How to Iron a Waterproof Jacket
  1. How to Iron a Waterproof Jacket, Prepare the jacket: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unzip your clean jacket and slide one half over your ironing board or towel-covered surface.
    • You only want to iron through one layer of the jacket at a time. Ironing through two layers can create creases in the bottom layer.
    • Flatten your jacket with your hands.
  2. How to Iron a Waterproof Jacket, Set up the iron: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Iron a Waterproof Jacket, Set up the iron: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Iron a Waterproof Jacket, Set up the iron: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the iron to its lowest heat setting, below 230 °F.
    • Turn off the steam function. Steam can damage the fabric and the DWR coating. If you can't turn off the steam function on your iron, drain the water chamber completely.
  3. How to Iron a Waterproof Jacket, Protect the jacket: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Iron a Waterproof Jacket, Protect the jacket: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  4. How to Iron a Waterproof Jacket, Iron the jacket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Iron a Waterproof Jacket, Iron the jacket: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Iron in one smooth stroke, running parallel to the zipper.
    • Only iron in one direction, don't go back and forth or you risk creating creases. Change directions only when you move to a new section of the jacket.
    • Don't press down. Let the heat and weight of the iron do the work.
    • Keep the iron moving continuously to avoid melting or burning the fabric.
  5. How to Iron a Waterproof Jacket, Check your progress: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Iron a Waterproof Jacket, Check your progress: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Iron a Waterproof Jacket, Check your progress: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the towel and inspect the jacket.
    • If the fabric looks unchanged, increase the heat slightly and try again.
    • If the area looks smooth, move on to the next section.
    • To fully reactivate the DWR coating, heat must make contact with every part of the jacket. Go slowly and work in small, manageable sections to ensure even coverage.
    • Be extra careful around tight or curved areas like hoods, cuffs, and sleeves.
    • For the sleeves, slide a tailor’s ham, sleeve board, or folded towel inside the sleeve to separate the two sides.
    • Continue repositioning the jacket and repeating the ironing process until the entire surface has been treated.
    • Don't forget to turn off the iron when you're finished.
crwdns2935229:023crwdne2935229:0
Clara Redwood
crwdns2935283:011/12/24crwdne2935283:0
2.543 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
Patagonia crwdns2935289:0Patagoniacrwdne2935289:0
Community
crwdns2931471:017crwdne2931471:0
crwdns2935297:0168crwdne2935297:0
crwdns2947412:017crwdne2947412:0
Thank you, good advice for younger generation who have clue.
keirakeith26 - crwdns2934203:0crwdne2934203:0
Thank you - good reminder for the older generation who have lost their marbles
Swag McYolo - crwdns2934203:0crwdne2934203:0
Thank you- good reminder for the baby boomer middle aged who voted for Brexit and haven't got a clue.
fixxysugar - crwdns2934203:0crwdne2934203:0
謝謝,對於說中文的外國人來說,這是一個很好的建議,即使他們沒有失去彈珠,他們也沒有投棄權,但仍然沒有任何線索。
艾爾伯特愛因斯坦 - crwdns2934203:0crwdne2934203:0
I hope the non-English comment is also in the same form as the first 3.
Eva - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 57
crwdns2936753:07crwdne2936753:0 519
crwdns2936753:030crwdne2936753:0 1,623
crwdns2942667:0crwdne2942667:0 195,913
