Google Pixel 9 Pro Fold Base Battery Replacement
  1. Google Pixel 9 Pro Fold Base Battery Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Base Battery Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold Base Battery Replacement, Separate the back cover adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the back cover adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the back cover adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the top bracket screw: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the top bracket screw: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the top bracket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the top bracket: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the back cover cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the back cover cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the back cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery bracket screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery bracket screws: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery bracket: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery bracket: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the base battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the base battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the USB-C port board cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the USB-C port board cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
  15. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the vibrator bracket screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the vibrator bracket screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
  16. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the vibrator bracket: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the vibrator bracket: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
  17. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the antenna cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the antenna cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
  18. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera bracket screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera bracket screws: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  19. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera bracket: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera bracket: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera bracket: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  20. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the inner front camera: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the inner front camera: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  21. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner front camera: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  22. Google Pixel 9 Pro Fold Base Battery Replacement, Separate the ultra wideband antenna: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the ultra wideband antenna: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the ultra wideband antenna: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
  23. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the ultra wideband bracket screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the ultra wideband bracket screws: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
  24. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the ultra wideband bracket: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the ultra wideband bracket: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the ultra wideband bracket: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
  25. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the bottom interconnect cable bracket screw: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the bottom interconnect cable bracket screw: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
  26. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
  27. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner display cable bracket screw: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner display cable bracket screw: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
  28. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner display cable bracket: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the inner display cable bracket: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
  29. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the inner display cable: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the inner display cable: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the inner display cable: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
  30. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
  31. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the graphite sheet: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the graphite sheet: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
  32. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
  33. Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the side buttons: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Disconnect the side buttons: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
  34. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
  35. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
  36. Google Pixel 9 Pro Fold Base Battery Replacement, Separate the 5G mmWave antenna: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the 5G mmWave antenna: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
  37. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the logic board screws: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the logic board screws: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
  38. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the logic board: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the logic board: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the logic board: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
  39. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
  40. Google Pixel 9 Pro Fold Base Battery Replacement, Clean the thermal paste: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Clean the thermal paste: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Clean the thermal paste: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  41. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
  42. Google Pixel 9 Pro Fold Base Battery Replacement, Separate the conductive fabric: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the conductive fabric: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the conductive fabric: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to peel the section of conductive fabric connecting the loudspeaker to the frame.
  43. Google Pixel 9 Pro Fold Base Battery Replacement, Separate the cable adhesive: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the cable adhesive: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the cable adhesive: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide one arm of a pair of angled tweezers under the contact pad connected to the loudspeaker.
    • Lift the contact pad to separate the adhesive securing it to the frame.
  44. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the loudspeaker screw: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the loudspeaker screw: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the 2.6 mm‑long screw securing the loudspeaker.
  45. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the loudspeaker: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the loudspeaker: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up the left edge of the loudspeaker to separate the adhesive securing it to the frame.
  46. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the top edge of the loudspeaker and pull it out of its recess in the frame.
    • Remove the loudspeaker.
  47. Google Pixel 9 Pro Fold Base Battery Replacement, Separate the USB-C port board adhesive: crwdns2935265:047crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Separate the USB-C port board adhesive: crwdns2935265:047crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the tip of an opening pick under the USB-C port board cable to separate the adhesive securing it to the frame.
  48. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the USB-C port board screws: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the USB-C port board screws: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the three 2.6 mm‑long screws securing the USB-C port board.
  49. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the USB-C port board: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the USB-C port board: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up the top right corner of the USB-C port board to unclip it from the frame.
  50. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the USB-C port board out of its recess in the frame and remove it.
  51. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to peel up the two edges of the pull tab on the base battery.
  52. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:052crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unfold your phone and flip it so the inner screen is facing upward.
    • Use a hair dryer, or a heat gun, to heat the section of inner screen behind the base battery until the its barely too hot to touch.
    • Don't heat the screen longer than 30 seconds, as it's susceptible to heat damage.
  53. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fold your phone and turn it so the base battery is facing up.
    • While holding the right pull tab, slide the left pull tab toward the top edge of the battery to separate the top section of adhesive.
  54. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:054crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery adhesive is strong. Be careful when pulling on the battery and reapply heat if necessary to avoid bending it.
    • Grip the ends of the plastic pull tabs with your fingers.
    • Pull straight up with constant, steady force to separate the adhesive under the battery. Work slowly and let time do the work for you until the adhesive separates.
    • Remove the base battery.
    • If you're having trouble separating the adhesive, apply more heat and try again.
    • If you're having a lot of trouble separating the adhesive, or if you feel like you might damage the battery, follow the next three steps for an alternate method.
  55. Google Pixel 9 Pro Fold Base Battery Replacement, Apply isopropyl alcohol: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply isopropyl alcohol: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The next two steps show how to apply isopropyl alcohol under the base battery.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol under the bottom edge of the base battery.
  56. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:056crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom edge of the phone to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
  57. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the base battery: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the center of the base battery.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to separate the base battery from the frame.
  58. Google Pixel 9 Pro Fold Base Battery Replacement, End of disassembly: crwdns2935265:058crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  59. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to remove the old base battery adhesive from the frame.
    • Apply isopropyl alcohol (>90%) and use a coffee filter or microfiber cloth to clean any adhesive residue.
  60. Google Pixel 9 Pro Fold Base Battery Replacement, Compare your new adhesive: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Compare your new adhesive: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing any liners, check that your base battery adhesive matches the size and shape of the cutout in the frame.
    • The clear liner should face the frame.
  61. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel off the adhesive strip from its clear liner.
    • Align the adhesive strip with the top edge of the base battery recess and press it onto the frame.
  62. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the five adhesive strips and adhere them to the frame.
  63. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:063crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:063crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:063crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the colored liner to expose the adhesive strips.
  64. Google Pixel 9 Pro Fold Base Battery Replacement, Install the new base battery: crwdns2935265:064crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Install the new base battery: crwdns2935265:064crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Install the new base battery: crwdns2935265:064crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the new base battery with the top edge of the battery recess and press it to the frame.
  65. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to press along the battery to adhere it to the frame.
  66. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the USB-C port board: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the USB-C port board: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the USB-C port board into its recess in the frame.
  67. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:067crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the USB-C port board flat to the frame to re-engage the metal springs, making sure the alignment pegs fit into their holes in the board.
  68. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:068crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:068crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:068crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the board in place, use a Torx Plus 3IP driver to install the three 2.6 mm‑long screws securing the USB-C port board.
  69. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the adhesive: crwdns2935265:069crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the adhesive: crwdns2935265:069crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the adhesive: crwdns2935265:069crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive on your USB-C port cable isn't sticky or intact, follow the next two steps to install new adhesive. Otherwise, skip those steps.
    • Use tweezers, or your fingers, to remove the old adhesive under the USB-C port cable.
    • Peel the new USB-C port cable adhesive strip from its clear liner.
    • Align the adhesive strip over its spot in the frame and lay it down with the colored pull tab facing the right edge of the phone.
  70. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:070crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:070crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the adhesive and adhere it to the frame.
    • Peel off the colored liner to expose the adhesive.
  71. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:071crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the USB-C port board cable to the frame to re-adhere it.
  72. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:072crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:072crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:072crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The next six steps show how to replace the conductive fabric on the bottom of your loudspeaker and the adhesive on the loudspeaker's cable. Skip these steps if your fabric and adhesive are intact.
    • Use tweezers, or your fingers, to remove the bottom and top conductive fabrics or the loudspeaker cable adhesive if they're not intact.
  73. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the bottom conductive fabric: crwdns2935265:073crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the bottom conductive fabric: crwdns2935265:073crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the bottom loudspeaker conductive fabric on the underside of the loudspeaker.
    • Refer to the second photo for the correct orientation.
  74. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:074crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:074crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the conductive fabric from its clear and colored liners and lay it over its spot on the loudspeaker.
  75. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:075crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:075crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the loudspeaker.
  76. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the adhesive: crwdns2935265:076crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the adhesive: crwdns2935265:076crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the adhesive: crwdns2935265:076crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the clear liner off the loudspeaker cable adhesive.
    • Align the adhesive over the loudspeaker cable and lay it down, making sure not to cover the hole in the cable.
  77. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to lightly pinch the cable and adhere the adhesive strip.
    • Remove the blue liner from the adhesive strip.
  78. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the loudspeaker: crwdns2935265:078crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the loudspeaker: crwdns2935265:078crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the hole in the loudspeaker cable over its peg on the frame.
    • Press down the cable with the tip of a spudger, or your finger, to adhere it to the frame.
  79. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:079crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:079crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While pressing the cable down, reinsert the loudspeaker at an angle into its recess and press it flat to the frame.
  80. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:080crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:080crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:080crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the loudspeaker in place, use a Torx Plus 3IP driver to install the 2.6 mm‑long screw securing the loudspeaker.
  81. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the top conductive fabric: crwdns2935265:081crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the top conductive fabric: crwdns2935265:081crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The next four steps show how to replace the conductive fabric on the top of the loudspeaker. Skip these steps if your fabric is still intact.
    • Peel off the clear liner on the top loudspeaker conductive fabric.
    • Peel off the small colored liner covering the rounded corner of the fabric.
  82. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:082crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:082crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:082crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Align the rounded corner of the conductive fabric with the same‑shaped marking on the frame.
    • Lay the fabric down onto the frame and the loudspeaker.
  83. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:083crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:083crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:083crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the frame and loudspeaker.
  84. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:084crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:084crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the large colored liner from the conductive fabric.
  85. Google Pixel 9 Pro Fold Base Battery Replacement, Apply new thermal paste: crwdns2935265:085crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply new thermal paste: crwdns2935265:085crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply new thermal paste: crwdns2935265:085crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
  86. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the logic board: crwdns2935265:086crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the logic board: crwdns2935265:086crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
  87. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:087crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:087crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
  88. Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the side button cable: crwdns2935265:088crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the side button cable: crwdns2935265:088crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use angled tweezers to push the side button cable back into its slot.
  89. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:089crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the locking tab down and lightly press on it until it clicks into place.
  90. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:090crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:090crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the yellow tape over the ZIF connector and its cable.
  91. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new graphite sheet: crwdns2935265:091crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new graphite sheet: crwdns2935265:091crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new graphite sheet: crwdns2935265:091crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
  92. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:092crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:092crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
  93. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:093crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:093crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
  94. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:094crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:094crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:094crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
  95. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:095crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:095crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:095crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
  96. Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the right side cables: crwdns2935265:096crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the right side cables: crwdns2935265:096crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the right side cables: crwdns2935265:096crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
  97. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner display cable bracket: crwdns2935265:097crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner display cable bracket: crwdns2935265:097crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
  98. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:098crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:098crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
  99. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the bottom interconnect cable bracket: crwdns2935265:099crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the bottom interconnect cable bracket: crwdns2935265:099crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
  100. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0100crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0100crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
  101. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the ultra wideband bracket: crwdns2935265:0101crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the ultra wideband bracket: crwdns2935265:0101crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
  102. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0102crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0102crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
  103. Google Pixel 9 Pro Fold Base Battery Replacement, Replace the ultra wideband bracket adhesive: crwdns2935265:0103crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Replace the ultra wideband bracket adhesive: crwdns2935265:0103crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Replace the ultra wideband bracket adhesive: crwdns2935265:0103crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
  104. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:0104crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:0104crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:0104crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  105. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:0105crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:0105crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:0105crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  106. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0106crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0106crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0106crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  107. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0107crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0107crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0107crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  108. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner front camera: crwdns2935265:0108crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner front camera: crwdns2935265:0108crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  109. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner front camera bracket: crwdns2935265:0109crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner front camera bracket: crwdns2935265:0109crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the inner front camera bracket: crwdns2935265:0109crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  110. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0110crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0110crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  111. Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the antenna cable: crwdns2935265:0111crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
  112. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the vibrator bracket: crwdns2935265:0112crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the vibrator bracket: crwdns2935265:0112crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the vibrator bracket on the logic board and align its screw holes.
  113. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0113crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0113crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
  114. Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the USB-C port board cable: crwdns2935265:0114crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the USB-C port board cable press connector.
  115. Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the base battery: crwdns2935265:0115crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the base battery press connector.
  116. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the base battery bracket: crwdns2935265:0116crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the base battery bracket: crwdns2935265:0116crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  117. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0117crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0117crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  118. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:0118crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the old adhesive: crwdns2935265:0118crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  119. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the back cover liners: crwdns2935265:0119crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the back cover liners: crwdns2935265:0119crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the back cover liners: crwdns2935265:0119crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  120. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0120crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0120crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0120crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the remaining clear liners on the outside of the back cover.
  121. Google Pixel 9 Pro Fold Base Battery Replacement, Compare your adhesive: crwdns2935265:0121crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Compare your adhesive: crwdns2935265:0121crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing any liners, check if the adhesive matches the frame.
  122. Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:0122crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:0122crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Apply the new adhesive: crwdns2935265:0122crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  123. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0123crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0123crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  124. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0124crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0124crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0124crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  125. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0125crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0125crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0125crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  126. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0126crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0126crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0126crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  127. Google Pixel 9 Pro Fold Base Battery Replacement, Reconnect the back cover cable: crwdns2935265:0127crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  128. Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the top bracket: crwdns2935265:0128crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Reinstall the top bracket: crwdns2935265:0128crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  129. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0129crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0129crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  130. Google Pixel 9 Pro Fold Base Battery Replacement, Remove the secondary liner: crwdns2935265:0130crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Remove the secondary liner: crwdns2935265:0130crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  131. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0131crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0131crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0131crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the secondary liner to expose the adhesive.
  132. Google Pixel 9 Pro Fold Base Battery Replacement, Secure the back cover: crwdns2935265:0132crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement, Secure the back cover: crwdns2935265:0132crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the top edge of the back cover with the frame and press down to adhere it.
  133. Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0133crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0133crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Base Battery Replacement: crwdns2935265:0133crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed batteries after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
189.047 crwdns2915208:0crwdne2915208:0
crwdns2935297:0866crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:023.251crwdne2935297:0
I'd charge about 2K to do that for someone with all the time and effort and material involved.
Kenny Penney - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 166
crwdns2942667:0crwdne2942667:0 1,148
