GuliKit KingKong 2 Pro Triggers Replacement
  1. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the back cover screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. GuliKit KingKong 2 Pro Triggers Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. GuliKit KingKong 2 Pro Triggers Replacement, Separate the front assembly and back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Separate the front assembly and back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. GuliKit KingKong 2 Pro Triggers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. GuliKit KingKong 2 Pro Triggers Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the back cover from the front assembly and remove it.
  6. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the right vibration motor: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the left vibration motor: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. GuliKit KingKong 2 Pro Triggers Replacement, Remove the vibration motors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vibration motors by lifting them out of the controller housing.
  9. GuliKit KingKong 2 Pro Triggers Replacement, Release the interconnect cable ZIF connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Release the interconnect cable ZIF connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the mainboard assembly screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard shield: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard shield: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the mainboard assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mainboard assembly by lifting it out of the controller housing.
  14. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the battery frame screw: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take care not to puncture the battery with your tool—a punctured battery may leak dangerous chemicals or cause a fire.
    • Use a Phillips #00 screwdriver to remove the single 7.8 mm-long screw securing the battery frame.
  15. GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Free the battery frame: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Free the battery frame by lifting it off the plastic pins holding it in place.
  16. GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Disconnect the battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to disconnect the battery connector by pulling it straight out of its socket.
    • Remove the battery and its frame from the controller housing.
  17. GuliKit KingKong 2 Pro Triggers Replacement, Unfasten the trigger screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 7.8 mm-long screws securing the triggers.
  18. GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the left trigger: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the left trigger off its bracket.
    • Remove the left trigger.
  19. GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GuliKit KingKong 2 Pro Triggers Replacement, Remove the right trigger: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous procedure and lift the right trigger off its bracket to remove it.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
238,170 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,137crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Do you know where to buy a replacement zr trigger? The Black piece of Plastic,as in your last picture ,is broken on mine.
Strumpfmaskenmann - crwdns2934203:0crwdne2934203:0
My Gulikit Kingkong 2 (non-pro) controller bought in Dec 2022 only uses PH01 screws. No PH00 ones. Otherwise this guide is very helpful for any disassembly you may want to do.
Sebastian Jost - crwdns2934203:0crwdne2934203:0
When replacing the triggers, you need to recalibrate the controller before the new trigger(s) will work. I followed I followed the instructions found here for recalibrating when updating the firmware.
"Just press the four buttons of L,R,left of D-pad and A at the same time to quickly calibrate the sticks ZR,ZL with a vibration to solve this issue"
Captain Tinman - crwdns2934203:0crwdne2934203:0
Did anyone find a retailer for a replacement trigger
Max Lang - crwdns2934203:0crwdne2934203:0
Mate. You just show how to remove the triggers. How bout replacement ?????
John Robert Caleja - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 174
crwdns2942667:0crwdne2942667:0 7,869
