Hoover Power Path Pro Advanced Suction Motor Replacement
  1. Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement, Brush Roller: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
    I have to rollers on mine.
    poco24 - crwdns2934203:0crwdne2934203:0
    I have two rollers on mine.
  2. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
  3. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
    Removing long roller brush is not required and can’t be done at this point because of belt.
    frank wilbanks - crwdns2934203:0crwdne2934203:0
    Yuck!! I want to clean the transparent curved surface. I can’t get at it.
    jmariep - crwdns2934203:0crwdne2934203:0
  4. Hoover Power Path Pro Advanced Suction Motor Replacement, Belt: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    The 8 screws are not all shown here. There are arrows with numbers pointing at all of them on the dark plastic. The two shown here in red are labelled on the clear plastic.
    jschaudt - crwdns2934203:0crwdne2934203:0
  5. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the red handle shown to remove the front suction unit from the cleaner.
  6. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the Phillips #2 screw at the bottom of the hose.
  7. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down on the handle release button. Pull and disconnect the edge of the top cover on the side of the handle release button.
    • Repeat the above step for the "On/Off" button.
    • When pulling the handle release button, make sure the top of the cleaner does not fall.
    What a load off bollocks following this instruction broke my Hoover
    Stewart Hogg - crwdns2934203:0crwdne2934203:0
    I followed your instructions and after pressing the release button and the start button erasing the clips broke my Hoover as it's not as easy as you
    It is impossible to remove the top cover...!!!!! I'm breaking the vacuum!!! you need to give better instructions!!!
    Zulma Ossandon - crwdns2934203:0crwdne2934203:0
    This guy forgot about removing the entire underside first...also snapped off a plastic screw casing. Bollocks is correct. There should be 10 or 11 steps. Take off the bottom casing, about 7 screws I believe.
    Jane Blevin - crwdns2934203:0crwdne2934203:0
  8. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently grab the belt and pry it off from the rollers.
  9. Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement, Suction Motor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew two screws using Phillips #2 screwdriver.
    • Detach grey piece from vacuum.
  10. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew four screws using a Phillips 2 screwdriver.
    How to remove electric on/off switch cover is not mentioned. To keep from breaking cover by prying, drill about a 3/8” hole through plastic cover lined up with partially hidden screw and remove screw. To drill a smoother holed use reverse (CCW).
  11. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out of base of vacuum.
  12. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip vacuum over and unscrew three screws with a Phillips #2 screwdriver.
  13. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew two screws with Phillips #2 screwdriver.
  14. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach motor and unscrew two screws with a Phillips #2 screwdriver.
  15. Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Hoover Power Path Pro Advanced Suction Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the bottom section off.
    • Pull the cap off.
Jose Andres Gonzalez Valdes
crwdns2935283:001/22/18crwdne2935283:0
682 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G5, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S16-G5, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S16G5
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
Billy H. Deal Jr - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,402
