Use this guide to replace the battery in your HP 15 Laptop PC.
Note: This procedure was written using a model 15-dy2702dx HP 15 Laptop PC, but is fully compatible with any HP 15 Laptop PC whose model number starts with 15-dy or 15-ef.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
Fully shut down your laptop and unplug all cables.
Flip your laptop over so the rubber feet are facing up.
Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
Peel the front foot away from the back cover and remove it.
Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
Peel the rear foot away from the back cover and remove it.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
The rear foot is thicker, with a deeper recess.
The front foot is thinner, with a shallower recess.
If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
The place in the rear is deeper than the front!
Thank you for the comment, the guide has been updated!
Use a Phillips screwdriver to remove the eight screws securing the back cover:
Six 6.5 mm-long silver screws
Two 6.7 mm-long black screws
Flip your laptop over and open the screen.
Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
Slide the opening pick down to the bottom left corner to release the clips on the left edge.
Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
Slide the opening pick down to the bottom right corner to release the clips on the right edge.
Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
Slide the opening pick to the bottom left corner to release the remaining clips.
Close the screen and flip your laptop back over again.
Remove the back cover.
Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
Remove the battery.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
The guide is fine, with one exception. It appears that the instructions for the rubber strips on the bottom are backwards. The deeper groove for the rubber strip is, in fact, in the back, not the front as stated. The shallower groove is in the front of the computer, not the back.
Thank you for the well written guide on replacing the battery on my almost 4 year old HP 15-EF laptop. The steps along with the pics. made it fairly simple and quick.
Cheers!
Ray L.
Very nice guide, thank you!! I splurged and bought the genuine HP replacement battery from iFixit. It's like triple the price of a knock off Chinese battery but I think it is worth it overall. Those knockoff batteries rarely perform well. I also purchased the Tesa 61395 4mm tape to reattach the rubber feet properly. 5mm would have been better but they only had 4mm or 6mm and not sure if 6mm would fit. Using this guide the fix went really smoothly with an HP 15-dy1038n purchased in December 2019.
