If your device cannot access or recognize your Wi-Fi networks, the wireless card may be faulty. This guide will show you how to replace the wireless card in your device.
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Flip the tablet over with the screen facing upwards.
Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
The eDP cable (the wider one) can tear very easily where it does a 90-degree bend. Be careful here, especially since this isn't an easy part to find.
Also, the lower right side of the screen is stuck down with adhesive. It can be pulled up, it again, be careful not to tear the eDP cable in the process
Be very careful not to use too much force when pulling up with the suction cup, as it will leave visible bright spots on the screen. It's better to put the suction cup at the edges and pull up using less force, then move the cup along to the next edge, then to pull from the centre.
With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
Remove the screen from the tablet.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Remove the single 2 mm screw with a Phillips #00 Screwdriver.
Gently disconnect the single wire connector with your finger.
Gently lift the wireless card and firmly pull it out of the motherboard.
Just to note, this is the WWAN (cellular/LTE) card, not the WLAN card (WiFi). The WLAN card is soldered down and not removable.
