Use this guide to open up and clean dust and debris out of the fan, grilles, or vents of a PlayStation 4.
If your console is loud, overheating, or underperforming, it may have built-up dust in the cooling fan, heatsink, or main vents.
If your PS4 lives in a TV cabinet with limited airflow, consider opening the door while gaming or moving it out to open air. If your PS4 is on the ground, it may suck in extra dust, dirt, or hair and limit its ability to keep cool.
Eventually, you may need to reapply thermal paste to keep temperatures under control for optimal performance. Read how to do that here.
To fully disassemble your console and remove the fan, follow this guide.
Flip your PS4 upside-down with the back side facing towards you.
Use a pair of tweezers to remove the sticker in the center of the back of the PS4, exposing the first screw.
Remove the two stickers at the outer edges, exposing two more screws.
Remove the three 7.2 mm-long TR8 Torx security screws on the back of the PS4.
Use your thumbs to lift the lower case up and off the PS4.
crwdns2935267:0crwdne2935267:0Small Needle Nose Pliers$6.99
Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
Remove three 9.7 mm-long TR8 Torx security screws.
Remove two 41 mm-long Phillips screws and brackets.
Lift the power supply straight up and out of the PS4.
How do you remove the battery wires? I’ve personally been wiggling it to no effect, is there a certain way i have to pull it out, and should i pull it out of the power supply or the console?
Retirar en vertical, derecho hacia arriba. Sino puedes doblar uno de los tornillos largos
Just got done with this part. It was a struggle for me to disconnect the cable from the PSupply side. It was easier for me to carefully remove the power supply first, using the HDD cover to lift the Power Supply in place and removing the l cable from the Motherboard side. Go slow with your fingers to wiggle it out slowly, when you have enough plastic from the cable casing expose, gently use pliers to wiggle it free. Try hard not to deform the plastic wire casing.
crwdns2935267:0crwdne2935267:0Dust Blower$18.99
Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
Use a small dust blower or light compressed air to blow remaining dust off of the fan.
If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
crwdns2935267:0crwdne2935267:0Microfiber Cleaning Cloths$3.99
Use a clean rag or microfiber cloth to wipe the inside of the case clean.
crwdns2935267:0crwdne2935267:0Anti-Static Brush$2.99
Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas and off of the rear vents.
Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
If you can see dust buildup in the heatsink, dislodge debris with a brush and use a dust blower to blow it clean.
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 4 Answers community for help.
crwdns2935229:019crwdne2935229:0
Thanks for the help now my ps4 runs quetly you Are a plessing.🙂
eu limpei a minha e nao voltou a ligar, o que que eu faço
quem souber de algo ajude pfvr
