Use this guide to force restart your Samsung Galaxy Watch.
Push and hold the lower button for at least 7 seconds.
Let go of the button when you see the watch restart.
crwdns2947412:013crwdne2947412:0
If I have done the hold button 7 seconds & it still dont come on then what?
That's what I want to know also
Me too. My watch won't come on either.
I suppose all commenters above have tried to charge the watch over night to make sure the battery is not completely depleted.
You could try and restart WHILE it is charging or even just placed on the charger without being plugged into the wall.
I dropped my watch off the counter and it's just keeps showing rebooting it won't let me restart watch or activate it from my phone.
Did you check if maybe the button is stuck and forces it to restart?
Thanks very much!
I've tried multiple rebooting techniques and none have worked, I also went into galaxy wearable app on phone to reset but it won't let me into general settings to do reset, the app also tells me it's not connected but how am I to connect if it don't turn on?
im having the exact same issues, nothing is working
Mine is having the same issue. After swimming it did not shut off the water mode, no matter what. Tried to reset it but the power button did not work. Have opened it to look inside and try to find something easy to fix but it´s hard to find the faulty part/component. So, without knowing which spare part to buy and replace it I guess it´s end of game for this piece of hardware. Not worth it taking to servicing since spare parts for this 5 years old watch are not easily available and/or might be as expensive as new watch.
Not restart my watch
battery replacement possible, if yes where can I got the battery
It does not restart
My smart watch got problem with cant power on
kok chua - crwdns2934203:0crwdne2934203:0
me too. I have charged and tried to restart by power button down but hasn't come back on. Any other ideas?
PJ Cav - crwdns2934203:0crwdne2934203:0
Hola, si mantenéis pulsado el botón de encendido hasta que salga rebooting. En ese momento pulsar repetidamente el botón de encendido hasta que salga la opción de recovery y pulsais nuevamente el boton de encendido 1 o 2 segundos para seleccionarlo.
Fernando Rivero - crwdns2934203:0crwdne2934203:0
J'ai réinitialiser ma montre touche retour en arrière ne fonctionne pas
NADIR BENMAMAR - crwdns2934203:0crwdne2934203:0
