How to Force Restart an iPhone 5
crwdns2942287:0crwdne2942287:0Use this guide to force restart your iPhone 5 when it is frozen and not responding. This procedure clears out your iPhone's RAM, which becomes fragmented over time. Force restarts are very simple and require no tools.
Press and hold the Home button.
While holding the Home button, press and hold the Sleep/Wake button.
Continue holding both buttons for about 10 seconds, until the Apple logo appears.
What if it's still on the Apple logo screen
Rebort my iPhone 5 but still frozen 3 hours after
Sorry (for me) this doesn’t work on my iPhone 5. Using this method toggles my iPhone between the solid black screen and the Apple logo on a black screen — that’s all I get. I cannot get anything else. If (after I use this method and get a solid black screen) I just press the sleep/wake button, the Apple logo once again appears and stays. That’s it.
My iPhone the button at the top is pushed down to far I cant use it
thnanks buddy
I tried this also and just got the Apple logo for about 20 seconds and then the screen goes black.
I replaced the battery to see if this was the problem , but still does not come on.. Any suggestions
madmomma- Sept. 16 2018
After I reset my phone I does the same thing. It goes back to the page that says hello
Doesn’t work for me either. Apple logo never appears.
My phone keeps going from the apple logo to a black screen and sometimes it goes to a red screen and it keeps flashing. I tried to do this method and it didn't work. What should I do?
crwdns2935229:0266crwdne2935229:0
crwdns2947412:045crwdne2947412:0
What happens if this does not work with an IPhone with a white screen
https://www.youtube.com/watch?v=aSG0Moj5... this video fix iphone white apple logo screen and iphone stuck.
Li Mike -
it means, that you have white iphone :D
does this work with water damaged phone?
Worked great with my seemingly dead iPhone 5s
it helps me a lot thanks
not working after holding for 30 seconds
Worked like a charm. Is this magic, or what.
Omg its not working......WHY MEE!!
worked great, thanks for your help.
iPhone is spinning and won't reboot how can I fix the problem
Sorted.....thanks
thanks a lot man!
if my iphone Sleep/Wake button not working , still got another way to restart my phone?
Exact same problem here :(
Same here. Any solutions?
Now how can I force shutdown the phone without it starting back up? The screen/digitizer is broken, so I can't do the normal power-off and the two-button procedure is a reboot - not power-off.
hey man its really helpful thanks a lot for this imp step !!!
My phone shut off and would not turn back on. Worked Perfect. Thank YOU!
what if the sleep/wake button isnt working?
Its help me a lot..... Thank u so muchhh
Searching ...... appears on my phone at the left corner. It's seem to be stuck. Calls continue to fail, What should I do?
The Home button of the iPhone 5s is not working, I can know how it will work.
My phone has frozen and my home button is broken, cant get notifications on my phone as they dont appear on the screen or allow me to swipe down. Can’t log in to icloud and manually restart it because you need to enter a verification code, and i cant get it.
i need iphone 7 gold display (my no 00919746186927) please help me
apple 5c touch not working
help me
It doesn't work with me.. It show me the apple mark and shut down immediately again... Please help me to wake it up again
My menu button isn’t working. How do I force restart
It did not work
my iphone s5 icloud locked ho remove
My iPhone is iPhone disabled Connect to itune problem
Just completed this repair with an iPhone 5 whose battery had swollen to the point that the screen detached from the case. This actually made the repair easier, as removing the screen and battery had basically already been done for me by the device itself. I got the battery and Ifixit toolkit, but it turned out I already owned the tools needed. So, extras, I guess.
And then what when that doesn’t work?
My IPhone 5s is disabled, how do I get it to restart it again and work properly? It was working fine yesterday, but now its messed up!
Thanks a lot for your information. iphone 5s is good .
its not working
My home button was broken any other ways?
Will this work when the screen is stuck on connect to iTunes ?
I tried the hold…it does not work… is there any other way to get the data from my dead iphone5?
My 5s iPhone is dead, only the apple figure comes out and does nothing else. I already let it discharge the battery and charged it again but without any positive results.
This troubleshooting page might help you: iPhone is Charging but Won't Turn On
My Iphone 5 Screen is Freezing and sometimes the Icons are not moving and sometimes when to click on for typing, suddenly it will type automatically on his screen? What seems to be the problem with the Display that works alone typing anything? Ha ha… it looks like there is something stock on the LCD my guest? As you can see this Iphone 5 proves to me a lot for a very long time of usages. I have done the Force to Restart but nothing is changing? What could be the problem? Will I have to Replace my LCD or else?
Sorry didnot work, I believe the iPhone is a brick. Thanks for your help.
Tony
I did the same thing but its not working i tried unplugging and re plugging the screen but still didnt work it restore it to still didnt work it took it to a phone repair man he tried with new screen still didnt work soo do you know how to fix it?
How to reatores the Iphone5 from zero and It says inativo..
What if the Sleep/Wake button ain't working? any alternative?
iman.casssidy - crwdns2934203:0crwdne2934203:0
