HP Spectre x360 15" (15t-ap000) SSD Replacement
  1. HP Spectre x360 15" (15t-ap000) SSD Replacement, Unscrew the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) SSD Replacement, Loosen the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Spectre x360 15" (15t-ap000) SSD Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) SSD Replacement, Remove the SSD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or tweezers to peel the black plastic strip until you uncover the SSD.
  6. HP Spectre x360 15" (15t-ap000) SSD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the 2.8 mm-long screw securing the SSD to the motherboard.
    What size screwdriver is needed to remove screw holding ssd
    Nils - crwdns2934203:0crwdne2934203:0
  7. HP Spectre x360 15" (15t-ap000) SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Spectre x360 15" (15t-ap000) SSD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the SSD edges with your fingers and pull it at a shallow angle parallel to the motherboard.
    • Remove the SSD.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297.485 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.559crwdne2935297:0
There are several types of M.2 slot supporting different technology, SATA or NVMe, so the first claim in the into is incorrect. Additionally, they are different sizes.
Ed Maher - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 4,382
