How to Install a Heatsink on an M.2 SSD
  1. How to Install a Heatsink on an M.2 SSD, Prepare the first thermal pad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The heatsink uses thermal pads to dissipate heat from either side of the blade SSD. The thermal pads may come with plastic liners on each side, so make sure all are removed before use.
    • Use a pair of tweezers to peel one side of protective film away from one of the thermal pads.
  2. How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Install the first thermal pad: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the exposed side of the thermal pad with the bottom tray section of the heatsink assembly.
    • Lay the thermal pad down so it covers the tray evenly.
    • Use your finger to lightly press down on the thermal pad to adhere it to the surface.
  3. How to Install a Heatsink on an M.2 SSD, Prepare the second thermal pad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to peel one side of protective film away from the remaining thermal pad.
  4. How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Install the second thermal pad: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the exposed side of the thermal pad with the top section of the heatsink.
    • Lay the thermal pad down so it covers the top section evenly.
  5. How to Install a Heatsink on an M.2 SSD, Remove the bottom thermal pad liner: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the plastic liner from the thermal pad in the tray.
    • The thermal pad might lift up from the tray as the liner is removed—this is normal. Use your finger to keep the pad in the tray.
  6. How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Lay the SSD in the tray: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the M.2 SSD into the tray, the side with the most chips facing up.
    • Make sure the SSD is centered in the tray. The tray shouldn't cover the contacts or the screw cutout.
    Are you meant to remove the sticker from the SSD or can you leave it attached? Has anyone done tests on if it effects thermal performance?
    samot - crwdns2934203:0crwdne2934203:0
    It's fine to leave the sticker on the SSD -- most of the time, they're designed to spread heat.
    Carsten Frauenheim -
  7. How to Install a Heatsink on an M.2 SSD, Remove the top thermal pad liner: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the plastic liner from the thermal pad on the heatsink's top section.
    • The thermal pad might lift up from the heatsink as the liner is removed—this is normal. Use your finger to keep the pad in place.
  8. How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Install a Heatsink on an M.2 SSD, Snap the heatsink in place: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the top heatsink section over the SSD and the tray.
    • Firmly press the two halves together. You'll feel it "snap" into place.
  9. How to Install a Heatsink on an M.2 SSD, Check the alignment: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For the SSD to fit in a desktop PC or a PlayStation 5, the heatsink needs to be centered on the SSD.
    • Make sure that the heatsink is close to the screw cutout but doesn't overhang it.
    • If you're having trouble installing your SSD, you may have to slightly adjust the heatsink's position.
    • Use your fingers to slide the SSD between the two halves of the heatsink assembly until fitment is just right.
Installation didn’t go as planned? Check out our Computer Hardware Answers community or PlayStation 5 Answers community for troubleshooting help.
Carsten Frauenheim
145.103 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.281crwdne2935297:0
If your SSD has a big "warranty void if removed" sticker over the chips, do you have to remove it? Or can you stick the thermal pad over that sticker?
shamino - crwdns2934203:0crwdne2934203:0
You can leave the sticker on the SSD! Just make sure to remove any adhesive liners on the thermal pad.
I just bought predator gm7000 ssd with heatsink. The ssd only come with one thermal pad on top to be use with the heatsink. Do i need to get another thermal pad for bottom?
afiqtobi9 - crwdns2934203:0crwdne2934203:0
This is just a generic guide, so not every step applies to every situation. I've checked your mentioned SSD and it comes with a custom heatsink for it, which means you don't need another one. Thermal pads only help if they're touching a surface (i.e. a metal sheet) for heat transfer. Since this isn't how yours is build/installed, a second pad would be basically pointless. Hope this helps :)
Kongoduff -
crwdns2936751:024crwdne2936751:0 65
crwdns2936753:07crwdne2936753:0 389
crwdns2936753:030crwdne2936753:0 2,215
crwdns2942667:0crwdne2942667:0 80,976
