Latch: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck Car Door Latch: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
    Vielen Dank!!! Sie haben mich heute gerettet und mir (Frau) einen Werkstattbesuch erspart. Ich umarme Sie!! 🥹
    F. E. - crwdns2934203:0crwdne2934203:0
  5. How to Repair a Stuck Car Door Latch: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Repair a Stuck Car Door Latch: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Repair a Stuck Car Door Latch: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the screwdriver to push the latch upwards into the final unlocked position.
    Thank you so much for your help
    mitv xiaomi - crwdns2934203:0crwdne2934203:0
  6. How to Repair a Stuck Car Door Latch: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Repair a Stuck Car Door Latch: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the car door to ensure the latch has been properly reset.
    Thank GOD for google! I didn’t know what to do. Very informative.
    Shahied Page - crwdns2934203:0crwdne2934203:0
    Merci énormément. Dieu merci j'ai pu débloquer ma portière bloquée ouverte à des centaines de kms de chez moi et sous la pluie!
    Badr - crwdns2934203:0crwdne2934203:0
    Bonjour !
    Bizarre mais de mon côté, le problème est inversé ; mon loquet reste en position déverrouillé et quand je ferme la portière, il ne redescends plus afin de garder la porte fermée! :/
    J’ai tenté un peu le même processus ici mais .. sans succès .!
    Mélanie Caron - crwdns2934203:0crwdne2934203:0
    Au top merci pour le tuto👍
    Portière déverrouillée en moins de une minutes 💪
    Ahlame - crwdns2934203:0crwdne2934203:0
    hasn't worked, the latch won't stay up. Any other suggestions!!
    Hazel Kitchener - crwdns2934203:0crwdne2934203:0
    My door was frozen and wouldn't close and flopped open. Couldn't drive it like that. But thanks for this advice and with wd 40, and pulling the exterior handle, and pushing the latch, the door is OK now.
    Bill Welch - crwdns2934203:0crwdne2934203:0
    Très bon tuto et très bien imagé. Merci.
    André Vanhaudenard - crwdns2934203:0crwdne2934203:0
    Extraordinaire ! Merci beaucoup, tu viens de sauver ma matinée !
    Serge-Eric Junior NDONGO - crwdns2934203:0crwdne2934203:0
    I have a Toyota sienna 2004 car is really supper good run but MY left door torque screw 3 EA missing du to door glass repairing . please how can i found that bolts . hole Calgary Canada store I run but not at found . please give me idea how to get . this is my number +15879687809
    hari prasad aryal - crwdns2934203:0crwdne2934203:0
crwdns2935229:017crwdne2935229:0
Kennedy Coleman
crwdns2935283:004/29/20crwdne2935283:0
601 crwdns2915208:0crwdne2915208:0
UW Tacoma, Team S1-G30, Cardinal Spring 2020 crwdns2935289:0UW Tacoma, Team S1-G30, Cardinal Spring 2020crwdne2935289:0
UWT-CARDINAL-S20S1G30
crwdns2947412:018crwdne2947412:0
Thanks a lot, you have saved me from one !&&* of a problem!
dee Knight - crwdns2934203:0crwdne2934203:0
This helped me so much!! Thank you!!!
Jasmine Roman - crwdns2934203:0crwdne2934203:0
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Bill Smith - crwdns2934203:0crwdne2934203:0
Thank you so much! I figured it out because of this post!
Sharan Sahota - crwdns2934203:0crwdne2934203:0
I love this solution. It literally just saved me. Thank you soo much.
Edith Turkson - crwdns2934203:0crwdne2934203:0
YES! I tried following other guides/videos and was still struggling, but you noting to lift the handle made all the difference. Thank you so much!
dlgornan - crwdns2934203:0crwdne2934203:0
Was washing me uncle’s car when i just decided to fiddle with the inside lock with the key, who knew it'd make me spend 30 minutes out in the finger nibbling cold trying to use the same key to unfiddle what i just fiddled. Just happened to open google to pull an exterior wachama-call-it and then refiddle that key.
Oluwaseun Ajifowobaje - crwdns2934203:0crwdne2934203:0
Thank you so much. It was so easy. In my mind, I was already thinking I was going to have to call a tow truck, have it towed, and get a rental car. The directions are clear and concise. It took all of 4 seconds after I read the instructions.
kyellowtooth - crwdns2934203:0crwdne2934203:0
Not really helpful if you have to manually do this literally every time you want to get in and out of the car, which is the situation I’m stuck in right now…
Chrisanna Hibbitts - crwdns2934203:0crwdne2934203:0
hi....use a metal nail file if you have one or something similar ( or the tip of a key.... the manual lock type) if possible....i know not ideal but it's better than nothing if you're stuck somewhere
wjoh5v9 -
and ladies if you are somewhere where you haven't got access to a flathead screwdriver....a metal nail file will also help
wjoh5v9 - crwdns2934203:0crwdne2934203:0
Selbes problem aber andersherum…Tür lässt sich nicht öffnen wegen verschobenen Schloss…lösung?
julian.herber - crwdns2934203:0crwdne2934203:0
Helped a lot. My brother did something to the latch and it got stuck. If I didn’t find this, he would’ve been crying 🤣 Thank you so much for the help!
Little_Tree 31 - crwdns2934203:0crwdne2934203:0
But what if it does it every time?? What’s the part called? Can someone change it themselves or does it have to go to a shop. I can change a clutch, brakes, spark plugs all the filters and I can read and follow directions. Plus Kia has this awesome online manual year make model specific unlike rhe old books so I’m thinking I got this and if not dukes of hazard style here we come. Probably break a leg trying to jump out the window of my sorento though.
Natasha Long - crwdns2934203:0crwdne2934203:0
Merci bien vous m'avez sauvé.
Rachid Rabiou - crwdns2934203:0crwdne2934203:0
How do you repair the pushed in lock on a rear passenger door of a 2017 Chevy Impala premier is in the lock position
Tyrone Spurlin - crwdns2934203:0crwdne2934203:0
Merci avec vos explications j’ai réparé encore merci
Lysdav - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 154
crwdns2936753:07crwdne2936753:0 1,131
crwdns2936753:030crwdne2936753:0 4,981
crwdns2942667:0crwdne2942667:0 176,551
