HP Elite X2 1013 G3 Wireless Card Replacement
  1. HP Elite X2 1013 G3 Wireless Card Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
    The eDP cable (the wider one) can tear very easily where it does a 90-degree bend. Be careful here, especially since this isn't an easy part to find.
    Also, the lower right side of the screen is stuck down with adhesive. It can be pulled up, it again, be careful not to tear the eDP cable in the process
    Dennis Favro - crwdns2934203:0crwdne2934203:0
    Be very careful not to use too much force when pulling up with the suction cup, as it will leave visible bright spots on the screen. It's better to put the suction cup at the edges and pull up using less force, then move the cup along to the next edge, then to pull from the centre.
  3. HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen from the tablet.
    How does the plastic bezel attach to the screen?
    Alex Hulinsky - crwdns2934203:0crwdne2934203:0
  5. HP Elite X2 1013 G3 Wireless Card Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Wireless Card Replacement, Wireless Card: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is turned off and the battery is removed before continuing!
    • Remove the single 2 mm screw with a Phillips #00 Screwdriver.
  8. HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently disconnect the single wire connector with your finger.
  9. HP Elite X2 1013 G3 Wireless Card Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the wireless card and firmly pull it out of the motherboard.
    • Pay attention to the orientation of the wireless card. Trying to put your replacement wireless card in the wrong way could damage the part or the connector.
Kory Haydon
crwdns2935283:004/18/19crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G12, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S9-G12, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S9G12
Just to note, this is the WWAN (cellular/LTE) card, not the WLAN card (WiFi). The WLAN card is soldered down and not removable.
crwdns2942667:0crwdne2942667:0 906
