HP Elite x2 G1 1012 Motherboard Replacement Guide
  1. HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the keyboard from the screen.
  2. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While the screen is facing down, remove six 3.0 mm Torx T5 screws under the stand.
    • The screws were not available when we received our device.
  3. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a suction cup to remove the screen panel.
  4. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach flex cable from motherboard using tweezers.
    You also have to detach the screen ribbon (silver) at the bottom end. Peel back the protective sticker on the screen end, and it unplugs downwards. There’s no retaining clip.
    tca cowan - crwdns2934203:0crwdne2934203:0
  5. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery wire attached to the motherboard using tweezers.
  6. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove ten 2.7mm screws using the Phillips #0 screwdriver.
    There is one screw missing here: Top Right immediately above the USB 3 port. It needs to come out as well.
    Also, there is a silver double-screw cover above the USB-C post that needs to come out as well.
  7. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the speaker wire attached to the motherboard.
  8. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the left speaker.
  9. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the two stickers highlighted from the right speaker.
    I cannot see why you needed to take out the speakers. They do not inhibit the Board coming out. The only thing you need to do is detach the stickers holding the wifi antennas from the speakers, and unplug the speaker cables from the motherboard (they are tiny and very fiddly to get back in again - needs small tweezers)
  10. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the right speaker cables from the motherboard using tweezers.
  11. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the right speaker.
  12. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the WWAN card from the motherboard by pulling it to the left using tweezers.
  13. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the SSD from motherboard by pulling it to the left using tweezers.
  14. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to loosen the motherboard.
    You missed a step here. Using the other guides for the front and real camera, you need to detach these before prying up the motherboard
  15. HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Elite x2 G1 1012 Motherboard Replacement Guide: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the motherboard from the casing.
    • Apply pulling force to the left to pull out the ports from the casing safely.
Hanif Norhisham
crwdns2935283:005/22/19crwdne2935283:0
571 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G5, Harley Summer 2019 crwdns2935289:0IUPUI, Team S1-G5, Harley Summer 2019crwdne2935289:0
IUPUI-HARLEY-SU19S1G5
¿basta con esto para cambiar el cable LCD?
Is this enough to replace the LCD wire?
Pablo Sánchez-Simón - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,760
