Fairphone 5 Earpiece Speaker Replacement
  1. Fairphone 5 Earpiece Speaker Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug all cables and power down your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Fairphone 5 Earpiece Speaker Replacement, Pry up the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Pry up the back cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the bottom right of the back cover.
    • Pry up the back cover to release the bottom right corner clips.
  3. Fairphone 5 Earpiece Speaker Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the bottom right corner of the back cover with one hand and brace the phone frame with the other.
    • Lift the back cover away from the phone to release the clips around its perimeter.
    • Remove the back cover.
    • During reassembly, align the back cover over the phone and press along the perimeter until all clips snap back into place.
  4. Fairphone 5 Earpiece Speaker Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail, or a pry tool like a spudger, to lift the battery by its tab along the bottom edge.
    • Remove the battery.
    • During reassembly, slide the top edge of the battery into its recess in the frame before pressing the battery into place.
  5. Fairphone 5 Earpiece Speaker Replacement, Unfasten the connector cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Unfasten the connector cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the 3.9 mm-long screw securing the top unit connector cover at the bottom left corner.
    • The connector cover is labeled with a "1" and a triangle pointing downward.
  6. Fairphone 5 Earpiece Speaker Replacement, Pry up the connector cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Pry up the connector cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Pry up the connector cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your fingernail, or a pry tool like a spudger, under the notch at the left edge of the connector cover.
    • Pry up the cover to separate it from the top unit.
    • The cover is connected to the top unit by a plastic cord. Don't try to completely remove it from the top unit.
  7. Fairphone 5 Earpiece Speaker Replacement, Disconnect the top unit: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Disconnect the top unit: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the cover out of the way, use a spudger to pry up and disconnect the top unit press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  8. Fairphone 5 Earpiece Speaker Replacement, Unfasten the top unit: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Unfasten the top unit: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips driver to remove the six 4.9 mm‑long screws securing the top unit.
  9. Fairphone 5 Earpiece Speaker Replacement, Remove the top unit: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the top unit: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the top unit: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under the screw hole along the bottom edge of the top unit.
    • Pry up to release the clips securing the top unit to the phone frame.
    • During reassembly, insert the top edge of the top unit at a downward angle into the frame before pressing it down and re-engaging the clips.
  10. Fairphone 5 Earpiece Speaker Replacement, Remove the earpiece speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the earpiece speaker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fairphone 5 Earpiece Speaker Replacement, Remove the earpiece speaker: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the tip of a spudger under the bottom left corner of the earpiece speaker press connector.
    • Pry up to disconnect the earpiece speaker press connector.
    • Lift the earpiece speaker out of its slot in the frame and remove it.
    Once you get it replaced and put back together, you can run a direct test by 'calling' the phone number *#*#2886#*#*
    There should be a test for the speaker specifically. Just don't do what I did, Start the test then put the phone next to my head, like an idiot.
    Vacation5768 - crwdns2934203:0crwdne2934203:0
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168,853 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,296crwdne2935297:0
J'ai changé le haut parleur d'oreille, pourtant cela ne sonne toujours pas ni puis je entendre mon interlocuteur. Je pense qu'il s'agit d'un probleme de logiciel, mais je ne parviens pas à voir comment le débloquer. Quelqu'un saurait?
Cyril deK - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 536
