How to Apply Liquid Metal in a PlayStation 5
crwdns2942287:0crwdne2942287:0Use this guide to apply liquid metal in your PlayStation 5. You can also use this guide to re-spread existing liquid metal.
Your PS5 has an Accelerated Processing Unit (APU), which uses liquid metal TIM (thermal interface material) instead of traditional thermal paste to transfer heat. Over time, the liquid metal can oxidize or become unevenly spread on the APU and heatsink, especially if the PS5 stood upright for long periods of time. If the liquid metal has oxidized, it'll look dried-out or cracked and will need to be cleaned and replaced. If it's just unevenly covered, you can re-spread it evenly across the surfaces of the APU and heatsink.
Your liquid metal might need to be replaced if your PS5 is overheating, throttling, or having overall poor performance. These signs could also mean a faulty or dirty fan. To remove your fan for cleaning, follow this guide.
crwdns2944105:0crwdne2944105:0
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
Lift straight up to remove the stand.
Insert the screw into the cubby on the bottom of the stand.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers or your fingernail to remove the cap from the cubby.
Use your finger to press the cap into the screw hole.
Twist the stand counterclockwise to close the cubby.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Do you guys sell the stand
Steps 1 through 6 are just about removing the stand, correct? Storing the screw and all that is just about being neat and tidy?
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
While lifting up the corner, slide the faceplate towards the bottom of the device.
Remove the right faceplate.
I recommend doing both covers at this time, to avoid hassle later. Skip to step 38, then come back here
Why remove the other cover? You only need to remove the cover shown in order to access the disc drive.
Insert the flat end of a spudger underneath the grille and into the gap above the fan.
Lift up with the spudger to pry the grille away from the case.
Lift the grille away from the case to remove it.
During reassembling:
There is a little flat pin in each end, they need to go into the console
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
Two 23.3 mm-long screws
One 11.4 mm-long screw
One 31 mm-long screw
My ps5 seems to have tiny black caps over each screw. My spudger can’t get them off I see no other way to move forward besides breaking the shroud
wrong side, take the cover off the other side
The 31 mm-long screw just wont budge! do I turn that one counter-clockwise or clockwise? someone please help!
counter clockwise to remove
I damaged the 23.3mm on the bottom right next to fan connector. Is there any replacements? Can't seem to find any 23.3mm t8 screw anywhere online
I used a t8 for all of them and had no problem removing, except for that bottom right screw
Is there any replacement screws you can buy for the fan? I slightly damage 23.3mm screw.
My PS5 has TX8 (security Torx bit) screws on my fan shroud and all the case screws. A normal Torx driver won’t work you need the one with the hole in the middle of the bit driver.
Why does my ps5 have 3 different screws? 2 are the same then 2 other ones? Why?
Does anyone know the thread pitch of these screws? I just bought a used PS5 and the screws are missing. The fan has been glued in. Can't make this up.....
Ci sono viti di ricambio?
Dove posso trovarle?
Ho guardato dappertutto e non se ne trovano
Sind mit den Massen die dicke oder die Länge gemeint
Thickness I'm sure
9h works also or I HAD a mix up
Thickness I'm sure
Lift the fan shroud straight up to remove it.
Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
Use the spudger to peel up the wire cover until you can grip it with your fingers.
Some PS5's have a smaller sticky cover instead , remove it in this step
Use your fingers to peel off the wire cover.
Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
Normally I don't have an issue with this type of connector, but I couldn't get it out with my fingers. I ended up using two plastic pry tools, one on each side of the connector, like a claw game.
So weird you just posted this yesterday. I am doing this right now and your comment helped so much, I couldn’t get mine out at all before I tried that.
Lift the fan up and out of the case to remove it.
Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
Use your finger to slide the SSD cover towards the top of the device to unclip it from the case.
Remove the SSD cover.
It is unnecessary to remove the SSD screw and cover for power supply replacement.
The only thing you can do without removing the ssd cover and screw is remove the fan.
Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
For some PS5's, the optical drive connector is still covered in this step. Proceed up to step 22, then you will be able to access these connecters. The connectors will be running across the heatsink visible from step 24.
Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the optical drive.
Use a pair of tweezers to remove the tamper-evident sticker covering the remaining case screw.
Use a T8 Torx driver to remove the eleven screws securing the case:
Six 18.6 mm-long screws
Two 43.2 mm-long screws
One 7.3 mm-long screw
Lift the case straight up to remove it.
Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
Lift the optical drive away from the device to remove it.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
Lift the wire's connector straight up to disconnect it from the motherboard.
Repeat for the black Wi-Fi antenna wire.
Black and white antennas are reversed, black should go on RB and white on RW
It looks like some models of PS5 lack these antenna wires. My PS5 only has Power Supply antennas, which are in the next step.
Can confirm, on a PS5 I got for repair, there are only antenna connectors that are in the next step. The antenna connectors of this step are physically absent from the PCB. There are only 2 coaxial connectors in total, not 4. From the image it seems the PCB routing is slightly different (my board with missing connectors seems to use PCB traces as antennae given trace shapes)
Use a pair of tweezers to grip the black or blue power supply antenna wire at its metal base, as close to the connector as possible.
Repeat for the white power supply antenna wire.
Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
Remove the antenna wires from underneath the sticker.
Press the white sticker back down onto the top shield plate so it can be reused.
Repeat the previous step to peel back the four remaining stickers.
Use a pair of tweezers to peel back the white sticker holding the LED ribbon cable to the heat sink.
Remove the LED ribbon cable from underneath the sticker.
Press the white sticker back down onto the heat sink so it can be reused.
Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
Forty-one 7.3 mm-long screws
One 43.2 mm-long screw
Your image already has the long black screw removed from the left hand side half way down.
You should add a step for this screw for people re-assembling.
I second this! I had an extra long screw when I was done, it was likely this. This is one of the screws that reach down to the PSU
I believe that this was an unintentional oversight in the guide, as I cannot find any guide that mentions removing this screw. I have made an edit to this guide to clarify that final screw must also be removed, hoping it is approved and published!
I can’t see how removing 41 of these 7.3mm screws to replace the power supply. None of them hold the power supply to the board. Waste of time.
The reason why is because you need to remove the top shield plate to get to the usb ribbon cable.
Some PS5's have a removable cover for the USB board (step 36). If this is your situation, then I think removing this entire plate is unnecessary for removing the PSU (80% sure, I haven't exactly tried.)
Lift the top shield plate off of the motherboard to remove it.
Unnecessary step to replace power supply.
Debatable, removing the top shield makes it much more comfortable to remove the USB ribbon cable.
I would say it's required since there's no way to get to the metal release otherwise
The grey rubber came off in some spots, what do I use to replace it? It attaches to cylinder things (opposite side of power supply) which then attaches to a copper bus.
That's thermal paste, it's recommended to keep it all on there. If you lost some paste, check on Google for the proper thermal paste for the PS5
Use your finger to depress the metal locking tab on the USB board cable's board connector.
With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
What happens if this cable disconnects from the front?
Use a Phillips screwdriver to remove the 11 mm‑long SSD screw.
Use a Phillips screwdriver to remove the two 11.8 mm‑long APU tension bracket screws.
Use a TR8 Torx security screwdriver to remove the two remaining 7.3 mm‑long main board screws.
Lift and remove both APU brackets from the board.
Put the bracket with plastic arms on first so the pegs go into their cutouts.
Then, put the metal bracket onto the plastic one so they're perpendicular and the screw holes line up.
Gently lift the edge of the motherboard with the large cutout to partially separate it from the bottom shield plate.
With the board lifted, insert the flat end of a spudger between the board and the bottom shield plate and gently twist to separate them. Work your way around the perimeter of the board.
Insert the flat end of a spudger between the board and the lower shield plate, by the two parallel solder joints near the corner with the power button.
Twist the spudger to lift the two prongs under the board out of their socket.
Remove the main board, flip it over, and carefully lay it on a clean work surface, so the APU is facing up.
Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
Carefully flip the board over so the APU is on the bottom, making sure no liquid metal spills.
Keep the board level and lower it into place.
crwdns2935267:0crwdne2935267:0Dispensing Syringe Kit 9 pieces$8.99
If you have a disposable syringe, you can use it to suck up any large pools of liquid metal. Don't use the syringe containing your new liquid metal.
Starting with the heatsink: apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to a cotton swab and carefully clean up all of the liquid metal from the heatsink surface.
Use the same cleaning process to thoroughly clean up all of the liquid metal residue.
Let the heatsink dry completely.
Just as you did for the heatsink, clean and remove all of the old liquid metal and its residue from the APU.
This is a good point to replace any thermal pads on the bottom of the main board, if necessary. The pads might be stuck to both the bottom shield plate and the main board.
Une petite photo de ce qu'on entend par "tampons thermiques", histoire de pouvoir éventuellement acheter un change sans avoir à désosser sa propre console pour voir à quoi ça ressemble, serait bienvenue :D
Apply a small drop of liquid metal to the heatsink (not the APU)—about the size of a small matchstick head.
Use the spreader that came with your liquid metal or a new cotton swab to lightly push down on and evenly spread the liquid metal across the entire surface.
If there's excess liquid metal anywhere, use the syringe to suck it back up.
Use the same cotton swab to spread a thin layer of liquid metal evenly onto the APU. If you need more liquid metal, lightly dab the cotton swab on the heatsink to transfer some, or apply a very small drop from the syringe.
To reassemble your device, follow these instructions in reverse order, starting with this step.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
crwdns2935229:010crwdne2935229:0
Una domanda se posso:
Come mai su tutti i video tutorial spargono il metallo liquido sia sul dissipatore che sull'apu?
Quanti gr di liquido metallico necessitano in totale?
