If a car door suddenly will not close, it may be due to a stuck car door latch. Sometimes a latch may become stuck if someone accidentally knocked it into a locked position while the door was open. On many newer cars, simply pulling the interior or exterior door handle may reset the latch, but in cases where that is not enough, this guide will describe how to manually reset the latch.
On the car door that will not close, examine the door latch located near the handle on the side of the door.
Position a screwdriver between the legs of the locked door latch.
While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
Vielen Dank!!! Sie haben mich heute gerettet und mir (Frau) einen Werkstattbesuch erspart. Ich umarme Sie!! 🥹
Use the screwdriver to push the latch upwards into the final unlocked position.
Close the car door to ensure the latch has been properly reset.
Thank GOD for google! I didn’t know what to do. Very informative.
Du bist mein Held!
Merci beaucoup !
Merci énormément. Dieu merci j'ai pu débloquer ma portière bloquée ouverte à des centaines de kms de chez moi et sous la pluie!
Bonjour !
Bizarre mais de mon côté, le problème est inversé ; mon loquet reste en position déverrouillé et quand je ferme la portière, il ne redescends plus afin de garder la porte fermée! :/
J’ai tenté un peu le même processus ici mais .. sans succès .!
Au top merci pour le tuto👍
Portière déverrouillée en moins de une minutes 💪
hasn't worked, the latch won't stay up. Any other suggestions!!
My door was frozen and wouldn't close and flopped open. Couldn't drive it like that. But thanks for this advice and with wd 40, and pulling the exterior handle, and pushing the latch, the door is OK now.
Très bon tuto et très bien imagé. Merci.
Extraordinaire ! Merci beaucoup, tu viens de sauver ma matinée !
I have a Toyota sienna 2004 car is really supper good run but MY left door torque screw 3 EA missing du to door glass repairing . please how can i found that bolts . hole Calgary Canada store I run but not at found . please give me idea how to get . this is my number +15879687809
crwdns2935229:018crwdne2935229:0
crwdns2947412:021crwdne2947412:0
Thanks a lot, you have saved me from one !&&* of a problem!
This helped me so much!! Thank you!!!
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Thank you so much! I figured it out because of this post!
I love this solution. It literally just saved me. Thank you soo much.
YES! I tried following other guides/videos and was still struggling, but you noting to lift the handle made all the difference. Thank you so much!
Was washing me uncle’s car when i just decided to fiddle with the inside lock with the key, who knew it'd make me spend 30 minutes out in the finger nibbling cold trying to use the same key to unfiddle what i just fiddled. Just happened to open google to pull an exterior wachama-call-it and then refiddle that key.
Thank you so much. It was so easy. In my mind, I was already thinking I was going to have to call a tow truck, have it towed, and get a rental car. The directions are clear and concise. It took all of 4 seconds after I read the instructions.
Not really helpful if you have to manually do this literally every time you want to get in and out of the car, which is the situation I’m stuck in right now…
hi....use a metal nail file if you have one or something similar ( or the tip of a key.... the manual lock type) if possible....i know not ideal but it's better than nothing if you're stuck somewhere
wjoh5v9 -
and ladies if you are somewhere where you haven't got access to a flathead screwdriver....a metal nail file will also help
Selbes problem aber andersherum…Tür lässt sich nicht öffnen wegen verschobenen Schloss…lösung?
Helped a lot. My brother did something to the latch and it got stuck. If I didn’t find this, he would’ve been crying 🤣 Thank you so much for the help!
But what if it does it every time?? What’s the part called? Can someone change it themselves or does it have to go to a shop. I can change a clutch, brakes, spark plugs all the filters and I can read and follow directions. Plus Kia has this awesome online manual year make model specific unlike rhe old books so I’m thinking I got this and if not dukes of hazard style here we come. Probably break a leg trying to jump out the window of my sorento though.
Merci bien vous m'avez sauvé.
How do you repair the pushed in lock on a rear passenger door of a 2017 Chevy Impala premier is in the lock position
Merci avec vos explications j’ai réparé encore merci
What if the door is stuck closed I think the latch has fallen due to lose crews
Bonjour
Merci beaucoup très gentil
Bonjour 👋
Merci beaucoup
Tür ist im geschlossenen Zustand blockiert
Hubert schaub - crwdns2934203:0crwdne2934203:0
Pero si el error persiste? Como se hace para que no vuelva a suceder?
Roger Emilio Paizano Herrera - crwdns2934203:0crwdne2934203:0
