How to Open Your Apple Watch Ultra
  1. How to Open Your Apple Watch Ultra, Power down your watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra, Power down your watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Drain your watch battery below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Take your watch off the charger and power it down.
    • If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
  2. How to Open Your Apple Watch Ultra, Safety details: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Safety details: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Safety details: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Because the gap between the screen assembly and frame is so small, a thin metal tool is needed to pry the screen up. Read the following warnings before you start disassembly:
    • Protect your fingers by keeping them completely clear of the front end of your tool. You can protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the iFlex to slip and cut you, or damage the watch.
    • Wear eye protection. The glass may break, sending pieces flying.
    • Attach or remove the watch bands as needed to provide more control as you make repairs.
  3. How to Open Your Apple Watch Ultra, Soften the screen adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the screen for two minutes to loosen the adhesive underneath.
    • You can also use a hair dryer, heat gun, or hot plate, but be careful not to overheat the watch—the screen and internal battery are both susceptible to heat damage.
  4. How to Open Your Apple Watch Ultra, Insert the iFlex: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Insert the iFlex: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Insert the iFlex: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the tip of an iFlex along the edge opposite the Digital Crown and position it in the seam between the screen and the frame.
    • Press the iFlex firmly straight down into the gap.
    • The gap between the screen and the frame is very small, and it makes inserting the iFlex difficult. Don't force the iFlex in, or you risk damaging the screen. If you're having trouble, apply more heat and try again.
  5. How to Open Your Apple Watch Ultra, Pry up the screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra, Pry up the screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the iFlex to pry up the screen.
    • The adhesive requires time and constant force to loosen—it probably won't loosen from the initial pry. Reheat the screen and keep applying constant force until the adhesive loosens.
  6. How to Open Your Apple Watch Ultra, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap you created between the screen and the frame.
    • Remove the iFlex.
  7. How to Open Your Apple Watch Ultra, Slice the adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Slice the adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Slice the adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of the opening pick less than 2 mm to prevent damaging the antenna pin.
    • Slide the opening pick around the top left corner and along the top edge of the watch to slice the screen adhesive.
  8. How to Open Your Apple Watch Ultra: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the top right corner and stop just before the Digital Crown.
  9. How to Open Your Apple Watch Ultra: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the seam at the top left corner of the watch.
    • Slide the pick along the Action button edge to slice the adhesive.
  10. How to Open Your Apple Watch Ultra: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the bottom left corner and along the bottom edge of the watch to slice the screen adhesive.
  11. How to Open Your Apple Watch Ultra: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick around the bottom right corner and stop before you reach the side button.
  12. How to Open Your Apple Watch Ultra, Lift the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Apple Watch Ultra, Lift the screen: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the opening pick between the screen and frame at the opposite edge of the Digital Crown.
    • Pry up the screen until you can get a good grip with your fingers.
    • Don't try to remove the screen all the way yet. It's still connected to the watch body.
  13. How to Open Your Apple Watch Ultra, Swing open the screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Swing open the screen: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Apple Watch Ultra, Swing open the screen: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to strain the screen cable when you swing open the screen.
    • Lift the screen up and carefully pull it towards the Digital Crown.
    • Swing the screen open to an upward position.
To reassemble your Apple Watch Ultra, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
247,305 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023,741crwdne2935297:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 197
crwdns2942667:0crwdne2942667:0 5,863
