How to Open and Clean a PlayStation 4
  1. How to Open and Clean a PlayStation 4, Flip over the PS4: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your PS4 upside-down with the back side facing towards you.
  2. How to Open and Clean a PlayStation 4, Remove the rear stickers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open and Clean a PlayStation 4, Remove the rear stickers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open and Clean a PlayStation 4, Remove the rear stickers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Stickers cover the screws securing the PS4's outer case.
    • Use a pair of tweezers to remove the sticker in the center of the back of the PS4, exposing the first screw.
    • Remove the two stickers at the outer edges, exposing two more screws.
  3. How to Open and Clean a PlayStation 4, Remove the rear case screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 7.2 mm-long TR8 Torx security screws on the back of the PS4.
    The screws that are holding it in are T-10
    Paytonb88 - crwdns2934203:0crwdne2934203:0
  4. How to Open and Clean a PlayStation 4, Remove the lower case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open and Clean a PlayStation 4, Remove the lower case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumbs to lift the lower case up and off the PS4.
    • In addition to the three rear screws, the lower case is held in place by plastic clips. You may need to use significant force to release the lower case.
    Only one side, "the one over the disc insert" comes off. Then there is another 2 screws under the plate, holding the opposite side on
  5. How to Open and Clean a PlayStation 4, Disconnect the power supply: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open and Clean a PlayStation 4, Disconnect the power supply: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Small Needle Nose Pliers
    $6.99
    • Use a pair of tweezers to pull the power supply cable straight out to disconnect the power supply unit from the motherboard.
    • Depending on the age of your console, this cable might be very firmly connected. If it feels stuck, don't pull on the cables themselves with much force.
    • Use your fingers to grab the white connector head, and wiggle or "walk" the connector out of its socket to disconnect it.
    • In extreme cases, you might need to use needle nose pliers to get a good grip on the connector.
    • Go slow: pulling on the cables themselves might rip them out of the connector.
  6. How to Open and Clean a PlayStation 4, Remove the power supply unit: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open and Clean a PlayStation 4, Remove the power supply unit: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 9.7 mm-long TR8 Torx security screws.
    • Remove two 41 mm-long Phillips screws and brackets.
  7. How to Open and Clean a PlayStation 4: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open and Clean a PlayStation 4: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open and Clean a PlayStation 4: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to remove it.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
    How do you remove the battery wires? I’ve personally been wiggling it to no effect, is there a certain way i have to pull it out, and should i pull it out of the power supply or the console?
    Tubby - crwdns2934203:0crwdne2934203:0
    Retirar en vertical, derecho hacia arriba. Sino puedes doblar uno de los tornillos largos
    FabianCampos - crwdns2934203:0crwdne2934203:0
    Just got done with this part. It was a struggle for me to disconnect the cable from the PSupply side. It was easier for me to carefully remove the power supply first, using the HDD cover to lift the Power Supply in place and removing the l cable from the Motherboard side. Go slow with your fingers to wiggle it out slowly, when you have enough plastic from the cable casing expose, gently use pliers to wiggle it free. Try hard not to deform the plastic wire casing.
    Justin Tang - crwdns2934203:0crwdne2934203:0
  8. How to Open and Clean a PlayStation 4, Clean the fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open and Clean a PlayStation 4, Clean the fan: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Dust Blower
    $18.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off of the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
  9. How to Open and Clean a PlayStation 4, Clean the case: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
  10. How to Open and Clean a PlayStation 4, Clean vents and hard-to-reach areas: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Anti-Static Brush
    $2.99
    • Depending on how dirty your console is, you might need to use a soft bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas and off of the rear vents.
    • Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
  11. How to Open and Clean a PlayStation 4, Clean the heatsink: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open and Clean a PlayStation 4, Clean the heatsink: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The PS4 draws air through the heatsink fins, and they may clog with dust and debris over time.
    • If you can see dust buildup in the heatsink, dislodge debris with a brush and use a dust blower to blow it clean.
    • Remember: use this time to clean any other dirty internal surfaces before you seal your console back up. Happy gaming!
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 4 Answers community for help.
crwdns2935229:022crwdne2935229:0
Carsten Frauenheim
146 207 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 892crwdne2935297:0
Thanks for the help now my ps4 runs quetly you Are a plessing.🙂
Martin1234 - crwdns2934203:0crwdne2934203:0
eu limpei a minha e nao voltou a ligar, o que que eu faço
David Almeida - crwdns2934203:0crwdne2934203:0
quem souber de algo ajude pfvr
David Almeida -
crwdns2936751:024crwdne2936751:0 128
crwdns2936753:07crwdne2936753:0 1,093
crwdns2936753:030crwdne2936753:0 4,405
crwdns2942667:0crwdne2942667:0 36,176
