Fitbit Aria 2 Disassembly
  1. Fitbit Aria 2 Disassembly, Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the scale upside down on a surface that will protect the glass top of the scale and won’t scratch.
    • Remove the battery cover and batteries (if installed).
  2. Fitbit Aria 2 Disassembly, Remove Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fitbit Aria 2 Disassembly, Remove Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the label in the battery compartment. You can use a small flat headed screwdriver or similar implement to pry the sticker up. (Try to avoid damaging the sticker too much if possible).
    • Use a Torx T10 screwdriver to remove the two Torx screws and set aside.
  3. Fitbit Aria 2 Disassembly, Unclip Base: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small flathead screwdriver, starting new the corners, pry away the plastic panel from the glass top.
    • Once the gap is wider use larger pry tools to allow you to pull the bottom section away. You may need to use some force to release the clips.
    • Note there are no cables of components connected to the bottom plate so do not be concerned about ripping delicate cables.
    • Once open necessary repairs can be made.
    • If your issue is regarding inaccurate measurement you can remove the feet by pulling them, then remove the feet mounts using a small flat headed screwdriver to release the three clips.
    • Reassemble the feet and feet mounts outside of the unit then reseat them in the clips.
Peter Crowther
crwdns2935283:002/17/18crwdne2935283:0
136 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 1,214
