How to Fix Joy-Con Drift Without Disassembly
Weijie Chen
crwdns2944107:0crwdnd2944107:0Weijie Chencrwdnd2944107:0crwdnd2944107:0crwdnd2944107:07crwdnd2944107:0crwdne2944107:0
crwdns2944111:0N'w 14, 2024crwdne2944111:0
crwdns2931287:015crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
This guide shows how to fix Joy-Con drift for the Nintendo Switch Joy-Cons.
Joy-Con drift is when the Nintendo Switch thinks that the analog stick (also known as the joystick, controller stick, or thumbstick) of the Joy-Con is moving, but it isn't.
Joy-Con drift may occur as you use the Joy-Cons over time from dust and debris building up. You do not need to disassemble the Joy-Con for this repair. In addition, this guide will not corrode any parts of your Joy-Con controller.
Please note this repair is temporary and will last only a certain amount of time.
  1. How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly, How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the black round button on the back of the Joy-Con, then slide it forward to remove.
  2. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the 404B contact cleaner and insert the tube into the nozzle.
  3. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the Joy Stick to the side and hold.
  4. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift the rubber ring under the Joy Stick, and hold.
  5. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Aim the contact cleaner's nozzle at the gap and spray 404B contact cleaner once or twice.
  6. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the Joy Stick for 30 seconds to allow full penetration of the liquid inside.
  7. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wait 10 minutes for the liquid to dry completely.
  8. How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Joy-Con Drift Without Disassembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the Joy-Con back into the Switch to test the Joy-Con.
    • Navigate to System Settings > Controllers and Sensors > Calibrate Control Sticks.
    • Follow the on-screen prompts on your Switch.
Enjoy your Joy-Con being able to work properly again!
crwdns2935229:032crwdne2935229:0
Weijie Chen
crwdns2935283:001/16/22crwdne2935283:0
1 037 crwdns2915208:0crwdne2915208:0
Process says it requires compressed air then goes on to use contact cleaner instead.
Mike Burr - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 119
crwdns2936753:07crwdne2936753:0 703
crwdns2936753:030crwdne2936753:0 3,779
crwdns2942667:0crwdne2942667:0 78,242
