Google Pixel 3 Battery Replacement
Arthur Shi
crwdns2944107:0crwdnd2944107:0Arthur Shicrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 18, 2025crwdne2944111:0
1 - 3 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to remove and replace a worn battery for the Pixel 3. If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
  1. Google Pixel 3 Battery Replacement, Weaken the back cover's adhesive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Older devices may require 2 or more minutes with a very hot iOpener. Also note, the photo shows the opener on the FRONT of the phone. The heat needs to be applied to the back of the device!
    Rick Johnson - crwdns2934203:0crwdne2934203:0
    I just realized that I was trying to pry apart the front of my Pixel 3… and have separated the class from the display. ??‍♂️ Even though the rest of the directions show the back, it would be nice for the first picture to also show the back, just to be safe.
    JR Raith -
    Agreed, I’ve done exactly the same and completely broken my display. I probably should’ve paid more attention to the initial steps before diving in but the step could do with a new picture for sure.
    Daniel Fryer -
    Thanks for the comments! I’ll add a note in the step warning people to make sure to pry the back cover, not the screen.
    Arthur Shi -
    I prefer my favorite opening method with something like this. Dental floss. So thin it can slide in the gap. A little sawing to get it far enough past the edge to lift and get the first pick in.
    John Hoffstetter - crwdns2934203:0crwdne2934203:0
    I found another wonderful tool. I used something like medicine packaging which is aluminum foil with plastic. It’s thin and strong enough!
    Christie Lin - crwdns2934203:0crwdne2934203:0
    I also went for the hairdryer, dental floss, and then the provided picks and this worked. Not easy to get that initial seal broken but once that's done the rest is pretty easy.
    James - crwdns2934203:0crwdne2934203:0
    I needed 20 nerve wracking minutes with a hairdryer
    Amy schneider - crwdns2934203:0crwdne2934203:0
    My battery had bulged and opened the case for me!
    Warmed it up a bit with hairdryer
    Floss helped also.
    David Lincer - crwdns2934203:0crwdne2934203:0
    I found I wasn't able to get the edges hot enough. I ended up using my heat gun (for shrink tubing) instead.
    Kurt Nowak - crwdns2934203:0crwdne2934203:0
  2. Google Pixel 3 Battery Replacement, Create a gap in the seam: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Create a gap in the seam: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Create a gap in the seam: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the heated bottom edge of the back cover.
    • Make sure you did not mistake the screen side for the back cover side.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere.
    • Lift on the suction cup with strong, steady force to create a gap.
    • Depending on how aged your phone is, this may take significant force. If you are having trouble, apply more heat and try again.
    • Insert an opening pick into the gap.
    • Don't use metal tools to pry, or you'll mar or shatter the glass back cover. If the panel won't budge, apply more heat, either with a hair dryer or heat gun.
    The initial opening/insert is the hardest part of this repair, and if you end up having to use a flat-head screwdriver (etc) to get the first gap opened, you’ll scratch the phone. But it works.
    William Kew - crwdns2934203:0crwdne2934203:0
    I don’t recommend using a screwdriver. I tried this and it shattered the glass in that area. I replaced the battery on my Pixel 1 recently and noted that heating the FRONT glass on that phone enough to get a gap for one of the pics takes a considerable amount of time AND patience. I was one of the few who didn’t break or otherwise damage the glass in that process. I would say the same rule applies here. Allow for significant time and patiences to heat the old adhesive enough to get a pick inside the cover.
    kevlion88 - crwdns2934203:0crwdne2934203:0
    Definitely, this opening/insert is the hardest part of the procedure. I was unable to open even a slight separation with a suction cup and even with tons of heat from a hair dryer. What worked really well, and what I would highly recommend to others who experience really strong adhesive, is to use a small X-acto knife with a #16 blade. Make sure it’s a #16 (find on Amazon) because it differs greatly in angle and rigidity from the usual #11 blade. The sharpness of the blade makes it really easy to find the crack and open a gap, where you can then insert a pick with no problem.
    Andris Vizulis - crwdns2934203:0crwdne2934203:0
    I used a typical razor blade (like Matt and Rick and Greg) pressing the whole of the blade against the edge (blade parallel and flush against the back cover). The razor slipped under enough that I could get a pick in. (No damage, but when I first tried the corner of the razor, a small cut was immediately evident. Only use the whole blade.) Then, I used blue picks exclusively.
    I'm very curious about the dental floss method. I'll try that if I need to get back inside.
    pandam3ch4 -
    I gave up with the iOpener and pick, I tried >5 times for over an hour… After heating with theiOpener, I used and X-acto knife instead and that worked like a charm, except it did leave a few scuff marks unfortunatly. I used a size 22 blade.
    Manny - crwdns2934203:0crwdne2934203:0
    I really wanted to level off the back of the phone when pulling on the suction cup in this step, but found it was actually pretty easy once I used the opening tool to push down on the edge of the bezel, at the crack, barely putting any force on the back of the phone at all (just to keep it steady).
    Eugene Creswick - crwdns2934203:0crwdne2934203:0
    I have about a 2 year old Pixel 3. iOpener didn’t work at all on this step, but once I broke out the hair dryer, I was able to get the phone hot enough to insert the pick (no screwdriver or xacto knife needed)
    sliverdragon37 - crwdns2934203:0crwdne2934203:0
    I’m having trouble with the iOpener too. It is frustrating because I practiced on a bricked iPhone earlier this week and it was effortless. My Pixel 3 is also about 2 years old. Out of curiosity, were you replacing the charging assembly because of the charging cables fitting too loosely on the phone or for some other reason?
    Edwin -
    I used a stanley knive to get started and then a combo of opener and plektrums.
    All went well till I used to much force on the camera corner and broke the back into lots of small pieces. Be careful on that corner, people.
    But the new camera does focus, so for a first attempt at fixing a phone I am happy.
    clas ebeling - crwdns2934203:0crwdne2934203:0
    I heated the bottom up with the Iopener and then used a rectangular razor blade and the suction cup to lift the bottom. Place the entire blade edge into the crack and push/pry while lifting with the suction cup. As soon as you have a gap start to open, have a second person insert a pick into the corner. It was actually really easy. I had given up after a couple of tries without a blade. My Pixel 3 is 2 years old.
    Jeremy Stewart - crwdns2934203:0crwdne2934203:0
    Agreed with many other comments here. My Pixel 3 is two years old and neither the iopener nor a blow dryer were capable of loosening it enough. I ended up using a VERY hot iopener for a couple of minutes, the suction cup, and then a wide-bladed razer blade (about 80% width of bottom edge to spread out the stress and prevent risk of fracturing the rear glass panel). Once adding the razer blade I was able to get the pick in and follow the rest of the instructions as written.
    Matt Johnson - crwdns2934203:0crwdne2934203:0
    I also had to follow this process but resorted to a heat gun on its lowest setting as I couldn’t get the iOpener hot enough (I was afraid of overheating and bursting it). Other how-to videos also show using a thin piece of plastic or metal to slide into the corner, saving substantial time.
    Rick Johnson -
    So I didn’t use a blade, but I did get my fingernail in before the plectrum haha. Happened by accident as I was trying to push down on the bezel to counter the suction cup force.
    I also heated the sides and corners as well as the bottom, which may have helped it budge.
    Dmitriy - crwdns2934203:0crwdne2934203:0
    Helped me to notice that the focus here is to lift in the center (like right over the USB C connector). Was able to get it with just the iOpener and pushing down on the rest of the phone with the pry tool. My phone is over 2 years old though and it took about 50 minutes of working / reheating / repeating
    Tim Noack - crwdns2934203:0crwdne2934203:0
    Destroyed the glass back trying to take it off. This is not an easy phone to take apart.
    Andrew Richie - crwdns2934203:0crwdne2934203:0
    It would be nice if there was a heads up that the rear of the phone is glass….. Phone piping hot glass shattered and splintered
    John Gates - crwdns2934203:0crwdne2934203:0
    Hi John!
    Good suggestion! I'll add that into the step.
    Arthur Shi -
    The Jimmy tool from the iFixit toolkit worked like a freakin’ charm. Took me 10 mins to open the phone and it came out unscathed.
    adrianpauly - crwdns2934203:0crwdne2934203:0
    I used dental floss to cut the adhesive and slide it open. Just wiggle it back and forth from the corners until you cut enough that you can switch to a pick. Helps to have a extra hand to hold the phone.
    Javier Sullivan - crwdns2934203:0crwdne2934203:0
    Brother, dental floss was an absolute godsend!!! After 4 hours with the IOpener and attempting to use a heat gun which I balked from out of fear I came across this comment. Teased it around a corner and was then able to saw away at the adhesive. A lot of patience but no heat or potentially damaging tools needed. Thanks!
    Elijah Wilcox -
    With the floss, I wasn't getting enough "sawing" motion as it just slipped through my fingers too easily (my phone is about 4-5 years old I think, I bought it used). So I tied a few knots around a pen (the kind with a gripper, so the floss won't slide off) and it was a lifesaver. After about 3 hours trying other ways, the floss/pen saw got it open enough to stick the picks in and eventually open it up!! Thank you to everyone who commented these tips!!
    Rachel DeGouff -
    I have a 2-3 year old phone. The “heating pad” and blue picks did not work. I tried for two hours. Two weeks later I tried again using a hair dryer on high heat and low fan, and a rectangular utility razor blade. Start at the bottom of the phone, heat, and insert the razor blade into the gap and use it to cut the adhesive back a little at a time. Do not insert it more than about a 1/4 to 3/8 of an inch. Once you start getting a separation, use the blue picks to hold it open. Go up both sides an inch or two on both sides at a time. Do not pry the back open more than an 1/8 of an inch or so until you get it separated all the way around. Be patient. Work slowly. This took about 30 minutes once I got the hang of it. Do NOT pull the cover away from the phone after you separate it all the way around!! Read the instructions several times. There is a cable to the finger print sensor attached to the cover!
    Re-read these entire set of instructions and ALL of the comments TWICE before you start.
    Greg B - crwdns2934203:0crwdne2934203:0
    I used and iOpener and the iFixit tool (the one with the metal spatula). Ended up inserting about 10 picks, but it worked.
    Kevin Dick - crwdns2934203:0crwdne2934203:0
    I couldn’t get the pick in so I tried the sharper pry tool. Got it in and slid it sideways towards the corner —- BLAM, the back shattered. Not a good home repair experience.
    Roy Feague - crwdns2934203:0crwdne2934203:0
    Similar experience with others, iOpener would not heat up the phone enough to separate the adhesive. Had to use a hair dryer to finally insert the blue pick. After sliding the pick past the corner, the back glass scattered… Time to get a new phone and give up on this battery replacement i guess.
    John Wu - crwdns2934203:0crwdne2934203:0
    On a 3 years old Pixel 3 phone, after unsuccessfully trying iOpener and the suction cup, I used a piece of dental floss, and it worked perfectly.
    To make the process easier - tie little loops on both ends of the floss, put a finger or a screwdriver through the loop to help pulling the floss. Pull it through to one side and then to another, continue until you’re 1/2 inch in. At this point it should be possible to insert a pick
    Sergey Kiselev - crwdns2934203:0crwdne2934203:0
    This was the hardest step. I could not get the pick in at all. I tried dental floss and it slid in no problem. I eventually stuck the very tip of a razor blade in which allowed me to slide in a pick. Also be very careful when sliding the picks around as my wife broke the back glass of her phone, try to keep pressure as even as possible without bending the glass much.
    Adam Simmons - crwdns2934203:0crwdne2934203:0
    I like the dental floss idea. I set edges of the phone-back and also the blunt metal tool on an electric cooktop on low heat, and the adhesive softened enough to be workable. SAFETY TIP: the tool and phone were hot to touch, I wore cotton gloves throughout this task.
    Student4Life - crwdns2934203:0crwdne2934203:0
    Can confirm, with a 4-year-old Pixel 3, it was not possible to get the back cover off with any amount of force, heat, and the blue picks. I managed to get started by using single-edge box cutter razor blades and a hair dryer on high--got in just a bit under the left corner, then added a second blade along the bottom edge, and a third near the right corner, and that gave me enough space to get a blue pick in and start replacing the razors with blue picks one by one, and then proceeded as per the instructions. Dental floss is a neat idea; I wish I'd tried that--the razors didn't do any damage, but I was worried about the possibility.
    Adiv Paradise - crwdns2934203:0crwdne2934203:0
    Agreed; a 4cm section of utility knife was required along with heat/alcohol/patience to break the initial seal.
    Managed to do it without cracking anything, but sweated through this step quite prolifically.
    Mike -
    3.5 year old phone. Just wanted to confirm that dental floss, combined with the iOpener, does the trick to get the first pick in.
    I was able to slide the floss under the bottom right corner if you are looking at the phone. I alternated between sawing with the floss and applying heat with the iOpener. Eventually I was able to get a pick in that corner and was able to remove the rest of the adhesive by applying heat with the iOpener and sawing with additional picks around the perimeter of the phone.
    Matt Dubois - crwdns2934203:0crwdne2934203:0
    My Pixel 3 is 4 years old. I tried using the iOpener heat pad for 2 minutes. Didn't work. Then I tried using a heat gun on low for about 30 seconds. Didn't work. Then I used the heat gun on high for about a minute, then the suction pulled it off. I used the picks to peel the rest off. I thought about using the floss which would have work well. I also though about letting the phone sit in the car when it's hot outside. The key is to be patient and try not to use something besides the plastic tools. If I can do it then anyone can. Heat guns are very cheap and a good tool to have.
    Alex Schultz - crwdns2934203:0crwdne2934203:0
    After unsuccessfully trying all prying tools including metal ones - I finally hit the motherlode with the most inane thing possible-a stiff plastic collarbone-it has a slight angle at one end that gives it the required amount of rigidity and prying power.
    Yes, a heat gun is an absolute must!
    Jatinder Singh - crwdns2934203:0crwdne2934203:0
    I've ordered the battery replacement kit, it will arrive next week. I keep my house cool in fall/winter, so I'm a bit concerned about how well I'll be able to heat the adhesive. I'm considering heating the whole phone in my convection oven's "warm" function. Its thermostat compares well with a meat thermometer, I might try my lab grade thermometer too.
    I see "The phone is designed to work best in ambient temperatures between 32° and 95° F (0° and 35° C), and should be stored between ambient temperatures of -4° and 113° F (-20° and 45° C)." 113° F seems pretty low, perhaps that's when the adhesive begins to soften appreciably. I was considering starting at 120F. (And trying "toast" if it defeats me.)
    Experience, suggestions, good luck wishes welcome.
    reg - crwdns2934203:0crwdne2934203:0
    Hi reg!
    The temperatures you listed are operating temperatures—once the Pixel exceeds those temperatures, it will shut down and show a heat warning symbol. Ideally, you want to heat just the adhesive perimeter. The back cover should be slightly too hot to the touch—aim for about 80°C.
    Arthur Shi -
    3.5 year old phone. Thank the gods you guys recommended floss. I broke 2 nails trying the picks. Unfortunately I used extra slippy floss so I couldn't even tie it into loops to help. Even with the floss I couldn't saw my way through or get a pick in so I ended up just adding more and more floss (and more and more hairdryer) until I could get the pick in. After that it was just careful muscle.
    Despite several frustrating tries across several days, I had zero success creating a molecule of seam gap to begin to remove back cover without breaking it! Suction cup ineffective (needs 3rd? hand to pull-and-insert pick); heated iOpener doesn't U-fold to cover perimeter (soon cools off in 63F room); hair dryer likewise too-brief heat; Exacto or utility knife blades useless. Dental floss no luck. But only! once I tried keeping the Px3 on my electric 1980s food warming tray (Lo heat ..hands resting on insulating hot pads ..it also! keeps iOpener hot) ..would dental floss fit into corners (No chance midpoint at charge port per foto); then blue pick. But! floss was too slippery to pull/grip strongly ..one must tie loops at each end, then use old-style 'peg' clothespins (or pen with clip) to roll-up floss length to enable pulling right at insertion point. With fingers/hands preoccupied manipulating floss, it was awkward to simultaneously tug suction cup upward effectively at all. Didn't break rear cover ;-)
    AdahS - crwdns2934203:0crwdne2934203:0
    I had no luck with just a suction cup and heat. Heat and a razor blade as others commented worked well; HOWEVER, while working the blue opening picks around the bottom I cracked the glass. The back glass is more delicate than I anticipated. :-( Be very careful/gentle with the back glass! If I attempt this with another glass-backed phone I will plan to work on an actively heated pad for this step.
    Jeff Selfa - crwdns2934203:0crwdne2934203:0
    The plastic opening pick was to thick to get into the (almost nonexisting) crack. I had to use a thin sharp metal knife, which scratched the paint a little bit but finally made the crack wide enough for the plastic pic to fit in and finish the job. Perhaps one thin metal pick would be helpfull in the kit for this first step.
    L. Hopmeier - crwdns2934203:0crwdne2934203:0
    As others have said, this step was by far the most difficult and time consuming. DO NOT RUSH THIS STEP THOUGH. Take it slow and do NOT bend the back glass to try and speed things up. Keep slicing your way though, patiently being aware of the fingerprint sensor cable. On my phone it required a lot of force and im not even sure the puller was able to make a gap.. I found that the plastic picks were too thick to get a crack started. I ended up using a piece of plastic from a clamshell plastic container to finally make it through the crack and through the adhesive. I tried the plastic backing of one of the adhesives but that wasn't rigid enough. Once though I made my way about half way through; and in haste I made the fatal mistake of bending the back glass to much and shattered it. Yes it is in fact made of glass! It will NOT BEND. I ended up getting a replacement back glass kit on Amazon for $16 which had a new sensor and the adhesive pre-installed which was very nice.
  3. Google Pixel 3 Battery Replacement, Fingerprint cable information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When inserting an opening pick above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
    While the text is accurate, I found this image to be misleading - it appears as if the finger print cable is attached to the right side (from a back-of-phone reference). Only upon close image inspection is it clear that the cable has already been disconnected from the connector that is positioned just inside and above the power button.
  4. Google Pixel 3 Battery Replacement, Cut through the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Cut through the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Cut through the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slice the adhesive along the bottom edge of the phone and around the right corner.
    • Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
    The back cover is glass! I was sure it was some kind of nice plastic. It's probably obvious to a lot of people, and it's very obvious in hindsight, after shattering it. But I'm writing this in case anyone else is oblivious to the last decade of smartphone design. I got impatient and flexed it out as I cut the glue. Don't do that. Carefully work your way around and avoid applying any significany bending forces to the cover.
    Dharman Gersch - crwdns2934203:0crwdne2934203:0
    Yup, shattered the back of my phone while trying to follow these instructions. You can’t flex the back cover much at all or it is toast.
    Someone else had said to use floss to start the cutting I found this to be the most useful. After I heated the phone with a hairdryer I would cut some of the adhesive at the bottom corner after sawing away for a bit I was able to move it enough to fit one of these picks in then I slowly reheated around the edge as I slowly moved more picks and slowly cut away at the adhesive .
    Braden D - crwdns2934203:0crwdne2934203:0
    Didn't have guitar picks. I grabbed some plastic packaging from my recycle bin and cut it into a bunch of triangles to hold the gap open as I worked my way around.
    Leaving the pick in the bottom as described while using another to slide up for the next steps shattered the back cover - these instructions should be clear to only leave the pick in the bottom with as little inserted into the phone as possible as it does not take much flex at all to shatter. Also beware that there are no replacement back covers available from iFixit either :(
    Pixel3 Owner - crwdns2934203:0crwdne2934203:0
  5. Google Pixel 3 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat the right edge with an iOpener and continue slicing the adhesive with an opening pick.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    What is the required temperature to soften the glue? Can I just use a small bag filled with boiling water or a heat gun.
    Wiley Sanders - crwdns2934203:0crwdne2934203:0
    The iOpener is a plastic bag filled with what appears to be water so probably, yes.
    Christopher St. John - crwdns2934203:0crwdne2934203:0
  6. Google Pixel 3 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue heating and slicing through the rest of the phone perimeter. Leave a pick in each edge to prevent the adhesive from resealing.
    • When slicing above the power button, do not insert the pick more than halfway in to avoid damaging the fingerprint sensor cable.
  7. Google Pixel 3 Battery Replacement, Lift the left edge of the back cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Lift the left edge of the back cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Lift the left edge of the back cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
    • Do not attempt to remove the back cover. It is still attached to the phone by the fingerprint sensor cable.
    • Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
    Yes, per Step 7 foto, lift rear cover to vertical only! along the left edge (camera, power/volume) ..while also keeping the opposite long edge down (almost touching wireless coil) ..as left/camera edge rises (and right/lower edge slides leftward), take care to keep lower/right edge no further rightward than midway across coil (foto) ..then gently rotate now-lower right edge leftward 'clockwise', lay it flat without straining cable. [When my rear cover eventually suddenly released from the perimeter adhesive while still pulling on it, the upward force almost yanked the cover off cable; got lucky]
    [this updates my minutes-ago post ..apparently one can't edit after 5min? ..or delete/replace with this?]
    Where is the guide on re-attaching the back cover with new adhesive?
    iuooip - crwdns2934203:0crwdne2934203:0
  8. Google Pixel 3 Battery Replacement, Remove the screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
    • During reassembly, be careful not to over-tighten these screws, or you may damage your display.
    A magnetic screwdriver tip helped here.
    Ciprian Chelba - crwdns2934203:0crwdne2934203:0
    If you purchase iFixit’s kit for this replacement, their included driver is magnetic. Helped immensely!
    Rick Johnson -
    after replacing my camera, my screen had a big green/white vertical stripe. I didn’t see the disclaimer about overtightening these screws. I think it may be related.
    Ethan Berry - crwdns2934203:0crwdne2934203:0
    KEEP TRACK OF THE SCREWS - sketch a scale diagram of the open, inside of the phone on a piece of paper and mark the position of each screw as you remove it - lay the screws on your diagram to keep track of which screw goes where - they are NOT the same size.
    I completely forgot to put the fingerprint bracket back, along with two screws. How bad is it? For now seems working...
    Rick Sanchez - crwdns2934203:0crwdne2934203:0
  9. Google Pixel 3 Battery Replacement, Remove the fingerprint connector bracket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the fingerprint connector bracket: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the fingerprint connector bracket: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
    • Remove the fingerprint connector bracket.
    Re-inserting this is tricky and requires pretty good dexterity. The shiny metal frame of the wireless charger is also not held down, so you may wish to gently apply pressure to it as you try to re-position the connector bracket.
    I could use a whole tutorial on how to reinstall this
  10. Google Pixel 3 Battery Replacement, Disconnect the fingerprint connector: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 3 Battery Replacement, Disconnect the fingerprint connector: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  11. Google Pixel 3 Battery Replacement, Remove the back cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the back cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the back cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back cover.
    • Before you install a replacement back cover, be sure to remove all adhesive residue from the phone frame. Use an opening tool to scrape and high concentration isopropyl alcohol to clean the surface.
    • If you are re-using the back cover, be sure to clean off any adhesive, and apply new back cover adhesive.
    • If you are installing a replacement back cover, be sure to compare it with the original part. Transfer any remaining parts (such as the flash diffuser) over to your replacement part.
    • Follow this guide to correctly apply new back cover adhesive.
    When reassembling is it better to first attach the new adhesive back gasket to the phone back or the phone chassis frame?
    Tom Burke - crwdns2934203:0crwdne2934203:0
    Hi Tom!
    It depends on the adhesive. Carefully align the adhesive to the phone by matching the contours. Note which adhesive side is backed by a clear liner, and which side is backed by a colored liner. The clear liner should be removed first. Whichever component the exposed adhesive faces should be the first surface to apply to.
    Hope that helps!
    Arthur Shi -
    Two things:
    1) I recommend attaching the adhesive to the Phone frame and not the back panel. As you attach, you can more easily see the gaps and guide the adhesive along the groove, leaving equal space all around.
    2) To transfer the fingerprint sensor, you will need double-sticky tape to make a new gasket. Put the tape on the back from the inside, and trim with a blade to make the sensor hole. To attach the sensor, place it on something small to raise it off your working surface, then lower the back over it. You’ll be able to see the sensor alignment as you lower the back, which helps get a good position.
    Gary Beardsley - crwdns2934203:0crwdne2934203:0
    Oh, and be prepared: Removing the old adhesive is teeeeedious!! It will take you some time. :-b Alcohol is not a strong solvent, so don’t expect it to remove much; it is mostly for cleaning afterward. In the end, I used one of iFixit’s flat metal tools from the big toolkit to remove the final remains. Its was blunt enough to not cut metal shavings as I cleaned.
    I used “medicinal” 91% Isopropyl Alcohol and about 30 Qtips to do the final cleaning of the adhesive, that is, after using a razor blade and the supplied tweezers to remove most of the tape. Patience and many Qtips soaked in IPA removed most of the remaining glue and film.
    Greg B -
    I ended up reusing the original adhesive as it was in pretty good shape. So far, no problems.
    Dan Comiskey - crwdns2934203:0crwdne2934203:0
    Does your IF356-119-1, Google Pixel 3 Rear Cover Adhesive, template use 2 sided pressure sensitive tape? Do I simply align it on the back cover and then press it to the device to reassemble the unit? If so, how long til the back cover is “glued” to the unit?
    Martin Seffens - crwdns2934203:0crwdne2934203:0
    Hi Martin,
    The rear cover adhesive is indeed two-sided PSA (pressure sensitive adhesive). Apply firm even pressure for a minute to bond the adhesive to the unit.
    Arthur Shi -
    When scraping the adhesive off the back cover be careful and don’t apply too much pressure (and/or position the cover against the surface so that it’s supported against the tool used), especially in the corners, or the glass cover rounded edges could break.
    Bart Oleksiak - crwdns2934203:0crwdne2934203:0
    Agree. BEWARE of SCRATCHING off the PAINT from the BACK COVER when cleaning !
    The back cover is painted glass it seems - using a razor blade to scrape off adhesive also scratches off the paint on the inside of the back cover, under the adhesive, and the clear lines it creates are visible from the outside of the back case. If you are using a phone case, this won’t matter.
    Greg B -
    My battery swelled and did all the hard work getting started popping the back open so I didn’t need the iOpener to get the back off, but now the iOpener is handy to heat up the sticky foamy factory original adhesive.
    I found isopropanol ineffective. I found heat softens it considerably. Just very warm, like hot water warm, is effective. Use tweezers or a plastic blade to help pull it off. Metal blades will either gouge the plastic or, worse, create metal shavings that will wreak havoc.
    Are there any solvents other than isopropanol that work and won’t harm the plastic? How do pros speed up this step?
    wsanders - crwdns2934203:0crwdne2934203:0
    I think pros often use heating pads or special jigs. They’d set the temperature, set the phone on the pad, and let the phone heat up for a few minutes. Heat guns are also a popular choice.
    Arthur Shi -
    I found that an opening pick worked well to scrape the glue off the inside of the curved edges of the back cover
    Richard Elder - crwdns2934203:0crwdne2934203:0
    The adhesive on mine took some effort to clean off all the way. During reassembly I did notice that my replacement back panel adhesive was larger than I expected and based off of product photos it looks like I received the 3 XL adhesive instead of the 3. That ended up having me fiddle with the adhesive to try and get it to fit right and unfortunately the camera side now has a bit of a gap that I can still press down on without having it stick. I’ll see how it stays but I fear I might have to get another adhesive. The guide was very helpful though!
    Craig Mileham - crwdns2934203:0crwdne2934203:0
    Does the replacement back come with all the sticky bits I need to replace it, including the fingerprint sensor, led and camers cover?
    I decided not to bother with new adhesive. The seal doesn't seem great but I tend not to drop my phone in toilets as often as other people.
    The actual back glass cover part is missing from the parts list and it appears iFixit doesn't sell it anymore.
    It used to be there, and I ordered one months ago and used this guide successfully then. I broke it again and the part is no more.
    Elijah Lynn - crwdns2934203:0crwdne2934203:0
  12. Google Pixel 3 Battery Replacement, Remove the screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five Phillips screws securing the wireless charging coil:
    • Two 1.9 mm screws
    • Two 4.2 mm screws
    • One 4.3 mm screw
    The top 1.9 mm screw can’t be totally removed — it comes out with the coil once loosened
    This was not true for me.
    Will Herrick -
    Can I leave the wireless charging coil out?
    This may also allow a bigger battery!
    Jex Webster - crwdns2934203:0crwdne2934203:0
    You may be able to! Note that this is not only the wireless charging coil, but also the NFC antenna (the upper loop).
    Arthur Shi -
    The 1.9 mm screws are actually screwed into the head of another screw beneath them. Sometimes the lower screw unscrews instead of the upper. That leaves both screws attached to the coil. If possible you should separate the two screws and screw the lower one back in first using a small flat blade screwdriver.
    If you decide to clean the wireless coil assembly, be aware that IPA will completely remove the printed 2-D barcode on the lower right. (Hopefully that's not important.)
    Bitt Faulk - crwdns2934203:0crwdne2934203:0
    There were 7 screws!!! The last two were both near the power button.
    Emily Viehland - crwdns2934203:0crwdne2934203:0
    Yes, I have that to, and a little black plastic part covering I port.
    ekan97Kingen (ekan) -
    l won’t mother board google pixel3 contact on WhatsApp +250783996430
    Nhimimana Glibert - crwdns2934203:0crwdne2934203:0
    Hey is there any potential way to accidentally damage the charging coil. Or is there something that needs to stick together? When trying to replace my phone batter, first the new battery doesn’t work, then when I swap to the old battery, my phone wireless charging charges, for a second then doesn’t work. When I disassemble and reassemble a second time it doesn’t register anymore. My phone still has battery so it turns on but now it has no way of being charged. I don’t use the usb port cause it gets clogged n is unreliable
    Adrian Ho - crwdns2934203:0crwdne2934203:0
  13. Google Pixel 3 Battery Replacement, Remove the charging coil: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and remove the wireless charging coil.
    There seems to be a small amount of adhesive holding down the camera-side edge of the coil. Used a spudger to peel it off...and some of the black film on the back side of the coil was torn away.
    Jacob Dziubek - crwdns2934203:0crwdne2934203:0
    Had some adhesive tape holding down the camera side of the coil. Used the tweezers and the spudger to carefully peel it off.
    Also has some adhesive from the back cover edge that caught on the black film at the top of the phone (above NFC coil) - VERY carefully scraped it off with the point of the spudger while gently pulling the coil assembly away.
    Stuart Clark - crwdns2934203:0crwdne2934203:0
  14. Google Pixel 3 Battery Replacement, Disconnect the battery cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 3 Battery Replacement, Disconnect the battery cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
    The connecton board is quete flexible … be careful otherwise other connectors may get looze.
    This is also valid when re-assemble … pusing battery conector may cause other conectors to “pop“.
    Tsanko Tsolov - crwdns2934203:0crwdne2934203:0
    The square connector directly below the battery connector came undone and will not pop back into place.
    Curtis Redfield - crwdns2934203:0crwdne2934203:0
  15. Google Pixel 3 Battery Replacement, Peel the black tape away from the battery: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Peel the black tape away from the battery: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Peel the black tape away from the battery: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Slide the point of a spudger in the crevice underneath the black tape bridging across the battery and the motherboard.
    • Slide the spudger along the crevice to pry up the tape from the battery side.
    • Carefully peel the tape from the battery and fold it out of the way.
    • The tape acts as a cooling pad for the motherboard and the battery. It will still work if it's torn.
    On my two-year-old phone, I found this tape tears VERY easily.
    Anyone know where I can get a replacement to this thermally conducting tape? Or some alternative to it? It tore right off without any hope of reusing the bit that was attached to the battery and now my phone is overheating constantly after doing this repair.
    David - crwdns2934203:0crwdne2934203:0
    tenía la misma duda y encontré este articulo the electrical tap will do just fine
    espero te sea útil lo voy a probar también.
    Manuel Lezcano -
    Amazon sells a 100mm X 200mm sheet of it you can cut to match the original profile with some tracing paper and an exact-o knife. Electrical tape is not appropriate for this. see my comment below.
    Kurt Nowak -
    Boy should I have read to be careful before I started this step.
    Yes, this step I think requires a replacement piece. This is a thermally conductive graphite sheet and is to transfer heat from the battery to the heat sink. Its very thin and I was not able to dislodge it as cleanly as it was described. And I disagree that it will still work if torn. You will essentially cut off a considerable amount of the heat transfer path of the tear is too big. Amazon sells a 100mm X 200mm sheet for about $11 which I cut to match the shape of the old one. I ended up making it even larger than the original on the battery portion to improve the heat transfer. And electrical tape is NOT an appropriate replacement, as it is a very poor thermal conductor.
    Instead of using the spudger, I used my fingernails and slowly worked the black tape from the lower edge. This worked; the tape remained intact.
    mediamonkey - crwdns2934203:0crwdne2934203:0
  16. Google Pixel 3 Battery Replacement, Disconnect the buttons connector: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Disconnect the buttons connector: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Disconnect the buttons connector: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the buttons connector from its motherboard socket near the left edge of the phone.
    • Push the connector and its flex cable out of the way of the battery.
    This step should absolutely come with a warning about just how fragile all ribbon cables like this are. I managed to break the volume rocker cable, I think while I was trying to pry up the battery. Make sure that's well clear of your working area when inevitably applying force to remove the battery. I'm lucky I didn't break the power button too -- at least volume can be controlled by software.
    Sean Carter - crwdns2934203:0crwdne2934203:0
    Care should be taken to ensure this cable stays out of the way during reassembly. It can easily become trapped under the battery and not reconnect.
    Mike - crwdns2934203:0crwdne2934203:0
  17. Google Pixel 3 Battery Replacement, Loosen the pull tab: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Loosen the pull tab: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Loosen the pull tab: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger underneath the black battery pull tab on the left edge of the phone.
    • Slide the spudger upwards along the edge to loosen the pull tab from the battery.
    • The battery is held in place with three separate stretch adhesive strips, which are connected to a single black pull tab. You can try to pull all three strips out together, but it is easier to cut the black pull tab where it is notched and pull each strip out individually.
    On very old devices, there’s a good chance these will just break before you get the strip out. The alcohol tip in the next step is quite likely going to be required.
    The "pull tab" on mine was transparent orange, like kapton, and not black.
    https://i.imgur.com/gFI1gyD.jpg
    (Sorry for the lousy photo. Normally, I'd use my phone, but…)
    Photos showing use of the kit adhesives for the battery and case would have been most helpful. Thanks.
    Loretta Divine - crwdns2934203:0crwdne2934203:0
    Instead of using the spudger, I used my fingernails and slowly worked the black tape from the edges on the right. This worked great.
  18. Google Pixel 3 Battery Replacement, Remove the pull tab: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the pull tab: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the pull tab: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around some tweezer tips and continue pulling.
    • If the adhesive strips break, use an opening pick to help pry up and loosen the battery.
    • A flex cable runs underneath the battery. Don't pry near the cable, or you may damage it.
    • You can also fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
    This was pretty tricky for me, required a reasonable amount of force as the bottom of the 3 tapes shown above ripped straight away, so I couldnt stretch to de-sticky it. There seemed to also be a fourth piece of adhesive on the bottom most part of the battery which was not shown in this guide, and did not have an external tab.
    I also had issues with this step. The tweezers immediately caused the tape to break on all three strips (after working with my hands for a while) and prying up the battery was tricky with ~1/2 of the adhesive still in place.
    Same here, all three strips broke with most of them left in place under the battery. The small foam buffer block from the left edge of the battery mentioned in the next step broke while I was working on removing the battery with the opening !$$&*.
    same issue here … just pry the battery and hope for the best :)
    I have iFixit plastic card (from MacBook battery replacement kit) … it made me more confident while removing the battery.
    This was the hardest part of the repair for me. I wasn’t able to pull these out without them tearing. I would definitely elaborate more on how to do this in different situations.
    joshua kolash - crwdns2934203:0crwdne2934203:0
    Yeah, if you are going to have a catastrophic battery melt down, this will be the step. If your phone is older, those tapes will not stretch enough to release and you will need to gently pry. Watch your fingers and keep some water near by. Why on earth they feel the need to GLUE the battery down I will never understand.
    Meredith Everett - crwdns2934203:0crwdne2934203:0
    I tried adding some heat to the front.. I don’t know if that helped, but this is definitely the most physically forceful part. After my adhesive broke, I pried the battery up and was able to us the spudger to poke at remaining adhesive and break it apart manually.
    Noah Garrett - crwdns2934203:0crwdne2934203:0
    Haven't seen anyone post anything about this, but be careful when you pull the battery up if the adhesive didn't fully come out. Mine was stuck to the ribbon cable for the "squeeze for google assistant" buttons and tore it as I pried the battery up. If you're careful you may be able to loosen the adhesives grip on the ribbon cable before pulling the battery out.
    Ben Lyons - crwdns2934203:0crwdne2934203:0
    I used 99% isopropanol (not the normal 70% that's available at a pharmacy; try a hardware store) to soften the remaining glue and had basically no problems at all. Just slow prying and it took less than a minute. I've used 99% IPA before and found that it works significantly better than 70% IPA for de-sticking glues. But it's also possible that I got lucky.
    If your glue is stuck (like mine was), be mindful of the ribbon cable for the volume buttons at the top left corner of the battery when you are releasing the adhesive. I applied a little too much force and the pick cut through that cable.
    Peter Madigan - crwdns2934203:0crwdne2934203:0
    I was very lucky and this came out very easily using the original pull tabs.
    I was very lucky and this came out very easily using the original pull tabs. Putting it back in though was a different story. Make sure don't forget the little rubber filler block on the lower left side of the battery. Also I completely botched the adhesive and tried to install it with both backings removed. Don't attempt this - or you will be cursing like a drunken sailor. I ended up getting a new one instead of the double sided tape which doesn't hold as well IMHO. Cut the whole thing down down to a size (with both backings on) of where it will be placed and trim off the backing at the pull tabs so it will flex into place when the lower (phone) backing is removed. Also make sure you side the battery all the way down to the bottom to give the power cable enough length to reach the socket. If its at the top, the cable wont reach and will perhaps put too much stress on the connector.
    What you don't mention is the ribbon cable than runs underneath the battery. The plastic pry that I used to get underneath the battery damaged the cable so now the phone is junk,
    Fffs - crwdns2934203:0crwdne2934203:0
    I'm sorry to hear about that! I'll add a caution bullet to the step.
    Arthur Shi -
    For me, it helped to work from the bottom edge near the charging assembly. Removing the loudspeaker at the bottom also helped. Prying from the side was definitely nerve wracking.
    bhurwitz - crwdns2934203:0crwdne2934203:0
    Would have been nice to know about the flex cable in the previous step.
    The iFixit Kit has a plastic dropper (for isopropyl alcohol, which isn't included). Drop some alcohol on the white pull tab to weaken the adhesive (the alcohol weakens the adhesive, but not the white plastic). Repeat this process along the tab until it comes off.
    If the tabs break, use the pick on the left side of the battery. Be careful not to damage the flex cable. Lift the battery slightly and, using a flashlight, check where the tabs are still stuck. Apply alcohol to the stuck parts and gently lift the white tab plastic with a popsicle stick, while continuing to gently pulling the tab and battery. Repeat until the battery is removed. If you can see the pull-tab adhesive is stuck to the flex cable, you need to tackle that first.
    So this is my third time having to remove the battery on this device (once for the screen, once for the battery, and now for the charging assembly). Dropping a little high-percentage IPA into the left side of the battery worked like a charm! The tabs immediately tore, as they always do, but after letting the IPA sit for 30 seconds or so, prying the battery up from the left with a pick was super easy. Just let everything dry before applying the new adhesive. Maybe it was just that my adhesive had only been sitting for like six months.
  19. Google Pixel 3 Battery Replacement, Remove the battery: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 3 Battery Replacement, Remove the battery: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
    • Carefully pull and remove the small foam buffer block from the left edge of the battery and transfer it to your replacement part. If it begins to tear, use the flat end of a spudger to gently pry it off the battery.
    • To install a replacement battery:
    • Lay some double-sided tape in the phone's battery well. If you're using Tesa tape to reattach components, follow this guide. If using stretch-release adhesive, follow this guide.
    • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
    • Peel away any tape liners to expose the adhesive.
    • Lay the battery on the adhesive and press firmly.
    • Disconnect the battery connector from its motherboard socket and resume re-assembly.
    It’s very easy to tear the foam block off from the adhesive backing strip that holds it to the battery; I think it’d be good to talk explicitly about how you need to get under that adhesive strip if you want to re-attach it to the new battery… I think friction will work to hold mine in place, but I do wish I’d known that would be an issue.
    I also found installing the new adhesive strips to be next to impossible. For other folks trying this with the iFixit adhesive strips:
    Just cut the three strips apart as you remove them from the packing plastic; you only want to deal with one strip at a time. You will probably never get them apart (without stretching them out of shape) if they stick to eachother.
    Hi Eugene,
    Thanks for the comments! I’ll adjust the step to include your suggestions.
    Arthur Shi -
    Directions/photos on how to use the iFixit adhesive strips would have been nice. I wish I saw your comment first.
    drlarsen -
    Yeah, I completely ruined my adhesive strips. It would have been nice to have a step for that. I ended up using some double sided tape.
    Oh, and not to mention that there’s basically no way to get the foam to come off the old battery without destroying it. So, I used a small piece of rolled up tape (not squished completely so it has some springiness) and taped it to the battery.
    Kyle Barr -
    I failed with these too. The backing came off and I put it back, but then I couldn't remove the backing! Maybe I accidentally turned the backing over? Photos of this step work let be really useful. I ended up using the tape from the smallest size 3M command hooks i could find. They are thin, easy to adhere and have a tab to remove by stretching.
    Dharman Gersch -
    Same here. I ended up having to order a second one. Cut it down to the size and trim off the potion of the backing at the pull tab. It wil. go in much easier. I hope they change the instructions to state this part.
    Kurt Nowak -
    The battery lateral position is captured between the foam block on one side, and the long black arm portion of the charging coil on the other side. So before setting the battery in place, be certain to temporarily insert the charging coil.
    rossh - crwdns2934203:0crwdne2934203:0
    When removing the battery it can (and did for me) catch on and disconnect ALL of the connectors on the right-hand side. Remember to verify ALL connectors are properly seated.
    Chuck - crwdns2934203:0crwdne2934203:0
    Very good description. Battery replaced and working perfect! Thank you!
    Marius Johansen - crwdns2934203:0crwdne2934203:0
    Seconding Chuck’s comment about making sure the connectors are slotted in at the end. In my case, the primary connector for the battery was finnicky plugging in, and I didn’t realize that it hadn’t actually clicked into place. Spent a couple days with my phone randomly powering down because the battery was touching the board just enough to turn on, but slight movement would jostle it out of place.
    I was getting pretty worried until I took it all apart again and had the realization that it was never fully plugged in. No problems since (knock on wood)
    Bennie Waters - crwdns2934203:0crwdne2934203:0
    What happens if I break the black foil tape on the top of the battery while peeling back? I notice there is a plus and minus positivity area on the battery here. Is this conductive tape? Will it not work if this area breaks?
    Brenton Cooper - crwdns2934203:0crwdne2934203:0
    Hi Brenton
    The tape acts as a cooling pad for the motherboard and battery. It does not need to be in one piece to do its job.
    Arthur Shi -
    This is thermally conductive graphite sheet and transfers heat from the battery to the heat sink. Ripping it WILL diminish the heat transfer capability and you'll end up having overheating problems. Amazon sells a 100mm x 200mm sheet for $11 which I cut to match the original. Do not use electrical tape. Plastic is a poor heat conductor.
    Kurt Nowak -
    Had a bulging battery and during removing the adhesive behind it I cut through the bottom portion of cable leading to the buttons.
    All of this glue is an unnecessary part of smartphone design. I’d rather see a few screws in my phone (which always has a case on it) then ruin my phone attempting a repair because the designer thought it’d be a good idea to pinch this cable between two pieces of metal next to where they used tons of adhesive to make the battery so difficult to remove. We need a right to repair law in place already.
    Nothing negative to iFixit. Directions and supplies are top notch.
    Kris Oliveira - crwdns2934203:0crwdne2934203:0
    Edit: Ends up the phone works but the volume keys do not, so that’s a plus. I’ll have a functional phone until I replace the cable.
    Kris Oliveira -
    For some reason after replacing the battery, the pixel is stuck on G. it booted once and showed “battery not readable”. and now its not booting. Any help will be appreciated.
    Ankit Agarwal - crwdns2934203:0crwdne2934203:0
    Hi Ankit,
    If you still have your original battery, please try plugging that in and booting the Pixel. If it works, you may have a defective replacement battery. If you bought the replacement from iFIxit, please contact our customer support and we will get the issue resolved!
    Arthur Shi -
    So these days they send you replacement tape (instead of needing to find some double-sided tape like the directions mention). Unfortunately, it *sticks* to one side of the film it’s shipped in, so strongly, that you’ll deform (if not completely ruin) trying to get it off. so yeah, i had to go buy some 2-sided tape. :(
    emiro99 - crwdns2934203:0crwdne2934203:0
    Agreed. The directions are a bit misleading:
    I think the proper way is to leave the liners in place. Test seat the new battery. Then peel one side of liner off. Stick the tape to the phone. Then, peel the second protective liner. Then place the battery.
    If you try to peel the adhesive off of the liner, it snaps back on itself and is stuck to itself and is a goner.
    Noah Garrett -
    Agree with this comment, and Noah's comment too, however solutions offered (other than buying regular 2-sided tape) did not work for me.
    I wanted to remove one liner on the ifixit provided adhesive replacement tape, place it inside the battery well and then remove the second liner. However, the liner that needs to be removed to be able to stick inside the wheel well is not the first one to come off, it's the other one that does! So I tried to remove both liners and yeah I made a mess of my adhesive strips, it's a nest of adhesive tape below my new replacement battery but it’s holding up fine.
    Adarsh Viji Elango -
    Thanks for the suggestions! I’ll adjust the wording slightly to correct this.
    Arthur Shi -
    Just FYI, the foam buffer on mine was disintegrated and would crumble at the slightest touch, perhaps due to age and heat. So I guess I’ll use double stick foam tape. Hope that doesn’t create issues. Otherwise good tutorial, great pictures and tips.
    lars sveen - crwdns2934203:0crwdne2934203:0
    Definitely need some kind of direction on how to use the iFixit double sided tape. I think I pulled the wrong side of the liner off of the tape and realized after the fact that it was backwards in how it goes in the phone. Too late. Once you pull that liner off, you can’t put it back on to flip and use in the correct orientation - the tape is now stuck to the liner and won’t come off. I now need to use my own double sided tape.
    Chris Nunamaker - crwdns2934203:0crwdne2934203:0
    Thanks for the feedback! I added a link in the last step with some adhesive instructions.
    Arthur Shi -
    I had this problem too. Specific instructions on using the ifixit tape that ships with the battery are needed. The link is to a generic Tesa tape guide and not relevant to this special stretchy stuff.
    Dharman Gersch -
    Note that the iFixit’s pre-cut adhesive needs to be placed on the back cover and then the cover placed onto the phone. I highly suggest only peeling a little bit of the white liner off a corner, lining up the entire pre-cut sheet on to the back of the phone, sticking the corner down, and then peeling away the rest of the liner. Then plug in the fingerprint scanner, removing the blue plastic liner from the adhesive(you’ll have to cut it because the fingerprint scanner cable is in the way, and finally put the back cover onto the phone.
    Dan Higginbotham - crwdns2934203:0crwdne2934203:0
    And why do we even need to re-add battery adhesive? Everything seems pretty tight in the phone when it’s closed up. I totally ruined my adhesive strips during the repair and just said screw it and didn’t use any at all. No problems with my phone so far.
    nobodycares - crwdns2934203:0crwdne2934203:0
    Good question!
    For safety reasons, you need to re-attach the battery with adhesive. Lithium-ion batteries are fragile and can be volatile when they’re charged. If the battery is loose in the battery well, there’s a good chance that an edge or corner will eventually be damaged from daily use, resulting in catastrophic battery failure.
    Arthur Shi -
    I wish there were explicit reassembly instructions for the parts that were not in the disassembly. I did not notice the tabs that were supposed to go underneath the battery until I was finished reassembling everything. Additionally, I had trouble with the sticky backing for reattaching the back of the phone.
    Overall, other than some reassembly mishaps, I had the most trouble getting my back off (I had to use a knife as the plastic tools kept bending) and the old battery out. For the latter, it is important to notice that the glue, at least for my phone, was only on the top of the battery. So, prying the battery out from the bottom was easiest.
    Alexa Lupi - crwdns2934203:0crwdne2934203:0
    I completely botched the adhesive and tried to install it with both backings removed. Don't attempt this - or you will be cursing like a drunken sailor. I ended up getting a new one instead of the double sided tape which doesn't hold as well IMHO. Cut the whole thing down down to a size (with both backings on) of where it will be placed and trim off the backing at the pull tabs so it will flex into place when the lower (phone) backing is removed. Also make sure you side the battery all the way down to the bottom to give the power cable enough length to reach the socket. If its at the top, the cable wont reach and will perhaps put too much stress on the connector. Also don't forget the little rubber spacer block. My new battery didn't come with a new one and had to use the one from the old battery.
    I hope the battery will last. I received it at 0% ....
    Thomas - crwdns2934203:0crwdne2934203:0
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
crwdns2935229:0170crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
301,327 crwdns2915208:0crwdne2915208:0
crwdns2935297:0687crwdne2935297:0
Staff
crwdns2931471:0118crwdne2931471:0
crwdns2935297:022,658crwdne2935297:0
crwdns2947412:053crwdne2947412:0
Removing the adhesive from the rear glass can be a tedious process. I got my best results by taking fine point tweezers and pulling the adhesive back slowly, trying to get it to come up altogether as much as possible before using IPA to remove any residue.
Brody Mistrot - crwdns2934203:0crwdne2934203:0
How do you put the adhesive back (or put new adhesive on) when putting the phone back together?
Brian Ferraro -
@bfferraro, it depends on the type of adhesive.
If you are using a pre-cut adhesive sheet, follow this guide.
If you have a custom-cut adhesive, follow this guide.
Arthur Shi -
What thickness(es) of tape is/are required to complete the battery replacement process?
mpc - crwdns2934203:0crwdne2934203:0
Hi mpc,
The tape does not need to be thick at all. You can use standard double-sided tape, or the fancier stretch-release adhesive.
Arthur Shi -
I actually used command strips (the thin kind, that are clear, not the foam type ones) so that maybe it'll help the process if I ever have to remove the battery again. Hoping they keep working well, so far so good!!
Rachel DeGouff -
What adhesive is used to reapply the back to the phone when this is done?
David Gunter - crwdns2934203:0crwdne2934203:0
Hi David,
Double-sided adhesive such as Tesa tape works well.
Arthur Shi -
It looks like the 2mm width would be ideal for this, for future reference.
William Kew -
I just finished the Pixel 3 battery replacement. This guide covers all the steps well. For re-attaching the back to the case I used the 1 mm width tape available from this size. The precut card was not available at the time I was ordering parts. I guessed on 1 mm but after using it, it seemed to work well. I cut long, straight lengths for the sides and top & bottom, and then filled each corner with a short piece placed diagonally. Seemed to hold ok.
Thank you for the excellent guide.
mpc -
Thanks! Straightforward repair with this guide.
The warning about breaking the fingerprint sensor cable is important. I didn’t break mine… :-)
Wayne Seltzer - crwdns2934203:0crwdne2934203:0
I had one small issue with putting all of it together. If you want to test the wireless charging you need to put a little space between the coil and the charger. I suspect their is a minimum distance between the coils to get them to couple properly and without this the charger talks to the phone but does not start charging.
notstarman - crwdns2934203:0crwdne2934203:0
Unfortunately my phone won’t boot correctly after replacing the battery. Fastboot Mode with Device-State: error! I must’ve damaged something while trying this process. Be careful, folks!
Matthew Quinn - crwdns2934203:0crwdne2934203:0
After this procedure, my phone started and worked, then began continuously rebooting when I pressed the power button to try the camera. Like the power button was stuck pressed, but it wasn't pressed and the procedure doesn't touch the switch and I couldn't see the issue even under a microscope. But I removed the battery and reinserted it against the edge opposite the power switch as far from the power switch as I could. Seems to be working now, I conclude the battery was pressing against and bending the back wall of the power switch. Insert the new battery positioning it against the compartment-edge opposite the power switch!
Student4Life -
I’m having to replace the back glass as it cracked and i’m thinking of replacing the battery as well since I think it has swelling.
Do i need to be as careful removing the back since I’ll be replacing that anyway, or is there still a difference between the back glass and the battery door?
Cabroncito - crwdns2934203:0crwdne2934203:0
Hi Cabroncito!
The battery door/back glass are the same. You don’t have to worry about cracking it, since it’s already cracked. Be careful not to damage the fingerprint sensor cable shown in step 1! Replacing the battery at this point is a great idea! Good luck with your repairs!
Arthur Shi -
Process went pretty smoothly. Only real issues I had were putting the new battery adhesive on (I got it all tangled before I set it in place). Removing the old adhesive was a bit annoying as well but after all that, it went together well and works. Thanks for the great guide!
Corey Maeltzer - crwdns2934203:0crwdne2934203:0
Great guide, I had to check a youtube video too (extra caution). However, the main reference was this guide, thanks for the help. The rubbing alcohol (+90%) is a must, I can stress enough how complicated/slow was to remove the adhesive from the phone.
Chrystyan Parada - crwdns2934203:0crwdne2934203:0
I feel that some instruction advising how to apply the adhesive for the battery would be helpful. I took mine off the protective film thinking that it would hold its shape and it immediately folded on itself. I was able to salvage a piece to hold the battery, but I consider that step a failure for me. Plus, showing how to clean the old adhesive from the back panel and applying the new adhesive would be helpful too.
Overall a really helpful guide that helped me to get the job done. Thanks!
Trey Ethridge - crwdns2934203:0crwdne2934203:0
Half an hour ago I had a bulgy battery and some raging fear. Now I have a working phone and I can’t thank you enough for this guide. I feel like a tech wizard! (with a menacing fat old battery that I need to find a place to recycle….)
Seconding/thirding the commentary on the included adhesive strips for the battery being difficult - mine also immediately curled into themselves. I used a small bit of mounting tape instead and that worked just fine. A classic case of problems between the keyboard and chair. The new back panel adhesive was easier to deal with (remove protective film on one side, align and press, then remove the other film), though removing the old stuff was a chore and a half even with 91% alcohol; it had been on there for several years.
Sara Patrick - crwdns2934203:0crwdne2934203:0
Oh, I guess I only commented on the battery step, not the whole article. Well, here it is again:
Welp. I followed this tutorial to a T, but now my phone’s display is completely broken and there is a hissing a popping sound towards the bottom of the phone, accompanied by a very hot spot on the display area where that hissing is coming from. This was after it booted fine, but with about 1/3 of the total area the screen covered in vertical lines from left to right.
I have a feeling this may have been due to the isopropyl alcohol step (which was basically the only way to actually remove the adhesive from the battery).
I am just not sure what to say. I followed the steps as closely as possible, and I made sure to dry the isopropyl alcohol beforehand.
I do not think I will ever work on a phone again. Probably safer to just hope you still have a warranty, or buy a new one.
Kyle Barr - crwdns2934203:0crwdne2934203:0
Really dumb that I can’t edit my comments after 5 minutes.
Update: I let it sit overnight, put it back together again, and it was able to mostly work, less a green line or two in the OLED screen. I’m wondering if there was a mix of isopropyl alcohol and me pressing the back closed caused the OLED to go nuts. This is fine for now and I can use the phone again, but I still don’t plan to try to fix any phones again.
I will add: IFixIt’s guides are pretty awful. There’s no reason that the guide should have ended at removing the battery. There were crucial steps like, how to fix the adhesive for the battery and phone, recommended way to seal the phone back up (to ensure you don’t break the OLED screen). I even looked at the OLED replacement tutorial and the farthest it got was removing the screen. I guess it expects you to guess how to put it back together by walking back through the tutorial, which mostly doesn’t work.
Kyle Barr -
Thanks for the great instructions!
After replacing the battery, the screen on my phone would not come on. I was worried I might had disconnected the display connector, so I opened the phone up again. Turns out all you have to do is to reset the phone. To do this, press and hold the power button for about 10-15 seconds. The screen will turn back on with the Google logo showing.
Cheers!
Torgeir Helgesen Riseth - crwdns2934203:0crwdne2934203:0
Hi, I have spent hours trying to get my pixel 3’s back cover opened following this guide and also with the hair dryer to the point where the phone’s back cover around the bottom edge is very very hot (could only place my finger on it for a second or so). Also tried other suction cups and the cover just didn’t budge at all and my fingers and hands gave up.
Anyone maybe have other ideas to share? I am using the ifixit repair kit that included the Pixel 3 battery and the phone is about 2.5 years old and has never been taken apart/repaired.
Thank you!
Hi Thomas,
The Pixel’s adhesive is pretty tough! Slightly too hot to the touch (where you can place your finger on for a second) is the right temperature. You may need to do multiple heat/suction cycles to loosen the adhesive enough to create a gap. You can also try the top edge, where the adhesive is slightly thinner, or the left edge, where the longer adhesive may loosen faster. Good luck with your repairs!
Arthur Shi -
I replaced the charging circuit and battery at once- now I plugged in the phone while still open to confirm charging, but I’m not seeing any indication on screen. Should I be able to verify things without putting everything back together?
David Gorelik - crwdns2934203:0crwdne2934203:0
Make sure the ribbon cables have firm connections. I had gotten the phone mostly reassembled before realizing that the charging assembly ribbon cable wasn’t seated properly. Re-assemble the charging assembly, replace the speaker and screw it down before plugging in the charger (or be VERY careful). The battery should also be plugged in, and you should see a battery indicator on the screen w/the current battery level. If the battery is too dead, give it a couple minutes to charge.
Chad Walstrom -
Arthur Shi, you made this replacement exceptionally easy! I loved the color coding of the screw sizes. iFixit, your battery replacement kit had almost everything I needed. I did supplement the small alcohol pad you supplied with some 91% isopropyl alcohol and cotton swabs to clean all the prolific glue left on the back cover and chassis. The only difficult part I had was trying to remove the glue strips under the battery. I managed to get a cotton swab with alcohol underneath it to dissolve the persistent hold. Thanks so much! New battery and new charging assembly installed! Now to find a safe place to dispose of this swelling battery!
Chad Walstrom - crwdns2934203:0crwdne2934203:0
Hey Chad! Thanks for sharing your success story and feedback! I’m always glad to hear a repair go well :)
Arthur Shi -
I’m just about done with this repair. I’m at the point of using the supplied adhesive cut out to re-install the back. Though the instructions are good for disassembly, the reassembly instructions that just say repeat the steps in reverse order is insufficient for a such a kit. As many have said above, there are some tricky steps to re-assembly that are completely missing. The IFIXIT is not DONE until the re-assembly is complete. So, these instructions are about 65% sufficient to complete the job. Please “finish” the instructions with clear descriptions and photos of RE-ASSEMBLY. E.g. the battery tape, the back cover tape and how to deal with the fingerprint sensor cable, etc.
P.S. the most difficult part is removing the back glass cover. I ended up using a hair dryer on high heat / low fan and a rectangular utility razor blade. Start at the bottom, heat and cut the adhesive a little at a time, as the cover comes off insert the blue plastic separators that come with the kit. Patience is key.
Greg B - crwdns2934203:0crwdne2934203:0
Did anyone’s Pixel 3 get into battery meter issue after battery replacement? I replaced the battery, but the battery meter icon on the notification bar with issue. It cannot detect the battery percentage. I tried to soft and hard reboot. The issue still there.
Christie Lin - crwdns2934203:0crwdne2934203:0
Thank you for the guide. I used it since my Pixel 3 battery pushed the backplate cover and created a gap along side the power and volume rockers.
The only part that I messed up was applying the adhesive to the battery (I pulled off the three strips by hand which made them curl up instantly and ruining then). Also user error, I some how messed up the lower volume rocker and it does not work anymore after I sealed it up.
One criticism is to include a guide on how to reassemble, specifically regarding adding the adhesives (to the battery AND to the back case cover).
Chris - crwdns2934203:0crwdne2934203:0
Great tutorial. Unfortunately for me, removing the glue tapes under the battery damaged the ribbon cable spanning the phone from side to side. I cant find spare for one of these - do you know where to get one? <
Nigel - crwdns2934203:0crwdne2934203:0
Just attempted on my Pixel 3 (to replace a battery / device never previously opened) that I bought shortly after it came out. BEWARE adhesive seems to become more permanent after a significant amount of time. Heat gun like above would be appropriate, probably, as I couldn't get the back off with just the hot pack. I ended up breaking the back. Easy, just tedious, especially on older, unopened devices.
Jacob Kamholz - crwdns2934203:0crwdne2934203:0
I replaced the batt. But in the process the volume ribbon cable broke. Is that hard to replace?
John Lam - crwdns2934203:0crwdne2934203:0
Excellent guide. However, the heat and suction cup just wasn't doing it for me. I ended up using the iFixit Jimmy rather than the pick to get between the back cover and the rest of the phone. Once that was in, I was able to switch back to picks.
Nicholas Holdgate - crwdns2934203:0crwdne2934203:0
My screen is showing bright green and is seemingly unresponsive to anything. Hoping too much isopropyl alcohol removing the glue but worrysome that some damage happened. Anyone have any ideas?
Jon Bosche - crwdns2934203:0crwdne2934203:0
now stuck in fastboot with a corrupted image
Jon Bosche -
Hey I just got mine in the mail and have been trying to replace the battery but the cord connecting the phone back to the battery wont connect back to the plug. I have the exact same model as was originally in my phone however the connectors slightly differ. Anyhow I can not for the life of me get the new battery to connect.
Phoenix Keener - crwdns2934203:0crwdne2934203:0
Hi Phoenix!
If your original battery still connects to the phone, then the replacement battery's connector may be damaged. If you bought the battery from iFixit, please contact our customer support and we will get the issue resolved!
Arthur Shi -
Info here was very helpful. LOTS of warming, and then a steel blade to get a small crack going that you can slide a plastic tool into. Main challenge was figuring out how to replace the adhesive at the very end. Everything went smoothly until that part and while was able to recover, i did mess it up. So pls add one more instruction "page" to "close" the deal!
Robert Berley - crwdns2934203:0crwdne2934203:0
After reading this guide, the comments, and watching a few videos online, I felt prepared to attempt this repair. I spent, no joke, probably 5 or 6 total hours trying to carefully open up this phone using the toolkit and some dental floss. I finally got a pick carefully inserted into the rear and the back glass shattered all the way up the rear of the phone. Hot glass shards in my hand.
By far the most difficult repair I've ever attempted. Surprised it is rated as "Moderate" difficulty.
It's ridiculous that Google manufactured a phone that is so difficult to repair (making a phone body out of glass????) and a bit disingenuous of the iFixit staff to make this seem like a repair that can be completed with just the tools provided in this kit.
I wish I hadn't wasted my time and money.
Travis Gysegem - crwdns2934203:0crwdne2934203:0
Agreed. The devil is in the details behind this painful procedure. Some of the videos were very unrealistic.
Kurt Nowak -
My phone lost connection from charging cord to the battery. Wish I had a solution to this problem. I lost all my contact info. Got a new iPhone, wishing now I’d have gotten the pixel 6.
Frederick Johnson - crwdns2934203:0crwdne2934203:0
In addition, I replaced the battery, couldn’t get it to charge. What a POS. Great phone while working but crazy to repair it. Yeah, glass case is nonsense. Sure wish I could get it to charge so I could retrieve my contacts etc.
Something that drove me crazy was the dust/residue/stains on the inside of the camera protective lens. After all, this is my main picture phone! Here is what I ended up doing in the end:
0. Wait until you are ready to sandwich the back glass to the frame
1. Drop some alcohol into the protective lens box
2. Wipe down the lens with a lens wipe, pushing it in with a spudger
3. Drop alcohol AGAIN
4. Blow it out with a blow dryer
5. Quickly sandwich the back on
Crystal clear, no dust, no residue, no water stains!
Vladislav Ekimtcov - crwdns2934203:0crwdne2934203:0
Man that was a pain in the a$$. This is not an easy process - was a horrible design - clearly tis phone is not designed for serviceability. BE PATIENT, especially with the back glass. It will shatter if you force/rush things. Use a thin plastic (clamshell material) to cut and easy on the pulling with the suction cup. Use the picks to prop open the edges you've already opened.
Also test the phone before you press the back glass back on. Make sure the finger print sensor works before you do that too. The last thing you want to do is take the back glass off again.
But I ended up being successful in the end....
Kurt Nowak - crwdns2934203:0crwdne2934203:0
Part 1/3
The adhesive replacements are no joke! Both the battery adhesive and the back panel adhesive are super unintuitive.
For theBATTERY ADHESIVE, I followed the guide in the link for that section. First pull off the section that adheres to the battery, line up the black tabs to where they are supposed to go, then with the backing to the phone side still in place, roll and press the adhesive to the battery.
STOP here, do not remove the phone side adhesive cover yet!
First, place the battery in the battery well and connect it.
Next, reconnect the power button.
Next, plug in the phone (the battery has no charge from the factory). Wait a few seconds to see the battery charging symbol come up on the screen. Turn on the phone and let it boot. Then with 2% battery available, unplug the phone.
If it stays on, you did it right! Now turn off the phone, Keep the battery plugged into the motherboard, remove the phone side battery adhesive cover, and stick it in place with the battery still connected. Done.
Daniel Yoder - crwdns2934203:0crwdne2934203:0
Part 2/3
NEXT, the back panel adhesive that comes with the I-Fixit kit. There may be instructions on the website somewhere, but I couldn't find them.
The kit adhesive is super awesome! It takes 3 steps to install. There are 3 layers of plastic adhesive covering: Layer 1: Clear (top half and bottom half). Layer 2: Blue. Layer 3: Red.
First, make sure that the back cover and phone are completely clean of all leftover adhesive residue.
Next, find the correct orientation for the adhesive: Blue facing you with the notch pattern for the power button in the top left.
Then, pull off the top half of the clear layer and carefully line it up with the surface of the phone (use the screw holes as a guide). Don't press down yet. Lay the whole assembly down to check for proper alignment.
Once you have the correct alignment, starting from the top, slowly lay the top half down about halfway, like reverse peeling.
Then remove the bottom clear layer and continue.
Part 3/3
Now the adhesive should be firmly stuck to the phone side; it is now safe to remove the blue layer - this will not expose any adhesive, the blue layer is just for support.
Next, (DO NOT REMOVE THE RED LAYER YET) it's time to plug in the fingerprint sensor and reattach the little black bracket that holds it in place.
Then, double-check the phone for functionality. Plug it in, turn it on, test the fingerprint sensor, the power and volume buttons, and check out the camera - make sure you didn't smudge the camera lens or get dust/adhesive on it.
If that all works, remove the RED LAYER and carefully place the backing onto the phone. Done!
I used the I-Opener heater on the phone for a few minutes to help the adhesive bond, then placed the phone flat on my desk with some hardback books on it overnight. I also plugged it in.
This was a 2nd time I replaced battery for Pixel 3. I had replaced another Pixel 3 battery 1 year ago. Almost no problem, getting the back off. This 2nd time, it was 3 hours of frustration to get the back off. The comments were excellent. I 1st used the heating pad provided by Fixit, then a hair dryer. Then a heating gun. Still no gap to insert the "guitar pick". Per comments I tried a metal blade, a small screwdriver, various dental floss. Still no go. I finally got an opening with a steel blade in the bottom corner. But, the glass back broke. After carefully removing pieces of the glass bottom, I performed a "post mortem" on why so difficult to remove the back. Answer: the adhesive used to hold the back in place was 5x as thick near the bottom where the USB charger connector was compared the the 2 vertical edge 1/2 the distance from the top/ bottom. In hindsight, it would be easier to start the gap at the vertical edges of the back where there was significantly less adhesive.
Ahay - crwdns2934203:0crwdne2934203:0
It took significantly longer than what the guide suggests (40 minutes to an hour) - for me end-to-end was around 3 hours. The hardest part was removing the back, because just with the suction cup and the included plastic pry tools I couldn't get started. Then I resorted to a thin and sharp utility knife that managed to cut through the glue, from then on it was a walk in the park. Also make sure to have some isopropyl alcohol at home before starting to clean up the nasty glue residue. Lastly, take your time, because after finishing I cannot tell from the outside that it was opened. I'm really impressed! Thanks a lot for the kit and for putting this guide together!
baliika - crwdns2934203:0crwdne2934203:0
The adhesive that it came with was great (it fit perfectly), and the process wasn't too painful. Took about 2 hours or so, with me swapping the charging module as well. Trickiest part was the initial opening (though it wasn't apocalyptic for me like it was for some others - just patience, multiple heating cycles with the iOpener, and the right angle of attack) and removing the battery (those pull tabs are not obvious and not helpful - I ended up prying it up from the bottom edge).
While the battery and charger port work now, I managed to break the screen at some point, which may have been when re-installing the battery, so be careful. Something soft and flat under the phone is a good plan.
crwdns2936751:024crwdne2936751:0 30
crwdns2936753:07crwdne2936753:0 249
crwdns2936753:030crwdne2936753:0 1,087
crwdns2942667:0crwdne2942667:0 185,708
