Google Pixel Buds A-Series Sound Chamber Mesh Removal
  1. Google Pixel Buds A-Series Sound Chamber Mesh Removal, Getting started: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Buds A-Series Sound Chamber Mesh Removal, Getting started: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the Google Pixel Buds Charging / Carrier case to locate the Buds.
    • Remove the rubber tips.
    • If necessary, clean the ear buds, especially the openings, contacts and sensors with damp cotton swabs.
  2. Google Pixel Buds A-Series Sound Chamber Mesh Removal, Overview: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Buds A-Series Sound Chamber Mesh Removal, Overview: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Components of the ear buds:
    • Microphone
    • Vent
    • Charging contacts
    • IR sensor for detecting when the bud is in the ear
    • Touch sensor
    • Sound chamber opening with mesh, our point of interest
    • Take a small container, fill it with isopropyl alcohol and insert the buds so that the sound chamber opening - but not any other parts - touch the liquid.
    • Soaking time might vary depending on how degraded the glue already is. This can potentially take hours.
    • If longer soaking is necessary, I really recommend adding some glycerol to the alcohol solution to soften the glue and prevent rapid evaporation of the solvent.
  3. Google Pixel Buds A-Series Sound Chamber Mesh Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Buds A-Series Sound Chamber Mesh Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Buds A-Series Sound Chamber Mesh Removal: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The mesh we're going to remove. The mesh sits in a small groove in the plastic case and is held in by gooey black glue.
    • Groove (after mesh removal)
    • This is the metal grid of the more expensive Pixel Buds 2 model (for comparison).
  4. crwdns2935267:0crwdne2935267:0
    • Take a soft brush (like a toothbrush or a small artists brush) and carefully try to push in the mesh.
    • Don't use excessive force and don't use sharp/pointy tools like tweezers.
    • You neither want to create a hole in the mesh nor want to cause damage to the speaker membrane further inside.
    • If the mesh doesn't easily move, keep soaking it in solvent. Be very careful and don't apply force.
  5. Google Pixel Buds A-Series Sound Chamber Mesh Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Buds A-Series Sound Chamber Mesh Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully use fine tweezers to grab the loose mesh and pull it outside.
    • The mesh is likely still stuck to one side of the ridge (assuming you pushed carefully), so it should be easy to retrieve. If not, locate it in the sound chamber and carefully remove it.
    • Make sure to not touch or damage the speaker membrane further in the back. Only use a small, soft brush if the mesh is stuck on the back side of the sound chamber.
    • Most of the glue should have come out together with the mesh. If necessary, carefully remove any remaining residue with the tweezers or a soft brush.
    • Here's some of the sticky black glue.
Reassemble the rubber tips and test the ear buds. Hopefully, the problem should be gone.
The removed mesh could cause increased ingress of dirt and liquids in the future. You could try to create a new cover made out of fine brass mesh for example, but the removed cover mesh also allows you to carefully clean the inside, so this isn't a big deal.
crwdns2935229:011crwdne2935229:0
Jonathan Haas
crwdns2935283:003/09/18crwdne2935283:0
1.703 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
I was having problems with the loudness of the pixel buds 2a. I thought my hearing was deteriorating. I had to have them set to around 80-90% volume on my pixel 6. I was thinking of getting new headphones anyways so I'm okay ruining the buds. I took the mesh out, now they sound like the same volume but the volume phone is set to only 20%. Feels like I have new head phones. Thanks for the guide!
Kyle Lessoway - crwdns2934203:0crwdne2934203:0
Happy to help. Also had a low volume problem at first and it took some trial and error to figure out what was wrong.
Jonathan Haas -
Wow! If weren't completely inappropriate to hug a complete stranger...! I didn't think I could do this and it did require glasses, focused light, a magnifying glass, and a ton of patience, but it worked!! I did shred the screen a bit but I eventually got it all out. God bless you.
Alena Van Drielen - crwdns2934203:0crwdne2934203:0
I was playing around with mine and it looks like that cup that has the CE mark and forms the groove that holds in the soft ear piece comes off at the seam that the mesh sits inside of. If you were to take it off you might be able to reinstall the mesh if you so desired.
Andrew - crwdns2934203:0crwdne2934203:0
That's good. I suspected that the "cups" could be removed but in my buds these were quite stuck. If you have them removed, could you explain how? Just brute force?
Jonathan Haas -
Thanks for that! I had the issue that my attempt to clean it pushed half of the mesh inside and left it open. Opening the cup took a bit of effort and brute force, I wrapped some tissue around it while pulling at it with my fingernails, but once I got it off it, was super easy to clean off the glue with some alcohol and re-apply the mesh with some glue on the rim.
Leenders Kristof -
Omg this was a lifesaver. I forgot to actually ship my buds in when they were gonna cover it under warranty and was literally about to purchase a new left bud when I saw this guide. Idk if it's due to age, but I didn't even need to use alcohol, just precision tip tweezers and a steady hand.
Devin Parker - crwdns2934203:0crwdne2934203:0
I've bought this when I travel US in 2019 Pixel Buds A Series Olive Green. the right bud somehow the mesh have gone into this situation:
https://pasteboard.co/7U5ujWDwNpZo.png
Do you know if the cap can be removed? So I can try to add a similar mesh?
Thanks!
Video Bots - crwdns2934203:0crwdne2934203:0
Very simple I never thought it would be so easy.
I'm new to this whole fix your own stuff thing and almost threw the headphones away.
My God, I was stupid not to have a look at the things that are ‘broken’.
I mean a small protective grille that comes loose and presses on the membrane prevents the sound and ignorant as I am I actually wanted to throw them away, the things cost almost 100 euros.
Thanks to the Author and thanks to IFixIt and also Special thanks to FixTronics Youtube Channel that brought me here
Seb Star - crwdns2934203:0crwdne2934203:0
Hi,
klasse Tipp: Das funktioniert tatsächlich, sogar auf die harte Tour – ohne Alkohol, nur mit Zahnstocher + Pinzette. Eine Frage dazu: Die Membran ist weg, wie reinigt man am besten den Innenteil/das Innere der Buds? Gruß + THX!
Hi,
great tip: This actually works, even the hard way - without alcohol, just with a toothpick + tweezers. One question: The membrane is gone, what's the best way to clean the inside/the inside of the buds? Greetings + THX!
Gregor - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 217
crwdns2942667:0crwdne2942667:0 9,047
