Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement
  1. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement, Pump Hose 288623: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement, Pump Hose 288623: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 2 bolts holding the cover on
  2. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove hose 288623
  3. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Connect bottom hose to pump hose without locking it in all the way. Pulling hard you will pull the top portion of the hose through and feed it all the way over to the right locked in place
  4. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the top hose attached make sure to feed around both ends of the pully and pull bottom hose through and push all the way to the right
    from what I can see this is not a replacement tutorial this is a tutorial on how to put the hose back into alignment on the pulley
    JACOB - crwdns2934203:0crwdne2934203:0
    A kink in a new hose while installing will happen. this DOES NOT MATTER as the 2 pegs rotating create positive and negative pressures as it rotates. a single kink will be unkinked during use due to rotation, that acts like a pump.
    BRIAN - crwdns2934203:0crwdne2934203:0
crwdns2935229:013crwdne2935229:0
Trevor A
crwdns2935283:009/16/21crwdne2935283:0
1,360 crwdns2915208:0crwdne2915208:0
What do i do with the hose plate, throw it away?
JOSEPH - crwdns2934203:0crwdne2934203:0
No, It holds the Hose Coupler in place, not allowing it to wiggle when machine in operation.
MAURICIO - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 86
crwdns2942667:0crwdne2942667:0 2,441
