Fix unstable bluetooth connection
  1. Fix unstable bluetooth connection, Heating up the lid: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up the lid by leaving the earbud upside down on a hotplate at ~80°C for ~1min. A 3d printers hotbed works well for this.
    • A heat gun should also work as well.
  2. Fix unstable bluetooth connection, Breaking the seal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The earbuds are glued shut.
    • Put some cloth around the earbud and put it in a vice like shown.
    • Pliers might work too if you don't have a vice but it's not recommended.
    • Slowly close the vice until there is a cracking sound or a gap forms in the seam.
  3. Fix unstable bluetooth connection, Removing the lid: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up the lid again before continuing.
    • Separate the 2 halfs using one of the opening picks.
    • Make sure not to press the pick more then ~1mm into the case to avoid damaging anything on the PCB.
    • Slowly lift up the outer half after cracking the seal around the whole earbud. Slowly pull them apart as there is some flexible adhesive on 2 internal pegs that takes a bit of time to "give up".
  4. Fix unstable bluetooth connection, Secure the mic cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The marked mic cover tends to easily get lost. It's best to take it of and store it with the top half until reassembly.
  5. Fix unstable bluetooth connection, Scrape away old glue: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Try to remove as much of the hard, clear glue on the outside edge to make sure the buds close nicely when reassembling them.
    • A precision rotary tool with a fine abrasive tip and/or a scalpel works best.
  6. Fix unstable bluetooth connection, Remove old glue: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Try to remove as much of the white glue as possible using a scalpel and/or tweezers.
    • Putting the lid back on the hotplate or a bit of Isopropanol can help softening it.
  7. Fix unstable bluetooth connection, Lift antenna: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fix unstable bluetooth connection, Lift antenna: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the contact area of the antenna with a scalpel.
    • Be especially careful when pushing it around the mic port(marked in red) that's beneath it.
  8. Fix unstable bluetooth connection, Add piece of foam: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put a thin piece of foam the size of the contact area behind it.
  9. Fix unstable bluetooth connection, Push the antenna back in place: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fold the contact are back down.
Byte Hoarder
crwdns2935283:007/03/25crwdne2935283:0
535 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 84
