Google Pixel Watch 2 Vibration Motor Replacement
  1. Google Pixel Watch 2 Vibration Motor Replacement, Prepare your watch for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Prepare your watch for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
    • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
  2. Google Pixel Watch 2 Vibration Motor Replacement, Remove both watch bands: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Remove both watch bands: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both watch bands by pressing the release button and sliding the band out of its groove.
  3. Google Pixel Watch 2 Vibration Motor Replacement, Put your watch in the vise: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inserting a tool between the screen and frame is very difficult. Using a vise to secure the frame makes it significantly easier.
    • Secure your watch with a small vise so the jaws go into the watch band grooves on the frame.
    • If your vice has sharp or metal jaws, consider wrapping the frame in a thin cloth to prevent scratching or damaging the frame.
  4. Google Pixel Watch 2 Vibration Motor Replacement, Safety precautions: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    iFlex Opening Tool
    $11.99
    • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Wear gloves to protect yourself.
  5. Google Pixel Watch 2 Vibration Motor Replacement, Heat the screen adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Very strong adhesive secures the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Use a hair dryer or heat gun to heat the right edge of screen around the watch crown until it's slightly too hot to touch.
    • Be careful not to heat the screen more than this, as it may damage the screen and/or battery.
  6. Google Pixel Watch 2 Vibration Motor Replacement, Insert an iFlex: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Insert an iFlex: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Insert an iFlex: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of an iFlex between the screen and frame just below the watch crown (opposite the side button).
    • This is very difficult and will take multiple attempts. If the screen cools down, apply more heat and try again.
    • Rotate the iFlex so its longer edge is between the screen and frame.
  7. Google Pixel Watch 2 Vibration Motor Replacement, Separate the screen adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Separate the screen adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Separate the screen adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the iFlex at a slight upward angle and slide it clockwise around the perimeter of the watch to separate the adhesive. Stop when you reach the side button.
    • Don't slide farther than this or you'll damage the screen cable.
  8. Google Pixel Watch 2 Vibration Motor Replacement, Remove your watch from the vise: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove your watch from the vise.
  9. Google Pixel Watch 2 Vibration Motor Replacement, Disassembly information: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Disassembly information: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Throughout the rest of your repair:
    • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
    • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
  10. Google Pixel Watch 2 Vibration Motor Replacement, Swing open the screen: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Swing open the screen: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Swing open the screen: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    E6000 Adhesive Glue
    $2.99
    • Be careful not to strain the screen cable during the rest of your repair.
    • Swing open the screen and put it in an upright position next to the watch crown.
    • If the screen feels stuck, go back around the perimeter and carefully separate any remaining adhesive with the iFlex. Be very careful not to damage the screen cable near the crown.
    • During reassembly:
    • This is a good point to plug in and test your watch before sealing it up. Be sure to power it down completely before you continue working.
    • Use a spudger and tweezers to remove all the old screen adhesive from the frame and screen. Then, clean up any adhesive residue with high‑concentration (>90%) isopropyl alcohol and a cotton swab.
    • You'll need to seal your phone with strong adhesive glue. Apply the glue to the perimeter of the frame and firmly press the screen into place.
    • Most strong adhesive glues have a long curing time—read the instructions for proper use.
  11. Google Pixel Watch 2 Vibration Motor Replacement, Unfasten the vibration motor cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Unfasten the vibration motor cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Use a 1IP Torx Plus screwdriver to remove the 2 mm‑long screw securing the vibration motor press connector cover.
    • While the Pixel Watch 2 uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
  12. Google Pixel Watch 2 Vibration Motor Replacement, Peel up the vibration motor cable tape: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Peel up the vibration motor cable tape: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Peel up the vibration motor cable tape: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tape secures the vibration motor cable and its cover to the battery.
    • Be careful not to puncture the battery—it can leak dangerous chemicals and catch fire.
    • Use a pair of blunt nose tweezers to grip the vibration motor press connector cover.
    • Gently peel up the tape until the vibration motor cable is uncovered.
    • During reassembly, use the flat end of a spudger to push the black cover tape back into place.
  13. Google Pixel Watch 2 Vibration Motor Replacement, Disconnect the vibration motor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Disconnect the vibration motor: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Disconnect the vibration motor: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the vibration motor press connector.
    • During reassembly, use the flat end of a spudger to reconnect the press connector.
  14. Google Pixel Watch 2 Vibration Motor Replacement, Unfasten the vibration motor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Unfasten the vibration motor: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1IP Torx Plus screwdriver to remove the two screws securing the vibration motor:
    • One 2 mm‑long screw
    • One 3 mm‑long screw, also securing a grounding bracket
  15. Google Pixel Watch 2 Vibration Motor Replacement, Remove the grounding bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Remove the grounding bracket: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt nose tweezers to lift the grounding bracket out of its recess and remove it.
    • During reassembly, use the smaller alignment cutout to orient the bracket.
  16. Google Pixel Watch 2 Vibration Motor Replacement, Remove the vibration motor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Watch 2 Vibration Motor Replacement, Remove the vibration motor: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the vibration motor.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
154,898 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,033crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023,758crwdne2935297:0
crwdns2942667:0crwdne2942667:0 157
